Is this piece supposed to come undone? | FerrariChat
Discussion in '308/328' started by Miklas, May 23, 2020.
  1. Miklas
    Miklas Karting
    Dec 10, 2018
    80
    Luxembourg
    I was swapping to a new steering rack today and when I removed the old one I realised that the lower part of the steering column was loose from the rest of the steering column (see pic below).
    This is the very last piece of the steering column that attaches to the steering rack.
    It's splined so it won't rotate on the column but it can slide up and down a bit. Shall it be welded to the column or is it normal that it can slide up and down?
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Was there a pinch bolt in the hole at the end ? The drawings on Eurospares web site give 2 good pictures of the setup
  3. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
    It is not welded. There should be a bolt + washer in the pinched end, tightened securely.
  4. Miklas
    Miklas Karting
    Dec 10, 2018
    80
    Luxembourg
    Yes, pinch bolt was installed correctly. In the diagram below I've marked in yellow the part that is in the pic in my first post. In the diagram it looks like one piece but on my car it's two pieces.
  5. Steve Magnusson
    25,145
    #5 Steve Magnusson, May 23, 2020
    As far as I know, part #7:
    should be a single monolithic part -- looks likes the lower part of yours has separated from the upper part (and should be rewelded in some fashion).
    The reason it's made in two piece is that it would be difficult, and expensive, to make a blind female spline feature. This way (using 2-pieces), the female spline goes all the way thru the lower part in your hand, and the upper part can have a male spline that fits into it -- but then they should then be permanently joined together to make a single part #7.
  6. Miklas
    Miklas Karting
    Dec 10, 2018
    80
    Luxembourg
    Thank you Steve, that's what I suspected.
    Can this be welded with a normal inverter welder or does it require something MIG/TIG?
  7. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Look to see if u can find sign of the original weld, might just be a few spot welds.
  8. Miklas
    Miklas Karting
    Dec 10, 2018
    80
    Luxembourg
  9. Steve Magnusson
    25,145
    Making small, high-quality tack welds with a large-diameter, flux-coated welding "stick" can be tricky, but would probably be OK. Try an internet search on something like "Tack welding with a stick welder" for some tips/hints if you can't have it MIGed or TIGed.
  10. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,086
    SanFrancisco BayArea
    1983 US 308 GTS QV
    I bring jobs like this to my friendly neighborhood muffler shop. They MIG day in and day out. For $20 they'll take 5 minutes out of their day to do a job like this for me.
    thorn likes this.
  11. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
    Agreed. It will take longer to drive to a decent shop than it will take the guy to MIG weld it. 3 good contacts and you're done.
  12. Miklas
    Miklas Karting
    Dec 10, 2018
    80
    Luxembourg
    Thank you all. I will have a go at stick welding the two pieces together.
  13. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,527
    California SF bay area
    Paul
    It's not like your welding body panels, doesn't have to be pretty.
  14. Miklas
    Miklas Karting
    Dec 10, 2018
    80
    Luxembourg
    Saabguy likes this.
  15. Saabguy
    Saabguy Formula 3
    1,759
    Shreveport, LA
    Are you certain that you don't need to turn that on a lathe, polish it, then plate in chrome? ;-) Looks terribly functional!
  16. Miklas
    Miklas Karting
    Dec 10, 2018
    80
    Luxembourg
    I might go as far as giving it a lick of paint. ;)
    Doogie and Saabguy like this.
  17. Saabguy
    Saabguy Formula 3
    1,759
    Shreveport, LA
    Heretic! ;-)
  18. Miklas
    Miklas Karting
    Dec 10, 2018
    80
    Luxembourg
    By the way, I'm reinstalling everything now and I bought new bulkhead bushings (items 30 and 31). Do these need any lubricants or are they supposed to be installed dry?
