Intro and high mile 456 question | Page 2 | FerrariChat
Discussion in '456/550/575' started by thphon, Oct 12, 2019.
  1. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Los Angeles/Montreal
    Chris
    A couple threads are here on repairing the motors. The same motor is for headlights and spoiler. The spoiler seems to go bad first because of exposure.
  2. ttforcefed
    ttforcefed F1 World Champ
    18,875
    those item numbers arent working for me
  3. fridolin_pt
    fridolin_pt Karting
    Mar 25, 2008
    162
    Germany NRW
    Fritz
    When I needed one I found a used one in a Volvo Forum from a Volvo 480 but they are rare and expensive.
    Dit you open the unit?
    What exactly is broken. Sometimes the contacts can be repaired.
  4. fridolin_pt
    fridolin_pt Karting
    Mar 25, 2008
    162
    Germany NRW
    Fritz
  5. tazandjan
    38,074
    There is actually no such thing as a major on one of our V12s. Most folks lump together a bunch of services, however, and call it a major. If you do not have to pull the engine, it is not a major.
    Prit Singh and Gizzi like this.
  6. ttforcefed
    18,875
    whooaaa - i didnt know that - i thought the 456 was an engine out - if its an engine in shldnt it be more like 4k? My f355 is an engine out and that belt service is $8k.
  7. tazandjan
    38,074
    Depends on what needs doing and whether there are any leaks from the cam seals and cam covers. Also depends on what was done at the last belt change. For long term owners, one degreeing the cams belt change may do you for a couple of lock and swaps if there are no leaks. Those are much less expensive. Also depends on whether the water pump needs rebuilding.
    ttforcefed likes this.
  8. thphon
    thphon Rookie
    Oct 9, 2019
    30
    Leonardo Arias
    I didn't know this, beside cam belts, what's part of the wrong-called major? Assuming a car that has been driven and has around 50k miles. I'm asking the specialist to give me a break down as well.
  9. tazandjan
    38,074
    Adjusting valve clearance if she has not had it done recently. Except for needing to change coolant every two years or so, the factory maintenance schedule is pretty good. New bearings/pulleys to go with the cambelt change, Hill Engineering ones recommended. Update tensioner brackets if an early 456. Check of suspension joints/bushings, although our V12s are pretty good for those lasting a while, unlike the 360/F430/612. Possibly cleaning the fuel injectors and changing the filters. All of this can be done piecemeal, but a lot of folks save it up for the cambelt change
    thphon likes this.
  10. Gizzi
    Gizzi F1 Veteran
    Dec 3, 2011
    5,183
    Brisbane, Australia
    Gezim
    So true. I have a 456 and a 430. The 456 bushes are so much better. And as usual Taz, you’ve hit the nail on the head with all items mentioned.
  11. asgor
    asgor Formula Junior
    Sep 8, 2016
    705
    Virginia, USA
    As for my earlier post about The Window Gap. F1 Imports (Naples, FL) will notoriously fix the window mechanism if you send it to them, but even so in some cases that won't remove The Gap in its entirety.
    The "clever positioning of the door gasket along the B-pillar" I was mentioning earlier is a simple but obvious solution: separate the door gasket from the B-pillar, nudge the gasket toward the window edge so that any existing gap is removed and place appropriate DIY spacers between door gasket and B-pillar so that it stays that way. I didn't see it in any threads: I guess I came up with it myself - but it's really both very simple and rather obvious.
    In my case the F1 Imports + gasket repositioning worked beautifully and both my windows seal extremely well - no gap.
  12. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Chris
    Ferrari had a similar fix, but it involved replacing the rear window with a new larger piece of glass.
  13. Prit Singh
    Prit Singh Karting
    May 29, 2017
    96
    London
    Hello
    These cars are very well build and provided they are well maintained the mileage should not be an issue.
    Mine had 93k miles with service history when it arrived. Lots of parts had never been changed. The clutch Is still original and also so are the engine/Gearbox mounts. Radiator is original and never been re-cored. To my surprise even the timing belt tesnioners looked like they have never been changed and are the old style. Windows seal well too!
    The engine uses no oil and service records show Mobil 1 0w40 has been used since the first service. I am now working through the whole car slowly changed parts that are worn.
  14. thphon
    thphon Rookie
    Oct 9, 2019
    30
    Leonardo Arias
    That's great to hear, congrats!
    Which model do you have specifically? And if you don't mind me asking, how much did it cost? I would've been scared of buying a car with so many miles but because of lack of knowledge on my part. If it's really an option for me as well it would be perfect because I'm really not interested in selling it ever hehe
  15. Prit Singh
    Prit Singh Karting
    May 29, 2017
    96
    London
    Thank you
    Its cost me around
    Many thanks
    The car Is a left hand drive 456GT motronic 2.7.
    The total cost was below £30k that includes lots of work and mods. I have done all work myself so far with the guidance of this forum and friend's. This also includes a custom made X pipe. I still have many more parts left and on order. The complicated work will be left to a specialist once I choose one to work with.
    I’n very grateful to this forum and members who really have helped me through some critical technical issues and knowledge
  16. Gizzi
    Gizzi F1 Veteran
    Dec 3, 2011
    5,183
    Brisbane, Australia
    Gezim
    How’d you go with the starter Prit?
  17. Prit Singh
    Prit Singh Karting
    May 29, 2017
    96
    London
    #43 Prit Singh, Oct 17, 2019
    Hi Gezim
    Once I got her started I moved the car to a better position and then decided to remove the starter. What a mission! I upgraded all the bolts and washers of the cats and X pipe to titanium whilst I was in there.
    I then purchased a brand new Bosch Starter that fits a Ferrari 512tr from ebay and swapped the flange. All the part numbers matched for the bendix. Refitted everything. She starts first time
    Thank you
  18. Gizzi
    Gizzi F1 Veteran
    Dec 3, 2011
    5,183
    Brisbane, Australia
    Gezim
    Good work mate!
    Prit Singh likes this.
  19. fridolin_pt
    fridolin_pt Karting
    Mar 25, 2008
    162
    Germany NRW
    Fritz
    Can you post a photo?
  20. EnzoItaly
    EnzoItaly Formula Junior
    Sep 29, 2016
    263
    Would indeed be interesting if you could post some photos: I’d like to tackle that issue as well.
    Verzonden vanaf mijn iPhone met FerrariChat
  21. Gizzi
    Gizzi F1 Veteran
    Dec 3, 2011
    5,183
    Brisbane, Australia
    Gezim
    If you buy a new door deal, it’s slightly larger than the original one. The proper fix has to involve having the window regulator repaired by F1. The alloy pivot pin in the centre of the scissor section wears a groove in one side because of the constant ‘burping’ down and up with every open and close action of the door. They replace it with a stainless steel version they make up in house. Combined with the new gasket, and proper window adjustment, it’s a perfect, long term solution.
