430 - is a tune required? | FerrariChat
430 is a tune required?
Discussion in '360/430' started by status:one, Apr 23, 2020.
  1. status:one
    status:one Rookie
    Oct 28, 2014
    30
    Dallas, TX
    Chris B.
    I currently have a TopSpeed Pro-1 Headers and Titanium Exhaust... I am adding the test-pipes tomorrow, will a tune be needed for the car to run safely?
    IG: @statusone_430
  2. vv23
    vv23 Formula Junior
    Jan 8, 2009
    259
    Edmonton, Alberta
    V V
    You will get a check engine light for the post cat sensors.
    Otherwise should run fine though
    status:one and Eric C like this.
  3. Eric C
    Eric C F1 World Champ
    11,089
    St. Louis, MO
    Eric
    yep. you'll def end up with a check engine light and extenders won't help........... so that's when a tune is a good idea so you can get them to turn off that parameter
    status:one likes this.
  4. ttforcefed
    ttforcefed F1 World Champ
    19,257
    the tune can address the error but i wldnt expect much in terms of hp to rear wheels
    any owners have dyno results before and after an ECU tune?
  5. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Ear plugs might help if u can live with it
  6. status:one
    status:one Rookie
    Oct 28, 2014
    30
    Dallas, TX
    Chris B.
    Luckily, no CEL yet and the car runs and drives great. Absolutely love the sound. Appreciate everyone’s input.
    IG: @statusone_430
  7. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    When u start it up, let it warm up without blipping the throttle- mine used to throw codes when i fitted the Capristo manifolds. I now allow it to tick over and get the exhaust sensors hot before i drive it, if any unburnt fuel goes down the pipe it cannot then drown the sensor as it is too hot for the fuel to affect the sensor
  8. 24000rpm
    24000rpm F1 Rookie
    it usually will not throw a cel until you continuously drive it for at least 300 miles ( 500km). Cat efficiency.
    Personal experience.
    drive short drives under 300miles each time you'll get a code without a cel. Only seen by hooking up a obd reader.
  9. Pedro MD
    Pedro MD Rookie
    Sep 22, 2017
    22
    El Paso, TX
    Pedro
    If you dont have a cel yet, you most likely will once you delete the factory cats and install the test pipes. An ecu tune can fix the cel to pass emissions inspection and will maximize hp from your exhaust mods. I'm currently shopping around for ecu tune options for my 430. Not too much info on the subject. Mase engineering seems to be popular on fchat.
  10. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    300 miles here is a long drive
  11. 24000rpm
    24000rpm F1 Rookie
    I didn't know this secret until I drive my de-precatted 430 from Beijing to Jinan, which is about 350 miles.
