Is there a Washer??? | FerrariChat
Discussion in '308/328' started by mwr4440, Aug 17, 2008.
  1. mwr4440
    58,021
    Bavaria, The 'Other' Germany
    Mark W.R.
    Is there a Washer that goes onto the oil sender on a 308???
    When it came out I did not notice one, BUT?! A few minutes later a washer fell out of the sky in the vacinity of the sender and in a size I cannot account for.
    Do not see one in the parts book I have, so I am asking the stupid question.
    mwr
  2. racespecferrari
    racespecferrari F1 Veteran
    Jan 31, 2006
    7,583
    Suffolk, Uk
    Pete.G By The Sea
    #2 racespecferrari, Aug 18, 2008
    I removed both oil sensors last week and yes there is one on both the temp and the pressure sensor.
    The washer is quite tight and doesn't look like it would fall off that easy.
    If its of any interest to anyone the oil temp is an M14 1.5 pitch and the oil pressure is M18 1.5 pitch.
    1st pic temp
    2nd pic pressure
  3. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    I replaced all three oil-related senders a couple of months ago.
    There's no washer on the temperature sender (this is the one that screws in to the front edge of the sump). It doesn't sound as if you have removed this one ... right?
    There is definitely a washer on the two senders that attaches to the oil filter housing. You don't even want to think about re-installing these without new washers. If you don't, you'll almost certainly get a small oil leak ... I speak from experience!
  4. racespecferrari
    Jan 31, 2006
    7,583
    Suffolk, Uk
    Pete.G By The Sea
    Sorry I got mixed up. The 1st pic is the warning light sender for the dash (fits the back of the oil filter housing).
    I just removed the temp sender from my sump and there wasn't a washer on it.
