Is there a special tool required for removing steering wheel? | FerrariChat
Discussion in '308/328' started by wolfturbo, Jul 25, 2015.
  1. wolfturbo
    wolfturbo Formula Junior
    Nov 7, 2005
    580
    So. Cal
    Rob W.
    Guys,
    I wanted to remove my steering wheel to see if I am missing a turn signal cancellation ring.
    I popped out the horn button and expected to see a large hex nut holding the wheel onto the spline. Instead there was this round round retaining nut with grooves cut into it every 90 degrees. You can see in the attached pic if you look really close.
    Is there a special tool that I need in order to remove this nut?
    Thanks to all!
  2. Ricambi America
    Ricambi America F1 World Champ Sponsor Owner
    Dec 7, 2003
    16,478
    Winston Salem, NC
    Yes. You'l need a 38mm ring nut tool.
  3. Jdubbya
    Jdubbya The $10 Trillion Man Silver Subscribed
    Dec 28, 2003
    43,727
    Hell's waiting room
    And yes the cancelling ring sometimes breaks. Not sure if original parts are available but I think Verell was making them.
  4. wolfturbo
    Nov 7, 2005
    580
    So. Cal
    Rob W.
    Thx Daniel. Order will be placed tonight.
  5. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Just to clarify. The steering wheel comes off by removing the hex screws. The steering wheel hub is removed with the above mentioned tool but you will need a puller to get it off without damaging anything. At least in my experience.
  6. monza75
    monza75 Formula 3
    Apr 5, 2012
    1,343
    Melbourne, Australia
    Dan
    +1
    Definitely require a pulling tool.
  7. wolfturbo
    Nov 7, 2005
    580
    So. Cal
    Rob W.
    Got it. I've got a steering wheel pulling tool. It sounds like I need to get at my turn signal switch as that is where the cancellation ring resides.
  8. Verell
    Verell F1 Veteran Consultant Owner
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    It was never available as an individual part, just part of a complete column switch.
    Yes, I make them to order. Prices are:
    Ring, Turn cancel black body switch w/o brass horn commutator ring & contact wire: $ 47.00
    Transfer brass horn commutator ring & horn contact wire from your old turn cancel ring: $75.00
  9. Alfer
    Alfer Formula 3
    Sep 4, 2007
    1,360
    NH/the Netherlands
    Menno
  10. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,286
    Black Forest Germany
    Martin N.
    As well as on the clutch shaft, the main transmission shaft, the camdrive pulleys, the rear axle shafts and so on :)
    Best Regards
    Martin
  11. Verell
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    The ring nut is also known as a SKF nut. It was originally developed as a low profile nut that would retain the inner race of a bearing on a shaft end w/o protruding into the seal area & w/o requiring a lock washer.
    As to why it was used on the steering column, good question the older cars used a low profile nylock style hex nut there.
