is a 360 challenge a viable daily driver? | Page 3 | FerrariChat
Discussion in 'Challenge/GT Cars/Track' started by ross, May 11, 2009.
  1. wolfeyes89
    wolfeyes89 Rookie
    Jan 22, 2008
    30
    Imho I think you should just pull the trigger :D. I mean it's a challenge car and if you already have some dds then I don't think there's anything to worry about :D. Besides it;s a challenge car, I mean imagine just pulling up to a scud or a 16m (no offense to the owners of said cars), the challenge just doesn't compare like you said it's a hard core car. Plus if it's only for quick jaunts I don't think you would mind like James did. Unless the ground clearance is as bad as it seems. In any case any choice is a win/win :D.
  2. scottypoz
    scottypoz Karting
    May 8, 2006
    54
    as a 360 challenge owner, i still say if you buy this to drive on the street anywhwere....you will hate it...its a race car, by the time you make it a street car, with the money you spend, buy a stradale
  3. ross
    ross Three Time F1 World Champ
    Mar 25, 2002
    38,221
    houston/geneva
    Ross
    well guys, i went to see it and had a test drive. WOW !!!! WOW !!!! did i mention WOW!!!!
    ok, here is the scoop. the car was raced in the challenge series in 2000 for one season by a dr moller (sp?). after which it was sold to a company (another guy) who also raced it but then had a shunt which damaged the front right side. so it was sold onto the present owner, where they repaired it (btw, the whole front end was replaced and he said that was standard for challenge cars). he decided to make it into a gt spec:
    - the front splitter, rear wing, brakes, and breathing all upgraded, and now puts out 430bhp
    and then it was adjusted to be made road legal in switzerland (no mean feat), and yes i have seen all the papers, its the only one in existence.
    - the steering rack was swapped out for a regular one so that you can actually turn a radius approximately the same as a 360
    - the brake pads are a little less racy, so they work well at lower temps
    - the race springs were swapped out for slightly less hard ones
    - the ride height was raised to about 4''
    - the exhaust was tamed
    - not necessary but, lots of carbon fiber parts added, now weighs 1211 kg
    it has now been driven a total of about 18,000 km on the street, and 10,000 km on track. it gets transported to far away tracks, and driven to the closer ones (altho he has driven it to monza twice and then swapped out to slicks, done 30-40 laps, then swapped out the tires, gone to dinner in town, and driven it back home !). it comes with a full set of slicks on separate challenge rims. cosmetically it is pretty good, but does have road/track rash here and there. the rear wing adds 100kilos of downforce already at 80kph ! the front splitter is easily taken off, but seems to clear most small curbs fine, so probably not worth taking off.
    startup: when you first switch on the battery, you need to wait 5 minutes for the computer to come up and everything to be kosher. then you just push the button and it comes to life - actually it erupts into a wall of sound that reminded me of that old memorex add ! then you have to let it warm up another 5 min or so, after which the noise level decreases sufficiently to pass the swiss noise test at 70db max i think.
    getting in: full padded roll cage makes it a pretty tight entry, but once inside it is typically ferrari roomy and practical. 4 point harness is easy enough. carbon fiber doors seem flimsy, but they are light. the lexan windows are not great either but again, they are light. (they also leak in the rain).
    driving: well some of you were right and some of you were not (largely because of the adjustments that have been made as noted above). the ride was pretty harsh compared to any normal road car. i could hear every pebble hitting the bottom, the chassis groaned and creaked, and the engine noise was VERY loud. BUT the steering was fine, i could turn corners and park (altho rear visibility was poor thru the lexan engine cover split by the wing); the ride was hard, but not conestoga like, the brakes were immediate and firm. the gearbox was great actually. at lower speeds the gear changes are subtle and easy, at speed the gear changes are very direct and bolt-like, so it seems well adpated for both purposes. engagement at low speeds was a bit jerky and starting in reverse was not something you would want to do a lot of.
    overall: this car is a race car that has been softened to become street legal and practical. it is a weapons grade track day car in the hands of an amateur such as myself, and is likely one of the least tame road cars in europe. one could say that since it is somewhere in the middle (albeit closer to 'track' than 'road'), that it will serve neither purpose well. but since i am not likely to be gunning for a challenge championship any time soon, and since i also have plenty of cushy sports cars, this might just be the ticket. i am going to give it some more thought, and the seller promised to leave it for me until sometime in september at least. ....
  4. CarbBoxer
    CarbBoxer Formula Junior
    Oct 7, 2008
    844
    Houston
    PW
    Sounds like a fun toy. M
    Just keep the purchase price low enough to consider that when it come to resale, your prospective market of purchasers is limited.
  5. ryalex
    Aug 6, 2003
    26,299
    Las Vegas, NV
    Ryan Alexander
    You need to rewatch the Top Gear where James thinks he's all clever getting an Aston race car for a cross-Europe drive...
  6. ross
    Mar 25, 2002
    38,221
    houston/geneva
    Ross
    forgot to say that they also added a hand brake to pass the street test.
    another question, how often do you need to re-flash the gearbox software? ie how often does it go wonky? and does the overall engine management system need the same kind of attention or does it just continue without trouble?
  7. Simon^2
    Simon^2 F1 World Champ
    Oct 17, 2005
    12,313
    At Sea Level
    I've always been told it's insanity to drive a car with a roll cage without a helmet...
    Ross, do you have kids?
  8. ross
    Mar 25, 2002
    38,221
    houston/geneva
    Ross
    the cage is padded, but i know what you mean...i guess i will just keep a helmet in the car at all times ;)
    apart from the cage, the noise, and the harder ride (admittedly all major issues but not as bad as a normal challenge drive), i dont see that much difference in terms of comfort or safety vs a cs (i have even seen some cs's with roll cages). the 'daily driver' tag line in the thread starter was just to get some reaction from people - i do not intend to drive this daily at all - it will be an occasional weekend toy and track day weapon.
    how about somebody that has cs and challenge experience give us a comparison?
