Iphone mount? | FerrariChat
Iphone mount?
Discussion in '308/328' started by mike996, May 12, 2010.
  1. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,870
    Mike 996
    #1 mike996, May 12, 2010
    Anybody found a good iphone mount that works well in our cars? I use my iphone for GPS (Navigon) as well as other applications so I'd like something that will hold it in clear view up around eye level. I'd also like to run it to the radio but my radio has not aux input so that's not happening anyway...
  2. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,320
    I just use a suction cup thing on the windscreen for my smartphone (sat nav). It doesn't interfere with visibility at all because its pretty much in line with where the wipers park. I don't like having the Sat Nav down low because the time it takes to look down & for your eyes to focus on it is too long. It needs to be where you can just glance across at it.
    I did mount an auxilliary power socket for it below the centre console so that I don't have to have a wire running back to the cigar lighter. It gets its power from the cigar lighter circuit & I put a small relay in the circuit so that its only live when the ignition is on.
    For the Ipod connection, the (fairly low end) Alpine head unit i have has iPod connectivity and came with a cable for same. I don't use it (because I don't own an iPod!) but the same head unit also takes USB sticks & so I have a couple of 4GB sticks that live in the car
  3. chrisbinsb
    chrisbinsb F1 Rookie
    Oct 20, 2011
    3,675
    Santa Barbara
    Chris B
    I had a similar issue and replaced the the radio with a new one - oxygen audio o-car. It's basically just a cradle with a volume knob. The iPhone slots in and then controls the radio tuner as well as playing any iPhone audio. Also has Bluetooth and a mic for hand free but I doubt anyone could her me well over the engine. And of corse it charges the phone.
    It's not perfect - getting the phone in the cradle is a little awkward and the unit is so deep set on the 308 that I can't rotate it to vertical, the phone stays horizontal. The radio tuning app is really slow while tuning manually, scanning is fine and presets are fine. If you only listen really to one local radio station, it's also nice that it will play the last station even when the phone is not in the cradle.
    I did not want a separate cradle or extra aux cables in the car so it's worked well for me even with the quirks, might be good for you as well.
    Edit - this obviously places the phone lower than eye level so if that's a major factor, it won't work for you.
  4. vne
    vne Karting
    Jan 2, 2006
    132
    South Is New Zealand
    N R
    My phone fits perfectly side on in the empty ash tray. Take out the ash flicker gizmo - and Wala - a perfect little I phone holder. Yes it is side on but u sure can see a call comming in and it is exactly the right size. However it certainly will not work as nav aid.
    I keep phone off when driving anyway - so it is a holder for me.
    Perfect.
  5. Dr Kananga
    Dr Kananga Formula 3
    Apr 20, 2011
    1,222
    Los Angeles, CA
    Buonapart I. Gallia
  6. chrisbinsb
    Oct 20, 2011
    3,675
    Santa Barbara
    Chris B
    #6 chrisbinsb, Feb 20, 2012
    It replaced the existing head unit. They also make a dock coming out soon that charges and can output to an existing head unit. I didn't want any more cables or docks in the car than necessary so I went for the head unit model.
    I don't have any photos of it in my car right now, but here's the head unit model and upcoming dock.
  7. Agsurf5
    Agsurf5 Rookie
    May 29, 2011
    46
  8. chrisbinsb
    Oct 20, 2011
    3,675
    Santa Barbara
    Chris B
    That looks interesting, primarily as it appears to allow easy and full use of the radio without the iphone docked. It doesn't say if the dock can be rotated to horizontal if that's important.
    One thing to find out on this is how far out the dock extends - the 308 at least has a pretty significant "shelf" that extends out over the radio opening.
    I should say regarding the oxygen unit that the dock can be rotated to vertical, but barely - the back of the dock presses against the vinyl of the dash above the radio. I avoid it as I don't want to cause wear over time. If the radio were to be installed without recessing it all the way into the opening, perhaps witha custom sleeve, it could be rotated freely. Might look odd though.
  9. TwiceBaked
    TwiceBaked Formula Junior
    Feb 19, 2012
    739
    Lake Arrowhead Calif
    Karlton Spindle
    iPhone dock II for Ferrari is done! Will work with ANY Ferrari with an iPod cord in glove box. Also noting comes with the proper cords to make your cord work with you iPhone OR ANY Ferrari with a Ferrari ash tray or Ferrari cup holder.
    NO drilling no changing head unit.
    You can get the plastic only or the whole kit.
    I dont want to change my head unit and the data it puts out to the car. Because there is no drilling you can simply remove it if desired and its like it was never there. Cant do that when you muck around with a new head unit.
  10. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,163
    SB,CA & Park City UT
    Jeff
    I looked really hard for my glove box but couldn't find one.........not sure the point of this post in this section. Am I missing something?
  11. TwiceBaked
    Feb 19, 2012
    739
    Karlton Spindle
    #11 TwiceBaked, Mar 19, 2012
    Its a strange thread agreed.. Point of this is unless you enjoy drilling holes in your car or you like replacing your head unit in your car for the most part you cant get Sat radio or a decent turn by turn Nav in allot of Ferrari cars. Well now you can. really you would put a $100 head unit in a 200K 599? Google search iPhone Mount Ferrari see how many options you come up with.
    http://s9.photobucket.com/albums/a59/mrmpx/Ferrari%20599%20GTB/
  12. Bobolingfo
    Bobolingfo Rookie
    Feb 10, 2015
    11
    These days, the imagnet seems to be the best choice...
  13. sltillim
    sltillim Formula 3
    1,693
    San Diego
    Ram Mount x-Grip - they are the best. You can figure out multiple mounting options. You are not constrained to the current make/model of phone. I have a twist/lock suction cup mount for my cars and move the arm to my Ducati with a ball mount on just below the instrument cluster.
  14. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,215
    Gold Coast, Aust.
    Patrick
    I'd show you what I've done, but I'm afraid I'll be lynched by the purists
  15. E-Dino
    E-Dino Formula Junior
    Aug 11, 2012
    378
    San Diego
  16. Carbuilder
    Carbuilder Formula Junior
    Aug 18, 2012
    550
    Bolton, ON
    Rick
