Is this a record? | Page 4 | FerrariChat
Is this a record?
Discussion in '348/355' started by vdettore, Jul 14, 2017.
  1. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Maybe it's just me, but along with John's observations (which I fully agree with), I tend to judge a shop by the shop conditions. If a shop is a train wreck, it does not give me confidence in the care the work will receive. if you don't care about a tidy shop, do you really care about the work?
    And, I'd bet they had the cam covers powder coated which is not proper.
  2. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    Pretty obvious this shop never saw Fchat or they'd know how to drop the engine the right way.
    Fingers crossed for you and the car after this is over.
    Sent from my SM-G930P using Tapatalk
  3. ghardt
    ghardt Formula 3
    Apr 18, 2004
    1,260
    Texas
    Jerry
    The photos provide tremendous information to F-Chat members. The photos do show an inexperienced mechanic with F cars. On the positive side, you do have metal timing covers instead of fragile plastic seen in the later cars. It may be wise to have another (experienced) mechanic check the belt, tensioner bearings, and pads. Best of luck.
  4. fatbillybob
    Aug 10, 2002
    28,912
    socal
    Well...those were my initial thoughts too. But we still have not seen the final bill. Perhaps there was a main seal leak detected? Maybe engine mounts? Maybe the shop has no space to keep a car around for 4 months+ and no chassis wheels so bolts the subass on to roll the car around in the shop as space is needed? With a couple pics you can certainly suspect cluelessness but there could also be very valid reasons.
    Jokingly...LOL in 308's our big concern is smacking the back window during engine in and outs. See if you got a new back window. Maybe that's why it took 4 months sourcing a back window. We also don't know what the valve covers looked like before the service. So tough to blame on the shop until we know. OTOH maybe shop does read Fchat because... aren't Ernie's covers powder coated like that?
    I say don't worry. If the car runs well and does not leak all sins will be forgiven. It is pretty hard to screw up a 348 and if it is screwed up there are a 1000 Fchaters who can fix it. I bet any number of the Fchat braintrust could get the OP to do the major himself with harbor freight tools and Facetime!
  5. ghardt
    ghardt Formula 3
    Apr 18, 2004
    1,260
    Texas
    Jerry
    #80 ghardt, Aug 26, 2017
  6. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,214
    CT
    John Kreskovsky
    Yes, the pictures have me wondering if thy took all that stuff off the engine so they could pull it from the top. Looking at my 355 it certainly looks like a possibility.
    Have we just discovered another way to do an engine out without the need for a lift? Maybe they are smarter than they look?
  7. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    No. Much more work. We could start talking about gas tank removal majors again. These cars have been design to drop the engine out the bottom. It's the most efficient way.
  8. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,522
    San Carlos, CA
    Mitchell Le
    I would remove a zero from that 1000. I see 100, but 1000 Fchat who can drop a 348 engine is optimistic. During our normal Stooge gathering where 20-30 of us gearheads show up, I can see five that would take on an engine drop and full 348 service. Next time we should do a poll.
    And Harbor Freight tools? Do they even have a degree wheel?
  9. fatbillybob
    Aug 10, 2002
    28,912
    socal
    It is not so crazy of a concept if taken to it's logical conclusion. I know this 348 IMSA racecar where the sub assembly is welded to the chassis and the transmission cross support is cut and sleeved to be bolt in and out. The whole engine with gearbox can them be pulled from the top. Rear rollcage main hoop supports are welded back toward the shock towers. All this is done to stiffen the 348 wet noodle chassis and make it a better developed race car. There are seconds of lap time to be found in the chassis just by making the chassis stiff enough so that you can predict and allow the suspension to do what it is designed to do and negate the chassis itself as an unpredictable spring.
  10. fatbillybob
    Aug 10, 2002
    28,912
    socal
    Oh come on Mitchel. Fchat is like 40,000 strong. There are a lot of very capable wrenches on this forum. They challenge the pros all the time and the pros have mostly left. I still respect them but fixing cars as you and I both know is not rocket science.
    You or I could print a degree wheel on paper off the internet and glue it onto a piece of cardboard and get the job done!
  11. WATSON
    23,679
    WI
    It is not just you. The way a shop, in any industry, is kept tells a lot about the capabilities and expectations of the staff.
  12. Motob
    Motob Formula 3
    Nov 11, 2003
    2,365
    Frederick, Maryland
    Brian Brown
    After looking at the photos of the work that the shop has performed on your 348 it is obvious that whoever is doing the repair work has never done this service before and has no business in working on Ferraris.
    In addition to the incorrect method of engine removal for the service and the glossy red paint on the cam covers instead of red wrinkle finish, there are other incorrect repairs that indicate that they don't know what they are doing.
    The spark plug wires were originally routed along the tops of the cam covers, retained by plastic clips that are pressed into holes in the cam covers. This keeps them away from the heat coming off of the exhaust headers. The shop that did your service did not reinstall these clips (in fact you can see where they painted over the remains of one of the clip ends still in the hole in the cam cover), and they have routed the ignition wires directly over the heat of the exhaust headers.
    Originally Ferrari applied silicone sealant at the ends of the cam cover gaskets were they meet the end cap gaskets at the rear of the cylinder heads. A little bead of silicone will alway squeeze out when the covers are tightened up. Some mechanics just leave it there, I wipe it off smooth, but there will still be evidence of sealant. In the photo of the rear of the right cylinder head I can see that there was no sealant applied at all at these joints. This is going to be the source of oil leakage in the future.
