Is the 328 (convex variant) wheel the same as Mondial t wheel? | FerrariChat
Discussion in '308/328' started by paulchua, Feb 27, 2019.
  1. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,594
    Menlo Park, CA
    Paul Chua
  2. nerofer
    nerofer F1 World Champ
    Mar 26, 2011
    12,085
    FRANCE
    Hi Paul,
    Answer: NO, they are not.
    The fronts rims of the "série 2" 328s (137079, after #76626) is exactly the same, including the 38,3 mm offset, as the 129791 front wheel of the "Mondial 3,2".
    These are absolutely interchangeable, which is no surprise as the front suspension of the "Mondial 3,2" and the "Série 2" 328s is interchangeable also (same triangles, or "A-Arms", etc...). However, just to distinguish themselves visually, the style of the dimension's markings on the rims: "Ferrari 7 X 16" is different, making these identifiable, but again: the two are fully interchangeable.
    BUT the 7 X 16 front rims from the "Mondial T" (Speedline 138857), despite looking identical to the others above, could not be substitued to any of the two above, as it has a different offset of 50,8 mm (vs 38,3mm)
    As for the rear wheels: no wheel can be substitued for any other, as the three have all different offsets:
    126949 for the "Mondial 3,2" (with tyres in inches, not TRX and mms): offset is 51 mm
    130905 for the 328 "serie 2": offset is 63 mm
    137087 for the "Mondial T": offset is 51,8 mm
    (although 126949 with 51 mm is really close to 137087 with 51,8 mm)
    Rgds
    djs308, VetroresinaNL and paulchua like this.
  3. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,594
    Menlo Park, CA
    Paul Chua
    Thank you so much sir for your time and detailed explanation. It is very much appreciated!
  4. hyenahf
    hyenahf F1 Rookie
    May 25, 2004
    2,603
    anyone looking for 328-mondial 16s wheels i have match set in storage
