Is this the engine oil temperature sending unit? | FerrariChat
Discussion in '308/328' started by Brunello, Feb 14, 2007.
  1. Brunello
    Brunello Formula Junior
    Sep 10, 2005
    250
    Vancouver, British C
    Al
    #1 Brunello, Feb 14, 2007
  2. 328gtsfan
    328gtsfan Formula Junior
    Aug 7, 2004
    830
    Aus
    Greg
    I believe the oil temp unit/thermistor is out of the top of your photo, along the edge of the oil sump cover.
    What you have circled, if I can read the diagram right is listed as the "SPEEDO IMPULSE UNIT".
    But I'd recommend a second opinion :)
  3. jwise
    jwise Formula Junior
    Apr 2, 2003
    781
    Portland Maine
    #3 jwise, Feb 14, 2007
    Correct- that is the speedo unit.
    The oil temp is threaded into the crank sump right next to where the shift shaft (with rubber boot) enters the sump. It's the brass hex with the wires snapped in to it.
  4. Brunello
    Sep 10, 2005
    250
    Al
    #4 Brunello, Feb 14, 2007
  5. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Yes, that's it!
