Issue with 19" HRE 547 wheels on a 360? | FerrariChat
Discussion in '360/430' started by tubeguy, Nov 25, 2003.
  1. tubeguy
    tubeguy Formula 3
    May 21, 2003
    1,041
    Upland California
    Kevin Deal
    I certainly don't want to have problems with fit...or any issues with cosmetics and cleaning. Can anyone chime in on this?
    There is a set that has been up on e-bay from a couple of folks...supposed to have come off a 360
    Size:
    Pirelli Pzero Rosso Tire sizes are as follows 295/30/19 on the rear and 245/35/19 on the front. Wheels are 19x11 on the rear and 19x8.5 on the front
  2. rjklein
    rjklein Karting
    Nov 3, 2003
    126
    The tire size on the fronts are wrong, and they will rub. They need to be 225 X 35 x 19's or max 235's but 245's = rubbing.
  3. Scott85
    Scott85 Formula 3
    Dec 16, 2000
    1,240
    Dayton , OH
    #3 Scott85, Nov 25, 2003
    Those look like the same wheels on the 360 below. I know the owner was a part of Ferrarichat before moving to the new forum, not sure if he's joined back up, but I can send you to his website if you want, PM me .
  4. TCM
    TCM Formula Junior
    Nov 10, 2003
    552
    Tyngsborough, MA
    I am not certain on the fitment of the wheels, but you do need to be very careful with the high polished lip on them. The lips stain very easily and hold water after washing. You need to use a good wheel polish (Mother Mag Polish works very well) every coupe of weeks. The quaity of the wheel is great but the staining does get tiresome.
  5. Schatten
    Schatten F1 World Champ
    Apr 3, 2001
    11,238
    Austin, TX
    Randy
    note in the second image they are R's - which would be a reverse wheel with the reverse lip and also one of the bolts is missing to hide the valve stem. really neat setup that the guys from HRE have done on those. but if you want a set, don't cheap out and make sure they are fitting right with the options you want.
  6. riverflyer
    riverflyer F1 Rookie
    Nov 26, 2003
    3,583
    Mendocino, Ca
    Hi, I have just rejoined the board. TCM and Schatten are both correct. I have the 547's on a bmw and have the full polished version. Depending on drivng conditions, habits etc. they need regular polishing. I do a very thorough job about two to three times a year on a car than gets about 3k mileage per year. I love them and get so many positive comments on them. The build quality is exceptional. Hope that helps, John
