Is Loctite Green 290 appropriate for use on the head studs on a 246GT (Iron) Block | FerrariChat
Discussion in 'Technical Q&A' started by 72Dino246GT(Eur), Nov 29, 2010.
  1. 72Dino246GT(Eur)
    72Dino246GT(Eur) Rookie
    Dec 1, 2005
    34
    SFO Bay Area
    Peter Hollyer
    Is Loctite Green 290 appropriate for use on the head studs that are installed in the holes that open into the water jacket of an (iron) 246GT engine block?
    If not; what is recommended?
    From Loctite Threadlocker 290 overview:
    Recommended For use on metal fasteners 1/12" (2.2 mm) to 1/2" (12.7 mm) in diameter such as pre-assembled fasteners, instrumentation crews, carburetors and electrical connectors
    From Loctite Threadlocker 290 Features:
    Benefit: Protects threads-Prevents rusting of threads
    Peter
  2. Rifledriver
    37,103
    I wouldn't use Locktite on head studs. Antisieze, not Locktite. If you had a seepage problem 518 or liquid teflon sealant would be better.
  3. SMOKDU
    SMOKDU Karting
    Aug 9, 2010
    116
    i would not use locktite or antiseize. torque them down to the specs they say. use oil or they sell some oil for this at Napa i think. you want a good torque reading.
  4. Rifledriver
    37,103
    He is not talking about installing the heads. He is installing the studs. I think.
  5. SMOKDU
    SMOKDU Karting
    Aug 9, 2010
    116
    i see. i installed the studs just by using the allen head size until tight.
  6. FerrariChallenged
    FerrariChallenged Karting
    Jan 14, 2009
    67
    A lot of different head stud manufactures like ARP for instance advise against using thread locker on studs. Instead they recommend using teflon paste if necessary to seal or help hold the studs in place. You can find teflon paste in the plumbing section of any hardware store, it will say "teflon paste thread sealer" on the bottle.
