Intermittent Rough Running and Hesitation 400i | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by Ferraridoc, Oct 24, 2017.
  1. Ferraridoc
    Ferraridoc F1 World Champ Owner Silver Subscribed
    Jun 20, 2012
    17,225
    Gold Coast, Aust.
    Patrick
    My first thought was water in the fuel, so I ran some E10 through to soak any up. My next thought, as it seemed to happen after about 45 mins of running, was that the Dinoplex was getting hot, and on the way out, so I installed an MSD. On my first run, it happened in a few minutes, so that wasn't it either. It feels like an ignition fault - sudden onset of very rough running, no power, won't rev, but will suddenly run perfectly with a burst of smooth running and power, before dropping back into rough running again. In the past, it sort of goes away after a few minutes.
    Thoughts? I've only got coil and distributor left - I really don't want to look inside the distributor, it looks big and scary.
  2. Steve Magnusson
    Steve Magnusson Two Time F1 World Champ Lifetime Rossa
    26,876
    Is your 400i completely stock, or has it been modified for US legality?
  3. rovexienus
    rovexienus Formula Junior Silver Subscribed
    Jun 10, 2010
    588
    Sainte Colombe, France (near Lyon)
    Jean-Michel Savary
    Would a intermittently failing fuel pump create a similar rough running situation?
  4. Al Campbell
    Al Campbell Formula Junior Owner Silver Subscribed
    Nov 22, 2013
    581
    Australia
    Lots of things it could be. You may be on the money with the distributor - sticking mechanical advance. I would also check the fuel distributors & make sure the metering piston slides nice & free.
  5. simon klein
    simon klein Two Time F1 World Champ Owner
    Feb 25, 2009
    29,808
    North Qld
    simon klein
    I have the answer.
    Marc 0417776216.
    You're welcome.
  6. Ferraridoc
    Jun 20, 2012
    17,225
    Gold Coast, Aust.
    Patrick
    Aus delivered RHD - another problem with the new Fchat - hard to see where the poster is from!
    I thought of that, but it seems to be a global problem for the whole motor. AFAIK, a fuel pump will cause loss of power, but the engine runs smoothly on one bank.
    Like I said, the distributor is big and scary (and hard to look at). The only thing more scary is the fuel distributor. I'll have to bravely take off the cap and have a look with a mirror.
    Duh, what's your special subject - the bleeding obvious? I've been waiting for your bus to be finished. I'm afraid it won't actually make it there now. Marc won't answer his phone.
  7. samsaprunoff
    samsaprunoff F1 Rookie Silver Subscribed
    Jun 8, 2004
    4,465
    Edmonton, AB Canada
    Sam Saprunoff
    Good day Patrick,
    Perhaps a double check of the fuses to see if there is a problematic connection and/or oxidized contacts with the fuel pump and/or ignition circuit(s)?
    Cheers,
    Sam
  8. simon klein
    Feb 25, 2009
    29,808
    North Qld
    simon klein
    .............and it won't be this weekend as he's in Unzud.
  9. Ferraridoc
    Jun 20, 2012
    17,225
    Gold Coast, Aust.
    Patrick
    Yeah, got into a texting duel with him - he reckons next week. I'm about to go and check the fuses (Occam's Razor)
  10. simon klein
    Feb 25, 2009
    29,808
    North Qld
    simon klein
    You should keep away from razors.....you're not skilled enuff.
    neither am I :(
  11. kerrari
    kerrari Two Time F1 World Champ
    Oct 22, 2004
    24,044
    Coolum Beach AUSTRALIA
    Karen H.
    Leads? Especially if you have any 90deg connections... If it's fine one minute, crap the next, it can only be electrical?
  12. Ferraridoc
    Jun 20, 2012
    17,225
    Gold Coast, Aust.
    Patrick
    Yeah, still thinking electrical. The coil lead is my next port of call, then the coil itself - anything to delay opening the dizzy (here be dragons).
  13. kerrari
    Oct 22, 2004
    24,044
    Karen H.
    the reason I mentioned it was I spent a fortune chasing an intermittent problem on my 500(including rebuilding the Weber) which didn't fix the problem. Then I was just doing routine checking and discover the lead onto the coil has a 90deg connector, and while it seemed tight due to the boot, inside was actually a tiny bit short - problem solved... New condensors are also useful.
  14. Ferraridoc
    Jun 20, 2012
    17,225
    Gold Coast, Aust.
    Patrick
    Well, it appears I've been chasing up the wrong tree. I bravely took of the distributor cap, and it was like new inside. So I took it for another run, and it happened again, with a small popping from under the bonnet, which I thought was a misfire. So I pulled over and opened the bonnet, where I noticed the popping noise was a pulse in the LHS fuel circuit. I rigged up a bypass circuit for the circuit breaker, and the car runs perfectly. "Ah, a faulty breaker!", I thought, but after driving it for a few minutes, the bypass wiring started getting... effing hot!! It looks like the circuit breaker was doing its job after all, and a failing pump is the problem. I'll order one when I'm back from hols and see if I can close this bloody thread!
    Al Campbell likes this.
