Is it OK to mix tire speed ratings? | FerrariChat
Discussion in '308/328' started by Scottc, Mar 31, 2006.
  1. Scottc
    Scottc Karting
    Jan 15, 2006
    81
    New York, NY
    Scott Coverley
    I am thinking of going with Goodyear Eagle F1 GS-D3 with my new 16" wheels. As it turns out, the front tires are only available with a "W" speed rating while the rears are available in either "Z" or "Y". As long as I am not going to exceed the lowest rated speed and I stay with the same tire design is it OK to mix the ratings?
  2. Bronco Jr
    Bronco Jr Guest
    Its not just the rating that changes its the construction of the tyre.
    In my experiance its never good to have mixed tyres on a car that handles...
    Go for a tyre where the same spec can be fitted front and rear,
    Just my opinion of course !
  3. ArtS
    ArtS F1 World Champ Owner Silver Subscribed
    Nov 11, 2003
    13,458
    Central NJ
    If this was a Ford Taurus, maybe. Sportscar/performance car - never.
    Art S.
  4. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    Anyone see the review of an old MG (or Morgan?) in either R/T or C/D a few months back? The car had 4 DIFFERENT tires!!! The article was hilarious.
    My two cents is have the same tires at least at the same ends.
    Ken
  5. MJT328GTS
    MJT328GTS Formula Junior
    Mar 30, 2005
    374
    St. Louis
    MJT
    You are correct in that you can mix them so long as you stay below the minmum speed rating. Too bad your fronts don't come in Z rating.
  6. Lemke
    Lemke F1 Rookie
    Oct 27, 2004
    4,644
    Vancouver, WA
    Daniel
    That was last months issue. It was pretty funny.
  7. Glen_Lloyd
    Glen_Lloyd Formula Junior Owner
    Dec 13, 2003
    785
    Lloydminster AB
    Glen
    I have that combination on my 328 you can't exceed the w rating in a stock 328 so it is ok. The tires are Z rated on sidewall and subrated W and Y.... they are designed with same tread and will work fine together
  8. EC308
    EC308 Formula 3
    Aug 28, 2005
    1,146
    jenkintown, pa
    ed
    they will work fine. The car will never do above 168mph w rating and the tread pattern will be the same so braking and handling should be fine.
