Is the F355 Right for Me? | FerrariChat
Discussion in '348/355' started by ADSA95, Nov 28, 2010.
  1. ADSA95
    ADSA95 Karting
    Nov 28, 2010
    50
    Bedford, NH
    #1 ADSA95, Nov 28, 2010
    I have always wanted a 355 Spider but am wondering if it is the right car for me. I have had a 911 Cab for years and have enjoyed it tremendously but have always wanted to go to the 355. My concern is after finding this forum and doing some investigating it sounds like the 355 needs a lot of maintenance. One of the great things I like about my 911 is the fact that it is very reliable with virtually no issues. I only put on 1,000 miles a year then it's back in the heated garage for the winter which is what I would do with the 355. A couple of questions I have before getting to fired up about buying one:
    1) Is there a difference in the car from 95-99 that I should consider?
    2) If I buy a car with all the major service done how dependable should I expect the car to be?
    3) How much ongoing maintenance should I expect with the milage I would be putting on the car?
    The one thing I want to avoid is having to constantly chase after mechanical gremlins. I love the 355, I am just hoping that a properly maintained one is relatively trouble free....
    Thanks in advance for your help,
    AL
  2. James-NZ
    James-NZ F1 Veteran
    Jun 26, 2007
    5,822
    Hamilton, NewZealand
    James
    First things first, are you passionate about Ferrari's? If yes, then you will be able to look past the overpriced parts and realise this level of enjoyment and passion comes at a cost. If that doesn't scare you away keep reading...
    If you go to any Internet forum and look through the recent posts there will be a large percentage of posts regarding problems, weather its cars, fish tanks, boats etc. The reason for this is the Internet is a great resource for help with any little issues.. or large issues. Another thing at play is Internet experts, they like to repeat what they hear and have no first hand experence with the issue, other than reading it on the Internet, needless to say this can drive rarely seen issues way out of proportion.
    So, some first hand experence. I have owned 2 355s, my current 355 for a few weeks shy of 3 years, in that time I have done 2 annual services and most recently a major engine out service, I have done 1 set of tyres and I am about to pull the trigger on another set shortly. Out side regular maintence the car has been great, a small water leak from the heater core (not a common issue and not so expensive to correct. I have had the headers replaced, common on 355's, prices depend on how you proceed with the fix, repair is cost effective and seems to last well, this is what I did, or replacing the hearers is more expensive but aftermarket manufacturers give good warranties on these, most cars have had these sorted by now but pays to check. My car has been great, the maintence is in line with what I was expecting, I use the car very regularly and try to get the most I can out of it, I worked out that for me, living in New Zealand the cost is around $1 per KM I travel, reasonably expensive when coming from Porsche land but fairly good considering the car and the enjoyment.
    Still reading?
    GET A PPI will be something you hear a lot, important to get this done by a workshop familiar with the 355 and I would ask if you can be there to watch it being done, this is not to make sure they do the work correctly but more so you can see first-hand any issues (if there are any) and you can get a feel for what she is like under the skin.
    Find a nice example you are happy with, make sure its records show good history and service, get it PPI'ed, agree on a reasonable price, buy it and drive it. Reflect on why you haven't done it sooner.
    Hope that helps.
  3. 3forty8
    3forty8 F1 Rookie
    Apr 25, 2006
    2,713
    San Diego
    Eric
    Even a well sorted used 355 can be a lot of drama. If your above statement is very important to you, you may not find that a 355 is right for you.
  4. ADSA95
    ADSA95 Karting
    Nov 28, 2010
    50
    Bedford, NH
    Thanks for the responses. The maintenance is a concern, however I keep coming back to the fact that I have always wanted a 355(more specifically a red spider with tan interior, 6 speed with Capristo exhaust.) I would hope that if I was to either pick up a well sorted car or buy one for less money that needs a bunch of major maintenance I would be able to get some trouble free years of driving(of course regular maintenance is a must) but at around 1,000-2,000 miles a year I would hope that I would be able to just get in it and turn the key and go...
  5. Rob'Z
    Rob'Z Formula 3
    Mar 29, 2008
    1,024
    Tucson,AZ
    Robert
    Do you turn your own wrenches? That will have a huge impact on your $/mile ratio.
    Rob
  6. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    I've had my 99 355 from new. Had one actuator go out when still in warranty, another one about eight years later which I repaired my self. Did my own major, and basically just start it and drive. It has never let me down once and I've never seen a check engine light.
  7. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,741
    A Ferrari is like a beautiful redhead in a black silk coctail dress with her hair on fire.
    You have to Drive them more than a couple of times a month. The more you drive them the less tempramental they are.
  8. Frari
    Frari Formula 3
    Nov 5, 2003
    1,194
    brisbane australia
    tony
    I had a 355 gts for 3.5 yrs and had similar experience to James-nz. Did the usual servicing replaced a small ecu , did the clutch (it was a manual not an fi) mine was a 98 gts. I had the best drives in her particularly in the snowy mountains in spring. She never let me down and the engine was superb. I owned a 930 turbo 3.3 1978.for 6 years prior and they were like cheese and chalk. I could never go back to a porsche, the driving position in the ferraris is totally different, the sound of the engine at 90% revs is awesome and the handling superb. IMO buy a good one that has been driven and looked after, do the best PPI you can buy and then drive it like a test pilot.
  9. ferrari 512 tr
    ferrari 512 tr F1 Rookie
    Nov 16, 2008
    4,180
    Australia
    Paolo
    who cares about maintenance when you own the most hottest,
    best sounding, most beautiful car ever in the history of life: a 355
  10. James-NZ
    James-NZ F1 Veteran
    Jun 26, 2007
    5,822
    James
    No.
