Is there any alternatives to OEM engine mount and suspension bushings? | FerrariChat
Discussion in '360/430' started by ornas, Jun 14, 2025.
  1. ornas
    ornas Rookie
    33
    Hi, could you tell is there any alternative/upgraded suspension, engine, gearbox mount bushing options? Something like powerflex or elephant racing for porsche?
  2. WantaF430
    WantaF430 Karting
    170
    Fort Worth
    Joseph (Joe)
    There’s lots of info out there about hill engineering for suspension parts.
    As far as engine mounts, I’ve not personally seen any alternatives. Seems like something there would be a market for though. I think most people deem the f430 trans mount to be fine, and can be used in the 360 if I’ve read correctly.
  3. GogglesPisano
    GogglesPisano F1 Rookie
    3,205
    East Bay, California
    Joe
    Flat plane crank engines have a lot of vibrations. I’d be hesitant to use anything firmer than the OE rubber mounts. Likely why there isn’t an aftermarket alternative at this point since the stock mounts are decent quality and not expensive. Nobody would buy aftermarket rubber mounts at this price point and I don’t think many see a benefit in going with a poly bushing.
    jtn0514 and eric355 like this.
  4. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,618
    San Jose
    dc
    The enzo PN engine mounts were cheaper when I bought replacements. Not sure if true now since challenge headers went up like 10x
  5. anotherred360
    anotherred360 Formula Junior
    Jan 10, 2015
    278
    I contacted Vibra-technics before replacing mine, and while they don't currently offer 360 mounts they seemed interested in making them. Their engine mounts use a rubber core with aluminum surround that limits the deflection of the rubber to strike a middle ground between NHV and stiffness. I had them on my M3 and liked them. They make Lamborghini engine mounts that look fairly similar to the factory 360 ones.
