430 - Is burning oil smell common? | FerrariChat
430 Is burning oil smell common?
Discussion in '360/430' started by V1ROT8, May 4, 2020.
  1. V1ROT8
    V1ROT8 Rookie
    May 4, 2020
    12
    Tucson, AZ
    I’ve searched other threads but can’t find an answer.
    I have a 2006 F-430 Spider with 14k miles. I’m getting pretty familiar with this particular vehicle, but I’m not super familiar with F-430s in general. Lately when I really open up the throttle, I smell what seems like burning oil. Definitely not clutch. I pulled the bottom tray and there are absolutely no oil leaks or seepage, and the exhaust parts all look dry. And no smoke out of the exhaust. Seems like normal oil consumption. The smell occurs with oil at both the full dot and low dot on the dipstick. I don’t see any indications of oil being burned. Is this just a normal smell on this car when it’s run hard?
    Thanks for any ideas!
  2. ttforcefed
    ttforcefed F1 World Champ
    19,256
    not really. if the car has hiflow cats or test pipes you might get some fuel type scent but not all burning oil. is the car stock? exhaust?
  3. Some Guy in the sky
    Some Guy in the sky Formula Junior
    Sep 19, 2018
    361
    #3 Some Guy in the sky, May 4, 2020
    I had something similar with my 360 when I first got it, it ended up being a ignition coil (20 year old originals on 100% stock car) that was arching at high rpm and burning itself. Replaced all coils and things were fine.
    EastMemphis likes this.
  4. V1ROT8
    V1ROT8 Rookie
    May 4, 2020
    12
    Tucson, AZ
    The car is totally stock, although I believe the previous owner had a Capristo exhaust on it at some point.
    Coils, huh? Interesting, I’ll definitely look into that. I’m sure the car needs new plugs anyway, maybe it would be a good time to do the coils too. Maintenance history is a bit spotty on the car.
    thanks
    Some Guy in the sky likes this.
  5. V1ROT8
    V1ROT8 Rookie
    May 4, 2020
    12
    Tucson, AZ
    One more question about the arcing coil. When you replaced it, did you notice anything unusual about the spark plug or coil itself? Burned/worn/gunked up/ anything like that?
  6. Some Guy in the sky
    Sep 19, 2018
    361
    I don't know because my mechanic did it.
  7. AandSC
    AandSC Formula Junior
    957
    Jax, FL
    Allen
    Have you looked at your valve cover gaskets? If they haven’t been replaced there’s a chance they are seeping.
  8. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,945
    Central NJ
    Dominick
    Please excuse this if it sounds silly ..but did you check the oil according to the instructions ..alot of people don't wrong and end up causing oil to get into the intake
    Sent from my moto g(7) using Tapatalk
    van22 and brookliner7 like this.
  9. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,471
    Menlo Park, CA
    Paul Chua
    have you checked your valve gaskets? It could a small amount of oil seeping that leaking onto your exhaust,cats,headers and burning - creating the smell.
  10. V1ROT8
    V1ROT8 Rookie
    May 4, 2020
    12
    Tucson, AZ
    I’ve been checking the oil with the engine hot and running. Usually after a drive.
    EastMemphis and flash32 like this.
  11. RedTaxi
    RedTaxi F1 Rookie
    3,339
    New Zealand
    Glen
    This is the first place to look. There should be no oil burning smell.
  12. V1ROT8
    V1ROT8 Rookie
    May 4, 2020
    12
    Tucson, AZ
    Are you talking about the valve cover gaskets?
  13. RedTaxi
    RedTaxi F1 Rookie
    3,339
    New Zealand
    Glen
  14. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    best to avoid having the oil up to the full mark, about half way is ideal.
  15. F131 one of one
    F131 one of one Karting
    Oct 12, 2019
    119
    Netherlands, Europe
    Taco Vonk
    I had the same issue with my 430. After a long { fast } ride there was a burned oil smell. Turned out to be a minor leak on the cranck bearing.
  16. V1ROT8
    V1ROT8 Rookie
    May 4, 2020
    12
    Tucson, AZ
    Thanks for all the suggestions! I think I’ll start with the valve covers. After a quick look, I do see some oil/greasy residue in that area on both sides.
  17. hessank
    hessank Formula 3
    1,929
    Canada, Florida
    Fred
  18. V1ROT8
    V1ROT8 Rookie
    May 4, 2020
    12
    Tucson, AZ
    Interesting, thanks for the link.
