IPOD connection in 2008 F430 Coupe
Discussion in '360/430' started by Zinger, Oct 11, 2011.
  1. ATTENTION: http/https Bug Fix! Most of us have been experiencing problems staying logged in as we navigate the site. That is simply the result of links varying between http and https, which each require different logons. To resolve we are going to force https starting sometime Wednesday. However, you may have problems accessing FerrariChat until after you log out, clear cookies/browser cache, and log back on. Keep in mind my email is admin@ferrarichat.com if you do have access problems after Wednesday. Thanks!
  1. Zinger
    Zinger Formula 3
    Apr 11, 2009
    1,668
    Leesburg, Va
    Ryan M
    I have the Hi-Fi sound in my 08 F430, how do I add the Ipod connection in the glove box? Cost?
    Thanks!
  2. bshah
    bshah Formula Junior
    Jun 28, 2011
    326
    Chicago
    I would like to know too...however, on my 06 430, there is a SD SLOT behind the face plate...which is almost as equal to an iPod.
  3. sclja
    sclja Formula Junior
    391
    San Diego Ca
    Scott Cairncross
    it takes @ 1 hr or so / the radio comes out of the dash the cd changer gets unplugged and the ipod interface plugs into the same port the cdc was plugged into....Next the ipod cable need to be routed to the back of the glovebox and then the ipod cable needs to be run into the glove compartment and normally a hole has to be made to get it into the compartment. I use a 1.25 inch diameter hole with a plastic grommet to fill the hole. The interface can be aquired from Becker http://www.beckerautosound.com/ if they have it in stock it if not I have 1 left...
    Scott
  4. greyboxer
    greyboxer F1 Veteran
    Dec 8, 2004
    9,260
    South East
    Jimmie
    There's several picture threads covering this modification over the years - try a search on '360 ipod'
  5. Zinger
    Zinger Formula 3
    Apr 11, 2009
    1,668
    Leesburg, Va
    Ryan M
    Thanks for the link sclja. I will order the connector for the Ipod and get it installed.
  6. sclja
    391
    San Diego Ca
    Scott Cairncross
    #6 sclja, Oct 13, 2011
  7. Tired of seeing this ad? Upgrade now
  8. Houston348
    Houston348 Formula 3
    Oct 18, 2006
    2,269
    FYI, you do NOT have to remove the radio to plug in the ipod cable.
    I got a flashlight and got down under the dash on the driver side floor and from there, I could see the CD changer plug and unplug it and snap the ipod cable in
    Step 1. Purchase the ipod cable from Becker
    Step 2. Install in 5 minutes
    viola!
  9. Zinger
    Zinger Formula 3
    Apr 11, 2009
    1,668
    Leesburg, Va
    Ryan M
    Thanks for the tip, I will try it.....
  10. KJM3SMG
    KJM3SMG Formula Junior
    Dec 3, 2006
    946
    Loudoun County, VA
    Karl - KJ
