430 - Is this normal? Crank pulley issue | FerrariChat
430 Is this normal? Crank pulley issue
Discussion in '360/430' started by alvin87, Sep 1, 2020.
  1. alvin87
    alvin87 Karting
    Mar 14, 2013
    77
    Renton, WA
    Alvin
    Any help would be greatly appreciated.
    last week I noticed a burning smell then smoke coming from the front of the engine. I was able to make it back home. Yesterday I finally was able to get it on the lift. The first thing I notice was the crank pulley. It looks like it was grinding against something but can’t figure what can possibly touch it. It looks too shiny for it to be normal. Anyone ever experienced this?
    What I do know is that the ac condenser pulley was shaking leading me to believe the burning smell and smoke was coming from that. The car runs and idles fine.
    Thanks in advance.
    Image Unavailable, Please Login Image Unavailable, Please Login View attachment 3158599 Image Unavailable, Please Login
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,660
    Central NJ
    Dominick
    I would start by looking at tensioner pulley right next to it .. pictures are not that clear but it looks off
    Or could the ac compressor when engaged is frozen / very hard to turn causing belt to smoke as well as put tension on pulley and pull into crankshaft
    Check it out with engine running and ac on
    Sent from my moto g(7) using Tapatalk
  3. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Take the belt off and see if anything is tight, if it has been smoking then renew it. Nearest VW garage will have the correct belt.
    Sort that before you try running the engine
  4. imahorse
    imahorse F1 Rookie
    2,746
    WI
    Dustin
    I'd take the belt off and try jiggling everything in the immediate vicinity to see if anything is loose.
    flash32 likes this.
