is there a difference in the F1 gearboxes of | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by ross, Feb 9, 2021.
  1. ross
    ross Three Time F1 World Champ
    Mar 25, 2002
    38,203
    houston/geneva
    Ross
    the 2005 575, or the 2005 612, or the 2005 430?
    and did the gearboxes in the 612 and 430 change as the model run continued?
  2. tres55
    tres55 F1 Rookie
    3,573
    Canada
    I believe the later 612's had the updated transmission from the 599 dubbed the "SF" transmission (SuperFast).
    I don't think there is anything significantly different for the 575 but that would be probably be better answered by @tazandjan
    No clue on the F430...but safe to assume the Scuderia had material improvements.
  3. CoreyNJ
    CoreyNJ F1 Rookie
    2,561
    New Jersey Shore
    lots of updates in 2008 for the 430 F1, not all 2008 have the updates it sort of happened mid production year.
  4. tazandjan
    39,392
    The HGTC 575M (late CY04/CY05) had updated software that pretty much mimicked the F1A system (180 ms min shift time) in the Superamerica and early 612, without the F1 selector that let you go to 1st. The 612 Sessanta and the 612 OTO both had 599 F1 Superfast I software (100 ms min shift time). All 612 F1 models software was updated in the CY07 timeframe to lower shift times to ~ 125 ms, about the same as late F430s.
    tfazio, V4NG0 and LARRYH like this.
  5. CoreyNJ
    CoreyNJ F1 Rookie
    2,561
    New Jersey Shore
    It should be more than software for the 612 to match the late F430. There were hardware changes on the late 430 side to get the lower shift times and the reduced clutch wear.
  6. tazandjan
    39,392
    The gearbox on the V12s is much tougher than that on the V8s. Not sure if any hardware changes were necessary. Even with Superfast 1 on the OTO 612s, the 599 gearbox case was used to match with the twin disc clutch, but 612 gears were used inside. Many 575M and later (612, 599) gearbox parts were shared with the Enzo.
    rynoshark and paulchua like this.
  7. LARRYH
    LARRYH F1 Veteran
    9,720
    virginia usa
    This sounds right the next improvement came with the super fast 2.. 60ms.... in the 430 Scuderia and the 599 GTO don't think it was used in anything else which is to bad cause it is a very fast solid mechanical shift ....
  8. tazandjan
    39,392
    Larry- Affirmative, Superfast II was only used on the Scuderia/16M and 599 GTO. Ferrari had already fielded the first DCTs by the time the GTO came out, so the handwriting was on the wall. An interim step for the V12s was the 599 HGTE, which had 85 ms min shift times.
    Nicky_Santoro and Texas Forever like this.
  9. ross
    Mar 25, 2002
    38,203
    houston/geneva
    Ross
    ok......
    but for model year 2005, all 3 of these cars had the same magnetti marelli F1 system?
    correct or not?
  10. brogenville
    brogenville Formula 3
    2,329
    Robin
    I think that’s correct. My 2005 612 used a CFC231, but 2006 612’s and all 599’s from what I can tell use CFC301 ecu’s.
  11. ross
    Mar 25, 2002
    38,203
    houston/geneva
    Ross
    are these ecu's interchangeable?
    i am guessing the actual hardware is the same, and the ecu just makes the gear changes faster?
  12. tstuli
    tstuli Formula Junior
    Jun 12, 2018
    380
    NC
    Theres other hardware changes too. Notably there's additional sensors like clutch pressure, and acceleration depending on the version.
    Sent from my SM-A515W using Tapatalk
  13. brogenville
    2,329
    Robin
    According to this documentation from Graziano, 612 and 575 'boxes use a few different ratios too.
    My understanding is that the 575 boxes onwards used triple cone syncro's on (I think) 1st and 2nd, so were an upgrade over 550's.
  14. tazandjan
    39,392
    Robin- Affirmative, 575M gearboxes were toughened significantly from the 550 for F1, including triple synchronizers (two synchro rings and a steel dog clutch) for the lower gears. Contemporary F1 systems used the same ECUs, but with different algorithms for individual models. Some F1 hardware was interchangeable, some not. Have to go through the parts catalogs to see the differences.
