Is it possible to fix broken bearing on jack? | FerrariChat
Discussion in 'Technical Q&A' started by peterp, Nov 19, 2005.
  1. peterp
    peterp F1 Veteran
    Aug 31, 2002
    6,699
    NJ
    Peter
    #1 peterp, Nov 19, 2005
    A bearing broke on the jack (Mondial 3.2) -- has anybody else encountered this problem and is it possible to get a replacement bearing. Picture is below
  2. PWehmer
    PWehmer Formula 3
    Oct 15, 2002
    1,733
    Surrounded by Water
    Can you take it apart and get the dimensions of the bearing?
  3. quartermaster
    quartermaster Formula 3
    Sep 11, 2005
    1,826
    Try a machine shop, auto or otherwise. I'd bet they can fix the thing affordably.
    How'd it break? Jacking the car?
    Keith
  4. Dubai Vol
    Dubai Vol Formula 3
    Aug 12, 2005
    1,418
    back in Dubai
    Scot Danner
    +1
    Of course I have to ask: is this jack really all that special, apart from being the "original factory jack?" Would a replacement scissors jack from Pep Boys or whatever do the job? If so, keep the broken original one for the next owner and carry a new one to use yourself, maybe?
  5. peterp
    peterp F1 Veteran
    Aug 31, 2002
    6,699
    NJ
    Peter
    Thanks for the input. It didn't break suddenly, but just was getting more and more difficult to turn, then I noticed ball bearings falling out on the floor which I thought was probably not a very good sign. I will try taking it apart to see if the bearing can be matched. It has a "double nut" on the end of the jack -- I will try to break that loose. I would like to fix the original jack if possible rather than replace it because I am a nut about originality.