  9. Challenge64
    Challenge64 F1 Veteran
    6,367
    Ron
    sure..what do you want to know?
  10. goober
    goober F1 World Champ
    Nov 15, 2004
    15,895
    Adelaide & Thredbo
    Buddy Miles
    there is no comparison.............one is a race car, the other a street legal car
  11. low flying kiwi
    Jul 27, 2009
    7
    Yes its a nice car but have you considered buying a Lotus instead? Everyone knows that they handle better than Ferrari's and the absence of the roll cage means you can still pull chicks once your wife has divorced you for buying the inpractical Rarri :D
  12. ross
    Mar 25, 2002
    38,221
    houston/geneva
    Ross
    phil, sell your lotus somewhere else !! ;)
  13. ross
    Mar 25, 2002
    38,221
    houston/geneva
    Ross
    well everybody has been telling me how harsh the whole challenge driving experience is, and yet the challenge stradale is billed as being the same car with sound deadening, carpets, and softer springs....so are the real back-to-back sensations just down to this louder, harder environment?
    here is another angle on the issue...is there a stradale owner here, that would prefer it if his car was more adapted to the track?
  14. Challenge64
    6,367
    Ron
    Last question first. To adapt a Stradale more to the track is to change mostly the suspension set up. Some have posted here some detailed info on how to do it and it is possible. The motor doesnt really need any work. One can fool about with the exhaust and stuff but there really isnt the need imo. Are there Stradale owners that want their Stradale as a track car? Not me. Maybe others..but definately not me. I would rather buy a Challenge car at 1/2 the price for double the fun..and safety.
    Driving experience - Both are loud. As I look back I think I spent almost the entire time owning a Challenge car with a helmet on. So I cannot compare noise. I think I posted a few times about driving both on the street and have said that driving a Challenge car on the street is an awful experience. I did take my Challenge car out on the street. Legally even too. It was during the 2000 FCA National Meet and I used their temp FCA/Colorado tags. But the Challenge car was not fun. The worst part was the brake squealing and the suspension. The suspension set up had alot of neg camber in the front so I was riding the inside edges of slicks through town. The Stradale has a totally different brake system (of course) and it's apple and oranges. The Stradale suspension isn't harsh and it is build for the street.
    So in otherwords what a post before mentioned in a sentence. One is a race car the other is a street car.
  15. ross
    Mar 25, 2002
    38,221
    houston/geneva
    Ross
    that was extremely helpful. thx !
    if i get this car i will likely not drive it on the street that often, even though i can. (the present owner has racked up a lot of mileage on the street, so it must not be complete hell). and it is more likely that i will only drive it hard on the track, so the current set-up is more suitable.
    i think i will get the car, and see what happens. you only live once ! and this is like a bargain basement F40 LM !
  16. Challenge64
    6,367
    Ron
    #66 Challenge64, Jul 27, 2009
    Speaking of F40LMs...here is a shot of me passing one at the old P.P.I.R. in Colorado
  17. ross
    Mar 25, 2002
    38,221
    houston/geneva
    Ross
    nice pic !
    question for you, do the challenge cars have a door lock system? i forgot to look on saturday, and now cant see it in the pics
  18. Challenge64
    6,367
    Ron
    Mine had door locks and I even had a key to lock the car. But from what I hear that was a mistake and most did not come with either.
  19. goober
    Nov 15, 2004
    15,895
    Adelaide & Thredbo
    Buddy Miles
    the sliding glass lexan doesnt lock, I had small retaining bars fitted so the slide is locked, the hood and engine covers are just clips and can be opened from the outside, same again, had small padlocks fitted to prevent opening..........this is all bearing in mind there is no ignition key system for starting the car hence dont leave it out of sight!
  20. low flying kiwi
    Jul 27, 2009
    7
    I am sure you could fit an imobilser and alarm system to protect the car from being stolen. You can also remove the red electric power turn switch key. I wouldnt ruin the look by fiting padlocks to any removable bodywork. If its just held on by split pins you could change it to Zues clips which require more intention to open.
    This is a car that is really only for track days and carefully planed trips. It has a lot of things about it that will piss you off if you expect it to be a daily driver. If you understand what you are buying and have the spare money it could be a lot of fun, as you say, a budget F40.
    Alternatively you could buy a Ferrari F1 car and keep that for track days. I guess you could pick one up for around £100k that is also loud and doesnt come with a locking key :D
  21. Simon^2
    Oct 17, 2005
    12,313
    At Sea Level
    $600K US is about as low as they go. Running costs average out to about $30K per track weekend ... assuming you don't shunt it...
  22. ross
    Mar 25, 2002
    38,221
    houston/geneva
    Ross
    i am not yet at f1 clienti class yet. in the meantime, this bargain f40LM will have to do.
    next area of difficulty is space...anybody want the best 456mgt in switzerland??
  23. Testacojones
    Testacojones F1 Veteran
    Nov 3, 2003
    5,198
    Florida
    Luix Lecusay
    Well, do you have any advise on how turn $100K into a million or several?
  24. davidsalfa
    davidsalfa Rookie
    Jun 25, 2009
    1
    Ok I have some experience with this. No door locks, no ground clearance, huge turnning circle etc, etc....If you want a race car buy a race car if you need a street car that you can track on occasion, a slightly modded 360 can be alot of fun.
  25. ross
    Mar 25, 2002
    38,221
    houston/geneva
    Ross
    david, thx for your note, but pls refer to previous answers which address those areas of concern.
