Is it possible to damage the clutch during an engine out service? | FerrariChat
Discussion in '348/355' started by DavidLMcAfee, Oct 7, 2016.
  1. DavidLMcAfee
    DavidLMcAfee Formula Junior
    Nov 22, 2015
    355
    East TN
    David McAfee
    In July, I had a local shop do my engine out service. After I got the car back, I noticed an odd noise. It sounded like a wheel bearing, but I wasn't sure. The noise only happened when the engine was under load. Push in the clutch pedal and it went away.
    So I took the car back to the shop last month, and the guy is telling me the clutch plates are worn and need to be replaced. He also says I might need a new flywheel.
    Now, this problem came up immediately after they did the engine out service. It was not making any odd noises prior to having that done. So I'm wondering if it's possible to mess up a clutch during an engine out service. As far as I know, they took the engine/transmission/axel, etc out as a single unit and never separated them, so it seems unlikely, but I figured I'd ask, anyway.
    Edit: This is on a 1990 348ts with 66,000 miles, and it's the original clutch.
  2. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    With 66k on the original clutch this is most likely just coincidental. I can't think of any way a standard major service would affect the clutch.
  3. johnk...
    johnk... F1 World Champ Owner
    Jun 11, 2004
    11,270
    CT
    John Kreskovsky
    Hard to damage the clutch unless you unnecessarily take it apart to "inspect" it during the service. Apparently some shops do that.
  4. c7matt
    c7matt Formula Junior
    Mar 3, 2016
    338
    Greater Detroit, MI
    I agree. Only clutch issue I would expect after a major is if they had an issue bleeding the clutch.
  5. DavidLMcAfee
    Nov 22, 2015
    355
    East TN
    David McAfee
    That's what I was thinking, too. Just figured I'd ask. Thanks guys.
  6. AceMaster
    Feb 6, 2009
    34,778
    Ontario, Canada
    I was going to post this as well.
    I think it's just a coincidence.
  7. m.stojanovic
    m.stojanovic F1 Rookie Silver Subscribed
    Dec 22, 2011
    3,289
    Serbia - Niš
    Miroljub Stojanovic
    Do you mean "the noise only happened when the clutch is engaged" (pedal up) and it disappears when you disengage the clutch (press the pedal)? Or do you mean the noise is present when accelerating ("under load") and it disappears when decelerating?
    Worn clutch plates will not make the kind of sound you described (bearing sound). Depending on your answer to my question above, it could be the clutch release bearing or a bearing in the transmission.
    With 66,000 miles done, I would replace the clutch discs anyway. The rest of the clutch assembly needs to be inspected/measured before deciding on replacement.
  8. DavidLMcAfee
    Nov 22, 2015
    355
    East TN
    David McAfee
    The noise disappears when you press the clutch pedal. It is prominent during acceleration but also present at speed, and was getting louder. At highway speeds it was a high pitched whine. I say "was" because I heard that sound and immediately took it to the shop.
    The mechanic has taken the clutch apart and says the discs need to be replaced. He has also pulled the flywheel and sent it to a machine shop to have it measured in hopes that it can be salvaged. On the order list at present is a clutch rebuild kit from Ricambi. We are waiting to see what happens with the flywheel before proceeding.
  9. johnk...
    Jun 11, 2004
    11,270
    CT
    John Kreskovsky
    This.
  10. AceMaster
    Feb 6, 2009
    34,778
    Ontario, Canada
    Can you post pics of the worn discs?
    Also, pray that the flywheel is salvageable (pray for your wallet, that is)
  11. DavidLMcAfee
    Nov 22, 2015
    355
    East TN
    David McAfee
    I don't have any pics. And I just got word that the flywheel is not salvageable. I've been pricing them already. My wallet is already in tears.
  12. yelcab
    yelcab F1 World Champ Consultant
    Nov 29, 2001
    13,629
    San Carlos, CA
    Mitchell Le
    Ouch !!!
    It is not the shop's fault by the way. This happens !!!
  13. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    If you have a dual disc clutch you may want to consider converting to single disc at this point.
    Someone here (pretty sure plugzit) often has rebuilt clutch parts at a good price.
    Let us know what you find. I suspect you're going to need to rebuild the clutch and then drive it in order to determine if there are any other trans problems.
  14. andrew911
    andrew911 F1 Rookie Silver Subscribed
    Sep 8, 2003
    2,894
    Northern NJ
    On a positive point, I think you will have a noticeable improvement in clutch feel when the job is completed (easier effort, better grip and smoother operation) so at least after this you will have a better driving experience (unlike preventative maintenance, where you don't notice anything after picking up the car, just pay a bill :) )
  15. ClydeM
    ClydeM F1 World Champ Owner Rossa Subscribed
    Nov 4, 2003
    12,030
    Wayne, NJ
    Clyde E. McMurdy
    when your in there jostling things around, things shift and poo happens.
    It would have been nice had they checked the clutch & replaced it (if necessary) while the engine was out. Oh well.
  16. Jh348
    Jh348 Karting
    Sep 5, 2015
    187
    Finland
    Jesse Heinola
    I'm curious what is the difference in everyday use between these clutches? and why it seems that single plate is better?
  17. yelcab
    Nov 29, 2001
    13,629
    San Carlos, CA
    Mitchell Le
    There is that old conflict between doing what is just necessary to save cost, and doing what else is nice to do and add costs. You pay for what you get, normally.
  18. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    IIRC parts for double plate clutches are difficult to find and quite a bit more expensive. The double plate clutches are more difficult to set up properly (there is a theory that Maranello switched to single plate clutches for that reason). Pedal effort is supposedly lighter on a single plate setup-- I know my single plate car doesn't require as much pedal effort as I'm used to in older Ferraris but I have not driven them back-to-back to know for certain.
    In theory the double plate clutch is superior in power handling and it should last longer too. But if you're beating your head against a wall trying to find parts it's worth at least checking for single plate conversion, especially if you need a new flywheel.
    No matter what happens, save the old parts! If you don't want 'em I'll take them. :)
  19. Jh348
    Jh348 Karting
    Sep 5, 2015
    187
    Finland
    Jesse Heinola
    yeah, theres a double plate on my car and while clutches obviously are wearing component so dunno what happens when they wear out. definitely theres no need for double plate for those torque levels :D
    so if operation is superior i think i would change, even if i could find new discs and re-surface the flywheel
  20. PAP 348
    PAP 348 Ten Time F1 World Champ Lifetime Rossa Owner
    Dec 10, 2005
    100,224
    Mount Isa, Australia
    Pap
    +348
  21. DavidLMcAfee
    Nov 22, 2015
    355
    East TN
    David McAfee
    Thanks for all the help guys. I figured the garage was not at fault, but just wanted to make sure.
    I may try to tackle this job myself. Anyone know of a good resource for doing so? Preferably something with detailed pictures?
  22. AceMaster
    Feb 6, 2009
    34,778
    Ontario, Canada
    There are two very good threads.
    I am away for a few days, if nobody posts the link to one of them I can do it when I get back.
  23. emac
    emac Formula Junior Silver Subscribed
    Sep 14, 2014
    851
    upstate SC
    ernest
  24. DavidLMcAfee
    Nov 22, 2015
    355
    East TN
    David McAfee
  25. AceMaster
    Feb 6, 2009
    34,778
    Ontario, Canada
