Is anyone in the Geothermal Heat Pump business? | FerrariChat
Discussion in 'Other Off Topic Forum' started by 62 250 GTO, Aug 18, 2005.
  1. 62 250 GTO
    62 250 GTO F1 Veteran
    Jan 9, 2004
    7,765
    Nova Scotia Canada
    Neil
    Is it really as efficient as it sounds?
    "Geoexchange is the most energy-efficient, environmentally clean, and cost-effective space conditioning system available, according to the Environmental Protection Agency."
    http://www.geoexchange.org/
    Movie about how it works:
    http://www.geoexchange.org/about/movie.htm
    Sounds very nice but is it worth it for an average home or small cottage?
    Thanks for any input.
  2. darth550
    Jul 14, 2003
    61,150
    In front of you
    BCHC
    Gentry is.
  3. 62 250 GTO
    Jan 9, 2004
    7,765
    Nova Scotia Canada
    Neil
    Just because he pumps into his fist until he sweats doesn't mean he's in the the geothermal heat pump business.
  4. robert biscan
    robert biscan F1 Veteran
    5,082
    Nashville and Palm b
    robert s biscan
    We have installed maybe 10 or so geothermal systems for schools in Tn. and Kentucky. They cost more but the extra us made up in 3 years or so and then it's money in the bank. It's just a big water loop with heat pumps.
  5. wax
    wax Five Time F1 World Champ
    Jul 20, 2003
    52,417
    SFPD
    Dirty Harry
  6. 62 250 GTO
    Jan 9, 2004
    7,765
    Nova Scotia Canada
    Neil
    So if you can afford to install it, it's worth while?
    It looked pretty simple, I thoughr maybe I was missing somthing.
    Thanks.
  7. TimN88
    TimN88 F1 Veteran
    Jun 12, 2001
    5,054
    Northeast
    Tim
    I am familiar with heat pumps. They are only efficient in mild climates. The power needed to run one increases as the temperature difference between your hot and cold reservoir increases. This means that they are better suited to climates like, say, the south where it doesnt get very cold in the winter than they are in climates like the northeast. If you want more of an explanation I could dust off my thermodynamics textbook.
  8. TimN88
    TimN88 F1 Veteran
    Jun 12, 2001
    5,054
    Northeast
    Tim
    Sorry, I didnt see you are from Canada. That pretty much means you dont want one.
  9. DGS
    DGS Seven Time F1 World Champ
    72,024
    MidTN
    DGS
    Unless your "reference" temperature is much warmer (heating) or colder (cooling) than room temp, you'll still need a compression/expansion cycle for the heat exchange. You want to make sure your thermal "reservoir" can absorb or source a lot of heat. That means volume flow through the ground loop.
    I did some research on this topic back in Massachusetts.
    In milder climates, installers tend to lay out the ground loop horizontally, a few inches deep. You don't want that for Canada. The better, but more expensive option is to run the ground loop vertically -- which means drilling ... deep drilling. Like an oil rig.
    Your ground loop should go down enough to get to relatively constant temperatures, regardless of season. With Canada's seasons, you'll want to go really really deep.
    Like to Australia. ;)
    But to make a geothermal pump work for Canada, you'll probably need to get well below the water table. Check for what kind of permits and approvals Kanukistan requires for that.
  10. 62 250 GTO
    Jan 9, 2004
    7,765
    Nova Scotia Canada
    Neil
    Thanks guys, now I know what kind of questions to ask. I know of a few cabins that have this kind of pump, I'll talk to him and the company who installed them.
