Is there anything CS owners crave? | FerrariChat
Discussion in '360/430' started by stradman, Apr 18, 2005.
  1. stradman
    stradman Formula 3
    Jan 8, 2004
    1,284
    London UK
    Stradman
    Don't get me wrong, I love my car, however the only thing I would love more of would be some more torque. It just feels a bit "thin" in it's power delivery. The engine on the the new 430 is the only thing/reason that would tempt me into buying a 430. Maybe I should transplant a 430 engine into the CS! The other option is that I can somehow knock another 150kg off the weight(Carbon fibre all the body panels!!!)
    Alex
  2. amenasce
    34,605
    Joe Mansion
    Or wait for a 430 CS :)
  3. jdcohenmd
    jdcohenmd Karting
    Nov 5, 2003
    80
    Carrera GT
  4. ben, lj
    ben, lj Formula Junior
    Aug 23, 2004
    594
    yep, that did it for me. while i loved the CS (sold two weeks ago), i nearly completely ceased driving it after the CGT arrived. it really ruined the CS for me which was held in very high esteem previously. most of the diff is the power the fact it has a real manual. the convertible part was nice too.
  5. Ducati
    Ducati Formula Junior
    Jan 23, 2004
    364
    So. Cal
    Joe
    I had an opportunity to drive a Stradale with the Eurotek ECU's and found alot more torque with that set up. I am still waiting to do it to my car but it definitely had a major impact. I'm sure I will get it done in the future. This car also had the Capristo Level 3.
  6. frefan
    frefan F1 Veteran
    Apr 21, 2004
    7,370
    More cylinders!
  7. ben, lj
    Aug 23, 2004
    594
    a friend of mine put high flow cats on his and picked up 30 rwhp and 50 lbs of torque! i'm fairly certain the ECU is planned for the not too distant future.
  8. WCH
    WCH F1 Veteran
    5,186
    Slicks.
  9. bumboola
    bumboola Formula Junior
    Mar 7, 2003
    625
    A 9500rpm redline and another gear, too big a gap between 1st and 2nd. More horsepower would be nice but if I want real speed I just hop on my 1000cc superbike, an automobile won't cut it.
  10. udalmia
    udalmia Guest
    more grunt above 80mph, the car's acceleration slows down beyond then
  11. W00dEar
    W00dEar F1 Rookie
    3,592
    LI, NY
    Chris
    i want the engine of F430, and sound of F355. the car itself is perfect.
  12. udalmia
    udalmia Guest
    NGT :D
  13. Cavallini
    Cavallini Formula 3
    Nov 2, 2003
    1,835
    Ben LJ, I'm sure you've answered this question before somewhere on this board, but how does the CGT's front end hold up on real roads? I'm considering one because it is such a superb, unique machine but I have reservations about using it without thinking about whether I'm going to bash the front end over every road imperfection.
    Many thanks,
    Cavallini
  14. ben, lj
    Aug 23, 2004
    594
    to give you an idea how mine is driven, it is currently at the dealer getting all four tires replaced as well as the front pads - at 2500 miles! as well, the typical fcar for sale description language of "never seen rain" does not apply to my car(s). with that preface, i'll tell you there was no damage whatsoever under the car despite all the "noise" when bottoming out from time to time. i think the $500 little plastic piece on the bottom of the front bumper (where the CS SHOULD have one) is making the noise while protecting the rest of the more important stuff - ie: carbon fiber.
    btw, why is cost of the pads for the ceramic brakes on the CGT a fraction of what ferrari gets for the CS's? the total production for both cars will be similar so the usual "limited production" BS rationale from ferrrari does not apply.
  15. Gary(SF)
    Gary(SF) F1 Rookie
    Oct 13, 2003
    3,637
    Los Altos Hills, CA
    Gary B.
    Good question. An even better one would address the cost of the Porsche PCCB pads, which I've heard are even higher than the CS, are they not?
    Gary
  16. ben, lj
    Aug 23, 2004
    594
    no, that's my point. porsche PCCB's ran me $325/wheel which i believe is considerably less than the CS's.
  17. Gary(SF)
    Gary(SF) F1 Rookie
    Oct 13, 2003
    3,637
    Los Altos Hills, CA
    Gary B.
    Interesting. I'd always heard the Porsche PCCB pads were more than CS pads. What are you CS guys paying for pads? How does the Porsche disc replacement cost compare to CS?
    Gary
  18. ben, lj
    Aug 23, 2004
    594
    discs for the CGT are $7k but that's more expensive that the GT3/2 which have smaller discs. if memory serves, the CSs are closer in size to the GT3/2s. also if memory serves, a front brake job on the enzo is $30k vs. $15K+ a couple hours labor on the CGT. same size ceramic brakes on those two.
  19. Cavallini
    Cavallini Formula 3
    Nov 2, 2003
    1,835
    Ben LJ, many thanks, that's what I wanted to hear- real life experience, not journalist speculation. And from the sound of your driving style, it seems the clutch has not been the fatal flaw many others have found it to be.
    Many thanks again,
    Cavallini
  20. marknkidz
    marknkidz Formula 3
    1,333
    so cal
    mark
    Ben LJ, what is the cost to replace pads on the CS? I mean after awhile i would assume only front pads would be needed as they would be used up sooner than backs. But Rotors should last an extremely long time, i would think? Im guessing the cost should be aroun 1k total for both fronts, am i not even close? IF NOT I MAY JUST START DOWN SHIFTING MORE!!!!
  21. Brian C. Stradale
    Brian C. Stradale F1 Rookie
    Mar 17, 2002
    3,615
    Dallas, TX, USA
    CS pads cost approx $500/wheel.
  22. ben, lj
    Aug 23, 2004
    594
    yep, i can't understand why the smaller CS ones are 50% more than the CGT ones. what kind of wear have you gotten out of yours?
  23. Gary(SF)
    Gary(SF) F1 Rookie
    Oct 13, 2003
    3,637
    Los Altos Hills, CA
    Gary B.
    Wow. That is remarkable.
    Gary
  24. scud
    scud F1 World Champ
    Oct 2, 2004
    11,803
    gears are for go
    brakes are for slow
    rock on
  25. ben, lj
    Aug 23, 2004
    594
    lol, yeah and that goes double on the CGT whose (ceramic) clutch is a ludicrous $25k installed vs. more like $4500 on the CS.