    Such.
    Thing.
    As.
    A.
    Cheap.
    Ferrari.
  11. Sandy Eggo
    Sandy Eggo F1 Rookie
    3,636
    Encinitas, CA
    Rick
    When you were 9 years old did you want to be a surgeon or a matador?
    If you thought "Gosh, a surgeon" then stick with P cars.
    If the thought of, on occasion, getting a horn through the buttocks would be worth the adrenaline rush of mastering that bull - then welcome to Ferrari ownership.
  12. rbellezza
    rbellezza F1 Rookie
    Jun 18, 2008
    2,793
    Henderson, NV
    Roberto Bellezza
    True !
  13. FerrariDeeJay
    FerrariDeeJay Formula Junior
    Jun 2, 2009
    418
    Chino, CA
    Michael
    #13 FerrariDeeJay, Nov 29, 2010
    I bought my 1995 355 Spider 3 years ago before the recession and paid $90K. My car only had 10,000 miles on it and had just had an $11k engine out service performed at Ferrari of Orange County. With the recession you can now buy a 355 for $50-60K. Even if you had to spend $20k to make it perfect, you would still be a Ferrari owner with a great car for less than the price of a 7 series BMW. Remember that this is a handmade car with an engine that comes from the most successful Formula 1 race team in history. Not some mass produced car that EVERYBODY drives. You will turn heads in this car. You will experience an engine that howls and screams like no other when you take it to the redline near 8500RPM. Strangers will stop and take pictures with your car and even film you with their iPhones when you stop at a red light.
    This car is expensive to maintain, but honestly, I wake up every morning, start her up and all of a sudden I am smiling ear to ear like a fat kid with ice cream...priceless!
  14. BarrieM5
    BarrieM5 Karting
    Jul 8, 2009
    74
    Kelowna, BC , Canada
    #14 BarrieM5, Nov 29, 2010
    A year and a half ago, I read almost every thread on FChat about the 355 as I wanted one "bad" ...but was hesitant due to the supposed maintenance costs. I found a beautifully maintained 1999 F1 Spider from a fellow FChatter ( thank you SKIPPER) for $60 k and have had zero problems or maintenance over the past year ! The car is a blast to drive....the engine sounds amazing...the car handles like a go cart...everyone you pass gives you the thumbs up....and the car is simply beautiful to look at !! What more can you want ? When I spoke with owners who have had both the Porsche Turbo and the 355....they said to a man....the Porsche is nice....but it's not a Ferrari !
    Take your time.....find a very well taken care of 355 Spyder ...and enjoy the hell out of it !!
    It's what they were made for !
  15. ADSA95
    ADSA95 Karting
    Nov 28, 2010
    50
    Bedford, NH
    Thanks for all your responses. Even though I had already made up my mind somewhat, your encouragement is helpful..... Since you only live once...Looks like I will be putting the 911 up for sale in the spring and begin looking for my 355 spider.....
  16. Coolhand
    Coolhand Karting
    Mar 30, 2007
    193
    Overland Park Kansas
    "There is a price for glory.... and it is high." -Brock Yates
  17. J. Salmon
    J. Salmon F1 Rookie
    4,367
    VA
    I am on my second. The first I got rid of because of FEAR of an issue, when really there wasn't one.
    I bought the second when I realized I just didn't care, it was worth it.
  18. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,608
    Gates Mills, Ohio
    Jon
    Having owned both Porsche and Ferrari, I'd say you need to view an old Italian car as an ongoing project. The 355 Spider, especially with an F1 gearbox and its intricate motorized top with seat sensors/motors, is a pretty complicated car. Even if it was Japanese, it might break occasionally.
    You have to love it enough to keep on top of things, maintain it fanatically, and be prepared for a five-figure shop bill when Something Really Bad happens.
    That's a good perspective. You can spend $70K tomorrow and end up with a boring grey German sedan that everyone else has, so at $50K a 355 is a more inspired purchase.
    With respect to "handmade": Ferrari robotized the assembly line by early '90s, and machine-stamped the panels. I think the seat covers and dash were hand-stitched after being laser cut, but if you surf the vintage forum here you'll see that "handmade" is a relative term. The Ferrari line back in the Boxer/308 and earlier days was more like a workshop.
  19. AceMaster
    Feb 6, 2009
    34,782
    Ontario, Canada
    If maintenance is a concern, then this is not the car for you.
  20. FullChat
    FullChat Formula Junior
    Jan 1, 2007
    339
    San Antonio, Texas
    +355
  21. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    The question should read; 'Am I right for the F355?' ........ ;) ............... It depends on what is important to you, if getting around and looking good is important, then ... no ..... get another car.
    If you do not care what others think and visceral enlightenment ranks magnitudes higher than simple expenditures .............. then you may be a candidate ................ :eek:
    IMO the 355 is a multi-dimensional work of art .......... it needs space ........ fanatical regard ............... and a conscientious hand ............ the 355 is certainly not for everyone ............ but for those keen to its virtues ........... there is no question ...... the F355 is quite simply ......... AWESOME!!!!! :cool:
  22. AceMaster
    Feb 6, 2009
    34,782
    Ontario, Canada
    Stop right there ;)
  23. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Agreed ......... :D!
  24. Rob'Z
    Rob'Z Formula 3
    Mar 29, 2008
    1,024
    Tucson,AZ
    Robert
    Summed it up perfectly!
    Long time no see Goth, welcome back.
    Rob
  25. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Cool thanks ... :)!!!
