Ipod connection in F430 | FerrariChat
Discussion in '360/430' started by wlracing, Feb 8, 2010.
  1. wlracing
    wlracing Karting
    Dec 14, 2004
    234
    wally
    Any one use the Ipod dock in there F430 ? if so does it charge and can it be turned off without disconnecting ? I am useing A Gen 5 Nano works great but does not charge and must disconnect to turn off .
  2. m.roberts
    m.roberts Formula Junior
    Nov 2, 2009
    907
    I believe it will charge an iPod, but not an Iphone.
    Not sure what you mean by can it be turned off... if you mean the car, then.. yes.
    I leave my iPod connected in the glove box and never really mess with it. The onscreen controls on the headunit work pretty well.
    I only use my iPhone if I have a new song that isn't on my iPod.
  3. wlracing
    wlracing Karting
    Dec 14, 2004
    234
    wally
    I mean the Ipod screen stays live when the car and radio are turned off .The display on the Ipon screen says this device does not support charging , it has been suggested to me that a Generation 3 Ipod has a different voltage so may charge ?
  4. RSQP
    RSQP F1 World Champ
    18,299
    California
    Boudreaux
    I've been told there is an adapter that fits between the ipod and the connection to the car to remedy the non-charging supported ipods and iphones.
  5. forgeahead
    forgeahead F1 Rookie
    Sep 16, 2008
    4,408
    Rocky Mount, NC
    Ray
    There is, indeed.
  6. wlracing
    wlracing Karting
    Dec 14, 2004
    234
    wally
    Would this adapter also allow the Ipod to turn on & off with the radio ?
  7. wlracing
    wlracing Karting
    Dec 14, 2004
    234
    wally
    What Ipod do you use ?
  8. chopperdr
    chopperdr Formula Junior
    May 10, 2009
    318
    oceanside/vancouver
    cal meeker
    on my ipod touch, in our 430, leave in the glovebox, plugged in and forget about it.
    on the 16m, have to remove and recharge at the end of the day. kinda sucks
    cal
  9. RSQP
    RSQP F1 World Champ
    18,299
    California
    Boudreaux
    Does the 430 have an adapter for more recent Ipods/iphones? That's odd that your 16M doesn't charge it. I'm assuming it's the same ipod in both cars.
  10. m.roberts
    Nov 2, 2009
    907
    The standard 430 has a dock wire in the glovebox.... The 16m and scud have a weird thing where the iPod clicks into the headunit.
    I haven't paid attention whether or not the iPod turns on or off with the car. I'm sure it just pauses and then turns into suspend mode from inactivity.
    As long as u get the adapter that I linked to earlier, it really shouldn't be an issue
  11. sclja
    sclja Formula Junior
    392
    San Diego Ca
    Scott Cairncross
    you can get the charge / voltage step down adapter it drops the 12 volts to 5 volts which is what all new ipods and iphones need to charge...The device won't work in the 16m or the scud dock .... The device doesnt turn the ipod on and off. If anyone needs an adapter I have them in stock .
    Scott La Jolla Audio
  12. wlracing
    wlracing Karting
    Dec 14, 2004
    234
    wally
    Is Gen 3 Ipod Nano 12 volt or 5 volt ?
  13. g4titan
    g4titan Formula 3
    Feb 6, 2010
    1,196
    Around
    Nico
    Do all MYs have IPOD connection abilities are are there specific radio options you have to have? Thanks!
  14. wlracing
    wlracing Karting
    Dec 14, 2004
    234
    wally
    Factory option on later cars in UK, dont know about USA .
  15. fc2
    fc2 F1 Veteran
    Nov 2, 2006
    5,263
    Silicon Valley Ca.
    Frank C.
    I plug my nano into the connector and leave it... I never touch it. It's worked this way since the car was new in '07.
    Of course, last month I went to use it and all the music had been magically erased :D
    A great excuse to reload the iPod with _even_ better music.
  16. kryten22uk
    kryten22uk Rookie
    May 28, 2007
    4
    Guys, I have bought a Becker ipod connector for my Cascade, and it can/does plug into the back of the unit. however a question:
    Those of you who have them in Glovebox, is there a way of feeding the connector into the Glovebox, assuming I didnt have the OEM iPod connectivity option?
    Alternatively,
    Those of you who have ipods sitting in the centre console square pockets (next to launch control etc) do you have a hidden or neat way of the connector wire getting there from behind the stereo, or is it just free-form?
    Ta
  17. Apple Sauce
    Apple Sauce Formula Junior
    Jun 30, 2008
    626
    Wide Open Throttle
    Vic
  18. kryten22uk
    kryten22uk Rookie
    May 28, 2007
    4
    I did read that and saw your comment regarding the OEM cable being too short, and tucked into pocket. But was wondering what people do with the aftermarket longer cable, especially comments in other threads talking about the glovebox; I cant see how to get it into the glovebox.
