Is the engine the same in the 355 & 360 | FerrariChat
Discussion in 'Technical Q&A' started by vref, Dec 24, 2003.
  1. vref
    vref Karting
    Dec 18, 2003
    214
    1 Hr North of Housto
    Jim
    Is the the same engine in the 355 & 360 or did they change something?
    If something was changed, what was it?
    Just curious.
  2. TeenwhoneedsaFerrari
    Dec 23, 2003
    90
    Greensboro, NC
    Blair Salter
    yes. it is a different engine.....size has gone up as well as horsepower and torque. These specs didnt change very much and i could not tell you every detail. Ferrari typically names their cars using some number from the engine......examples are the 355 and 360......3.5 litre V8 vs. 3.6 litre V8. 3550 cc vs 3600 cc. I believe that in between the two cars, the most changed aspect was the body(obviously). Things like the transmission and suspension were toyed with no doubt. The two cars push out specs that are VERY close together, including same top speed, maybe only a tenth of a second 0-60 difference. If i remember correct, the 355 uses a light alloy head and block, the 360 engine is completely aluminum i believe. No doubt there a far more changes than i can spit out. you can get all the information i would guess from the Ferrari website, or from a certified dealer. let me know if you have other questions i would be more than happy to do my fair share of research and what not. I love these cars and do not mind learning more about them!
  3. Gary(SF)
    Gary(SF) F1 Rookie
    Oct 13, 2003
    3,637
    Los Altos Hills, CA
    Gary B.
    The 355 is 3.5 liters, 380 hp, the 360 is 3.6 liters, 400 hp (or 395, depending on where you look).
    Gary
  4. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,742
    Depends upon what you mean. If you start at the raw castings, then yes, the F355 and F360 engines can be machined from the same raw castings {Block, heads}.
    However, all the internals are different {Crank, con rods, pistons, pins, valves, springs, cams, cam timing, headers, intake manifolds, air boxes, ECU, ducting}
    The basic state of tune is similar (109HP/litre).
  5. joeyy
    joeyy Karting
    Nov 11, 2003
    190
    long island
    joe
    they do sound different i dont know if its because of the exhaust or something els.
  6. Jerrari
    Jerrari F1 Veteran
    Jul 24, 2001
    5,469
    Michigan
    Jerry Wiersma
    355 comes from 3.5 litres/5 valves per cylinder.
  7. Dale
    Dale F1 Veteran
    Oct 7, 2003
    5,211
    uk
    Dale Juan
    spot on Mitch,it would have been far to expensive to cast a new engine,
    block,heads,so they just upped the cc bit of a re map new valve timing figures etc etc,they had a nice engine in the 355 so they kept it alive and the cost to them down,
    Dale.
  8. tbakowsky
    Sep 18, 2002
    20,038
    The Cold North
    Tom
    The Ferrari V8 engine has remained very cloase the the 308GT4 engine. The design of the engine itself,with the removable sleeves and the 180 degree crank etc has not changed. The only thing Ferrari has really done to the engine is cylinder heads and bore size. The casting of the block was redone with the 348 because of the mounting position in the car, and the way the trans sits. The cranks were also changed because of the clutch configuration. But the basic design has not changed since day one.
  9. ricrain
    ricrain Karting
    Nov 1, 2003
    213
    Dallas Area
    Ric
    And that ends with the 360 replacement...
  10. ricrain
    ricrain Karting
    Nov 1, 2003
    213
    Dallas Area
    Ric
    Both engines are from the same basic form: DOHC, billet-forged cranks, titanium connecting rods, 5-valves per cylinder, etc.
    The numbers are close on paper, but what the numbers don't say is the tremendous difference in the 360's power band. This is due to the use of variable exhaust timing and a trick intake system (dual length runners). The throttle response and low-end power are very different from the 355 to the 360.
