Is it OK to remove Axle bolts while in 1st gear? | FerrariChat
Discussion in 'Technical Q&A' started by Helmut, Jan 13, 2005.
  1. Helmut
    Helmut Formula Junior
    Dec 11, 2004
    640
    This may be another silly question but I am a novice to all this and I want to confirm with you guys.
    I removed both rear axles on my 78 308. the first several bolts I removed by shifting it into 1st gear to keep the axles from turning, can that harm the gearbox/differential?
    I finally figured out the screwdriver in the venthole of the discs method.
    Thanks for all the great advice,
    Helmut
  2. robertgarven
    robertgarven F1 Veteran
    Feb 24, 2002
    5,322
    Ventura, California
    Robert Garven
    I am not an expert but I was told to put the parking brake on and put in neutral, it worked for me. I would not worry, just enjoy!
  3. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,192
    Kingsport, TN
    Lawrence A. Coppari
    I suspect it won't hurt it. Think of it this way. Which puts more force on the gears - you with a wrench or dumping the clutch with the motor revved up. Granted these cars are not made for repeated burnouts but they can handle a little of it. You with a wrench don't come close to the forces generated that a burnout does. Emergency brake helps too.
  4. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Helmut,
    We're happy to help you, but please keep all posts related to a topic/project under one thread. This will make it much easier for future readers to find what they're searching for.
  5. Helmut
    Dec 11, 2004
    640
    Verrell, I agree, it is much easier to look things up in the archives when threads are kept together.
  6. Helmut
    Dec 11, 2004
    640
    That was my logic behind it as well; there certainly ain't 200 + hp in my muscles :)
    I saw nobody mention that putting it in first gear can also help which fueled my perfectionist paranoia. " May be I did somehting wrong".
    Thanks for the reply,
    Helmut
