Is removing window tint a DIY? | FerrariChat
Discussion in 'Technical Q&A' started by tomconte, Jun 6, 2010.
  1. tomconte
    tomconte Formula Junior
    May 15, 2010
    385
    Atlanta
    Tom Conte
    The prior owner of my F430 had the windows tinted and .... yuck, sorry for fans of tint, but it's just plain strange to do on a spider, IMHO.
    It looks like it's a film applied to the inside of the window. I'm wondering, is this a DIY kind of job to remove?
    Tom
  2. ttdang123
    ttdang123 Formula Junior
    Nov 28, 2009
    706
    North San Diego CA
    Tung
    #2 ttdang123, Jun 6, 2010
    Not hard as long as you take your time. I removed the tint on my Benz but not the Fcar since I do not have tint on my Fcar. You need:
    1) TINT-OFF from an autopart store
    2) Razor (homedepot)
    The removal was very simple - just follow the direction of the bottle. MAKE SURE you cover all the windows surrounding + do it in a garage to avoid wind-spray.
    When you remove the glue residue, keep your razor moving as one continuous stroke (either up or down) to avoid spreading the glue back on the glass - you will see what I meant.
    Good Luck
  3. Tom_C
    Tom_C Karting
    Feb 20, 2008
    233
    Raleigh area, NC
    Tom C
  4. BigTex
    79,406
    Houston, Texas
    Bubba
    Be VERY careful with ammonia around leather, however........
  5. DonJuan348
    DonJuan348 F1 Rookie
    Aug 5, 2008
    4,442
    Taxing Jersey
    razor blade, soapy water.
    pull it off slowly to minimize residue left on window. then use a squirt bottle and soak window with soapy water and use razor to take it off.
  6. dapper
    dapper Formula Junior
    Nov 10, 2003
    711
    Bristol, UK
    Dave
    #6 dapper, Jun 7, 2010
    I 'very carefully' used small amounts of ammonia in a VERY vented area. Tint peeled off in single huge sheets once started. Didn't take too long at all.
  7. tomconte
    May 15, 2010
    385
    Atlanta
    Tom Conte
    All great advice-- thanks!
  8. Alxlee
    Alxlee F1 Rookie
    Apr 8, 2002
    3,697
    Wilmington, DE
    Alex Lee
    If the rear window is tinted, be VERY careful around the defrost elements.
