Issue when shifting in 1st | FerrariChat
Discussion in 'Mondial' started by stekkefun4, Apr 26, 2016.
  1. stekkefun4
    stekkefun4 Formula 3
    2,232
    Belgium - Europe
    Hey,
    I'm having this little issue with my 82 QV: when shifting in first, 50% of the time the gear is not engaged. When I press the lever down (like you would do to put in reverse) and then shift in 1st, it works 100% of the time!
    Does that sound like there's a problem with the shifter itself, with the rod that goes to the gearbox and passes through the engine, or is that an issue in the gearbox?
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,709
    South East
    Jimmie
    A friend recently had to replace his 308 gear lever and on closer inspection it was worn halfway thro against the gate and this was throwing out 1st (& reverse) alignment - might be worth checking
  3. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    The Netherlands - NH
    Tijn
    Could be something worn indeed. However, if something is worn in the shifter you feel it (awkward movement) when you shift.
    When do you have this problem? Cold or warm transmission, perhaps both?
    Oldman's trick when synchros do not lign up.
    First put it in reverse and the shift at once to 1st gear.
    Seems you are doing this, that might indicate to a (worn) synchro problem or alignment.
  4. stekkefun4
    2,232
    Belgium - Europe
    The problem first appeared when my car left the maintenance shop to have the oil pan gasket fixed. Maybe they hit something while removing it. I can live with it, but of course, it's not ideal.
  5. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Did they replace the shift shaft seals as well? Is so, then it's definitely a linkage adjustment issue.
  6. nerofer
    nerofer F1 World Champ
    Mar 26, 2011
    12,085
    FRANCE
    That would be the first thing to check. I am not a mechanic, but inside the gear box, there is a stack of three 90° brackets (“renvois d’angle”, in French) on one vertical axle, one above the other, that convert the LONGITUDINAL movement they receive from the shifter shaft towards the gear axles, that are TRANSVERSE, to select the gears.
    Usually when the shifter shaft is not perfectly aligned, it cannot select the correct gear because its extremity inside the gear box is not pushing on the right bracket (= you get a gear, but a wrong one…) or pushing on the right one, but not “truly” (you get the right gear, but cannot engage it.) ?
    Rgds
  7. stekkefun4
    2,232
    Belgium - Europe
    It looks like that's something I can't solve without opening the gearbox. It's not that it's selecting the wrong gear, the gearbox just stays in neutral when the shifter is in 1st.
  8. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    Tijn
    I'm with Wade. They must have done more then just changing fluids. Unless they changed to a very different lubricant. I'm thinking it is a linkage problem. If so don't drive too long with it, because if it scrubs to much against the forks.. they wear out before you know it. Not sure what forks cost these days, but it is a lot.
  9. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,743
    Argent/Brasil
    Guido
    My feeling is they drop a little of the 3 balls and put all back together without it...
    Guido
  10. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    Tijn
    Upss! That would be a very easy, but at the same time a stupid mistake. Or switched the spacers. �� Not sure if the ball hold the lever in gear to be honest. It's true that these little balls tend to fly into every direction if it is your first time taking the pan off ��
  11. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    #11 Wade, Apr 26, 2016
  12. stekkefun4
    2,232
    Belgium - Europe
    Hey, it's not a 'balls' problem, all 3 of them are in there. I had that checked by another mechanic because that was my first thought.
  13. theunissenguido
    Jan 21, 2004
    2,743
    Argent/Brasil
    Guido
    #13 theunissenguido, Apr 27, 2016
    Its the little ball that keeps the lever in gear...with the pression of the spring under it. Maybe they put the spring first and the the ball...or an other ball with other diameter.
    Can be also that the hollow space in that lever is'nt put horizontal so that ball has'nt enough space to pass.
    Guido
  14. bartzagato
    bartzagato Formula Junior
    Aug 7, 2010
    614
    Belgium
    Bart
    I had this issue after I changed my shifter shaft seals.
    It's all about allignment.
    tricky job but doable. The problem is when you tighten the bolts the shaft could move.
    I redid the alignment and all troubles were solved.
  15. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    Tijn
    Makes sense!
    Just in case.
    Ferrari 308 and 328 gearbox alignment
  16. stekkefun4
    2,232
    Belgium - Europe
    thanks guys for helping me out... Guido, wecould do this together when you're here in May :)
  17. theunissenguido
    Jan 21, 2004
    2,743
    Argent/Brasil
    Guido
    just find the time....more then 20 owners waiting for fuseboxes !
    Guido
