Is my clutch on its way out? | FerrariChat
Discussion in '308/328' started by brook308, Sep 5, 2008.
  1. brook308
    brook308 Formula Junior
    Oct 19, 2007
    346
    SS Coast, Australia
    George
    Hi All,
    I think the cluch in my 308 GT4 is on its way out.
    I was doing 100Kph on a flat highway section in 5th when I decided to overtake.
    I left the car in fifth and floored the accel. The revs whent from 3K to 6K but the car didn't follow suit.
    I tries this again about 3 times and the clutch slipped each time.
    I didn't try it again for about 20 minutes and then I couldn't get it to slip again.
    The problemed seemed to disappear.
    Anyone out there had a similar issue?
    Ta
  2. eurogt4
    eurogt4 Karting
    Apr 15, 2006
    243
    Sacramento, CA
    check the clutch free play. If it is insufficient, it will slip. Once it is adjusted, if it still slips, replace
  3. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
  4. eurogt4
    eurogt4 Karting
    Apr 15, 2006
    243
    Sacramento, CA
    since the oil seal is on the engine side of the flywheel, if it leaked, the oil would coat the back of the flywheel and block, but not the clutch on the other side
  5. brook308
    Oct 19, 2007
    346
    SS Coast, Australia
    George
    Thanks Gents,
    Will check the freeplay.
    It's funny how the clutch was slipping consistantly then stopped. I took it for another run on the weekend and couldn't get it to slip.
    This is the first car out of about 30 that has a clutch problem so I've never had much experience when it comes to failed clutches.
    Cheers
    Geo
