Intermittent tach on 328 | FerrariChat
Discussion in 'Technical Q&A' started by Auraraptor, Sep 18, 2005.
  1. Auraraptor
    Auraraptor F1 World Champ Lifetime Rossa Owner
    Sep 25, 2002
    14,112
    MO
    Omar
    My tach is well intermittent in its function. Any ideas? I am having a feeling the connection behind the dial is weak.
  2. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    Could be the sensor on the flywheel - had a similar problem and changed out the sensor which corrected the problem. There is an ohms-based test for testing the sensor (do a search under "crank sensor"). If it's not the sensor then it could well be a connection in the guage, possibly an intermittent ground.
  3. Auraraptor
    Sep 25, 2002
    14,112
    MO
    Omar
    Hmm, does adjusting the flywheelsensor (or replacing for that matter) require a gearbox drop?
  4. pcord
    pcord Karting
    Jul 28, 2005
    53
    Near Phila, PA
    Pete C
    The easiest thing to do first is pull the cluster and check. You can pull it by pulling the lights at the 4 corners of the cluster and the screws are behind them. Use silly putting on your screw driver so the screws won't fall after removal. From there it should be easy to verify if it's the connection or something before it.
  5. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,298
    Colorado
    Dave
    Tachs with 3.2 motors are prone to fail. The thing to do is take it out and send it out for rebuild. There is a place in Palo Alto and another in Albuquerque. Cost is pretty reasonable. Someone here can provide the address if needed.
    Dave
  6. Skindiver
    Skindiver Karting
    Apr 22, 2004
    203
    JHB SA.
    Greg
    and posted the results for the benefit of all here.
    Die kittens die.
    Its the calibration pot, on the board, inside the unit, that gets carboned up, just like a slide type rheostat volume adjustor on an old hi Fi, that gets dirty and crackles like hell when adjusting the volume.
    Clean out the calibration pot and it works guaranteed.
    Skin.
  7. f355spider
    f355spider F1 World Champ Owner Rossa Subscribed
    May 29, 2001
    18,055
    I sent my to Palo Alto Speedometer, ran about $140 or so, plus shipping each way. They turned it around in 3 or 4 days. But call ahead for turn around times, as it can very by time of year.
  8. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    To answer your question about the ease of checking/removing the crank sensor, no, it does not require a removal of the engine/gearbox. All you do is remove the left rear wheel well surround and you'll be able to trace the sensor wires to the sensors mounted on the engine case by the flywheel. You can check the proper functioning of the sensor without removing the sensor - just trace the wire to the connector and perform the ohms test there - should read in the neighborhood of 500-700 ohms if functioning properly.
