Is the F430 very low in the front? | FerrariChat
Discussion in '360/430' started by Perre, Aug 17, 2008.
  1. Perre
    Perre Rookie
    Apr 5, 2008
    14
    Uppsala, Sweden
    Hi,
    A short question for you F430 owners: Do you feel your F430 is very low in the front? I assume the car doesn't have the lifting system that the Lambos have, but are you missing a lifting system because you scratch your front sometimes if you're not careful?
    Best regards
    /Per
  2. Bluehinder
    Bluehinder Formula Junior
    Aug 9, 2005
    889
    Colorado
    Yeah it's low. I dinged the bottom of the front bumper the first time I took it out the driveway. Red paint all over the cement. Now I use ramps to get out. I'm having the bottom of the driveway cut and repoured.
    It's not expensive to repaint the bumper, around $800 I'm told.
    Don't worry about it, it's part of the car. You'll find ways to get around it, and be careful when needed.
  3. Dsl42581
    Dsl42581 Karting
    Oct 9, 2006
    76
    Jupiter, Florida
    David Lichtman
    It is low. I normally have not had a problem, but did hit it once going into a gated community, luckily the scratches were only visible under the car.
  4. Perre
    Perre Rookie
    Apr 5, 2008
    14
    Uppsala, Sweden
    Ok, thank you guys. I assume it's the same as with the Porsche 997 Turbo, some planning where you take the car and you'll be fine most of the time. :)
    Regards
    /Per
  5. Testacojones
    Testacojones F1 Veteran
    Nov 3, 2003
    5,198
    Florida
    Luix Lecusay
    For me living in Orlando Fl. I find the car not low at all, the other way around, I find it an inch too tall.
  6. reubenk
    reubenk Formula Junior
    Mar 5, 2004
    333
    atlanta burbs
    reuben k
    it's not nearly as low in the front as the lambos or an F355. I have yet to scrape mine in atlanta in about 3500 miles of use. I too was considering lowering mine.
    ...but, as I understand it, the US version is higher than the euro-spec.
