Is my 1985 QV Mondial Cab supposed to have a cold start or not? | FerrariChat
Discussion in 'Technical Q&A' started by proteng, Oct 4, 2009.
  1. proteng
    proteng Rookie
    Sep 22, 2008
    17
    Sarasota, Florida
    My 1983 QV GTSi had the "cold start" where the engine revs high until a certain engine temp triggers it to relax to normal idle. My 1984 QV Mondial Coupe had the same thing.
    Just bought a 1985 Mondial QV Cab and it doesn't have the "cold start"...or it's so warm here in FL that maybe the system knows it's 'warm enough'? Any experts out there who know?
  2. 308GTS
    308GTS Formula 3
    Dec 27, 2001
    2,223
    TN
    Yes it has an auxilary air valve. When cold it should be at higher rpms when first started.
  3. proteng
    proteng Rookie
    Sep 22, 2008
    17
    Sarasota, Florida
    Thanks...that's what I thought. Hmmmmm. Now what? What part do I need to replace for the cold start to function?...is it called the 'auxilary air valve'?
  4. proteng
    proteng Rookie
    Sep 22, 2008
    17
    Sarasota, Florida
    Say, would a faulty aux air valve make the car run any different at normal operating temp?
    Anyone know? Thanks!
  5. Steve Magnusson
    26,834
    (Assuming these are both US verison F)
    Your '83 308QV had/has an AAV and a cold start air valve -- so the cold start-up RPM is very high.
    Your '85 Mondial QV only has an AAV -- so the cold start RPM will only be a little bit higher than the warm idle RPM.
  6. KKSBA
    KKSBA F1 World Champ
    15,300
    SBarbara-La Jolla CA
    KKSBA
    My US 1985 QV Cabriolet used to hit around 1500RPM for the cold start portion then settle down to about 900.
