Hello All: I was wondering if anyone else has seen the following issue. With the headlights on, I noticed that the panel dimmer is affecting my instruments. I can actually add about 10 psi of oil pressure and a quarter tank of gas just by cranking up the dimmer With the panel dimmer all the way down or lights off, the instruments return to normal values. Is this indicative of a short or bad ground somewhere ? Oleh
