Is This Normal for a 360 Engine . . . Pics | FerrariChat
Discussion in 'Technical Q&A' started by 3omar, Mar 15, 2006.
  1. 3omar
    3omar Formula Junior
    329
    United States
    Omar
    #1 3omar, Mar 15, 2006
  2. Willis360
    Willis360 F1 Rookie
    Aug 4, 2001
    3,928
    Redmond, WA
    Willis H
    Not normal.
  3. CornellCars
    CornellCars Formula 3
    Mar 24, 2005
    1,102
    South Florida
    Jason
    They might have been too aggressive with cleaner/degreaser in the engine bay - I don't usually see cars as new as 2004 showing that kind of valve cover wear, it's more normal on the older 99-00 stuff, and even then, i wouldn't say it was a chronic problem. Perhaps they pressure washed it, which could also explain it.
  4. Rifledriver
    37,288
    Yup, what he said.
    Cleaner, pressure washer etc.
  5. Willis360
    Willis360 F1 Rookie
    Aug 4, 2001
    3,928
    Redmond, WA
    Willis H
    I have a '01 which I've driven over 37k miles since new. It's serviced, cleaned, and detailed regularly and have not seen that type of wear at all.
    I'd say someone's not careful working around the engine. Makes you wonder what else is messed up in the car.
  6. 3omar
    329
    United States
    Omar
    But you wouldn't say it was a sign of engine abuse (overheating, etc.)?
    Is it just high water pressure that would cause this? Not heat/other abuse?
  7. Willis360
    Willis360 F1 Rookie
    Aug 4, 2001
    3,928
    Redmond, WA
    Willis H
    It's probably over-aggressive cleaning, like what the others said. The scuffing looks like it might have been done with a stiff-bristled brush or worse, a wire brush. If this happened after you took your car to the detailer, I'd check around the car for anything else that might have been damaged.
    First picture: The area in the second "r" in "Ferrari" looked like it might have been done with a screwdriver. :(
  8. Francesco_Baracca
    Francesco_Baracca Formula Junior
    May 18, 2005
    367
    I do not think overheating would cause that. I'd say cleaning the engine bay with the wrong type of cleaner/brush.
  9. Rifledriver
    37,288
    Cool avatar. Is that a museum shot? Where?