    When I the lack of attention to detail in the little things like this, it makes me very suspicious regarding the really important things like correct valve clearances, cam timing, belt tension, etc.
    Unfortunately my gut feeling is that the car will probably run, but you are going to have problems related to the service in the future and will have to have part or all of it redone.
    Sorry for the bad news.
  13. vdettore
    vdettore Formula Junior
    Mar 3, 2017
    353
    Georgia Coast
    Vince
    #88 vdettore, Aug 26, 2017
    I've read everyone's post and thank you for the input and it is well received.
    What I'll have to sort through is the mechanic which has worked at another exotic shop that was also part of a F shop says the previous work was not done correctly including how the routing of the lines and wires.
    The crank seal was leaking as well as the timing belt pad was previously put on wrong which caused excessive wear on the timing belt. I looked and the last receipt for an engine out was at a Ferrari dealer.
    The mechanic addressed the sealant coming out of the cam covers when I first brought it in and said this should always be removed. He said he cleaned the sealant from around the covers ( I hope but will question).
    He also told me several vacuum hoses were run wrong and he can't believe a previous F Shop did the work. Maybe they did or maybe the previous owner did the work after.
    I have receipts of $39k since the car was new.
    I told the shop to paint my covers red and I actually like them.
    Bottom line is That the car should run as it was intended.
    Again, I am listening to everyone and appreciate you input.
  14. Nader
    Nader Formula Junior
    Feb 12, 2011
    990
    East of Seattle
    #89 Nader, Aug 26, 2017
    I did notice that your mechanic appears to be researching the Internet looking for answers. He might even stumble into this thread and have his feelings hurt!
  15. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    Kind of like going out to a place to eat which does not appear to be very clean. You're probably going to be less impressed (horrified?) if you visit the kitchen. I think another thing to look for is good/proper/sufficient lighting whether a kitchen, a garage or a machine shop. It's kind of a starting point for doing good work, good inspections and good cleaning.
  16. vdettore
    Mar 3, 2017
    353
    Georgia Coast
    Vince
    The picture doesn't do anything for the shop. It is pretty clean.
    He took a lot of pictures when taking it apart. proof will be in the final outcome.
  17. fatbillybob
    Aug 10, 2002
    28,912
    socal
    #92 fatbillybob, Aug 26, 2017
    I am not defending the shop nor do I know who the shop is but people are making a lot of assumptions and accusations based on a couple of snap shots.
    When I'm in the heat of battle ripping a car apart my shop is a mess and it's because I'm working hard. A shop is always eat off the floor spotless when they have no business or a guy who's job is just to clean the shop. Do you have to have a janitor to fix a car?
    And OMG! maybe paint and texture master DaveRocks can tell us an easily available "right" red paint but ME? I must be a terrible mechanic because I use wrinkle red VHT out of spray can!
  18. yelcab
    Nov 29, 2001
    13,522
    San Carlos, CA
    Mitchell Le
    So do I.
  19. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    #94 Dave rocks, Aug 26, 2017
    Sorry, but this is a well lite, clean shop :)
    A bit more full these days as this was when we first moved in ;)
  20. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    #95 Dave rocks, Aug 26, 2017
    An organized shop is an efficient shop. If you don't keep a tidy shop, you won't likely keep the customer car tidy either. Of course a work area will get a bit disturbed during work, but the rest of the shop should not look like a **** hole :)
    Sadly, in the US, the only option is VHT (that I've been able to find). VHT is a decent product, however, the color (red) just does not match the Ferrari red.
    I've brought some samples in from Europe a few months ago and just have not had time to try them yet..
  21. KMR968Turbo
    KMR968Turbo Formula 3
    Nov 11, 2007
    1,001
    Calgary, Alberta
    Erik
    #96 KMR968Turbo, Aug 26, 2017
    I had the engine on my Porsche rebuilt at a local Indy shop. Brought the car to them in January and did not get it back until August. All along they were delaying and working on other people's cars doing general maintenance (ie: brakes, bearings, etc). End result? Car left me stranded 1000 miles from home when timing belt broke. They fixed but only after I had to pay to get the car home. Timing belt broke 2 more times after that. Last time had the dealer take a look and it turned out they improperly spaced a tensionor. Cost me $5000 at the dealer that the Indy shop would not cover. Then a few months later the car developed rod knock. Has sat on my lift ever since - approx 10 years now. Still disgusts me when I look at the car. I feel your pain. For what it's worth, the shop looked like a disorganized pig stye.
  22. 97 Spider
    97 Spider Formula 3
    Dec 15, 2012
    2,241
    Texas
    Brian
    If you ever decide to get rid of that troubled stepchild please let me know. 👍
  23. johnk...
    Jun 11, 2004
    11,214
    CT
    John Kreskovsky
    So paint with VHT to get the wrinkle effect then lightly over spray with base coat (flat) of correct color.
  24. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Some do just that.
  25. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,252
    Worcester, England
    Phill J
    #100 4rePhill, Aug 27, 2017
    :confused:
    Is it just Me, or is anyone else being reminded of the Porsche 356 Speedster in "Doc Hollywood", where the yokel mechanic finally gets the car back together and hands a box of bits back to Michael J Fox saying something along the lines of:
    "There are always some extra parts left over when I do repairs!"
