Issues & question on my 308GT4 | FerrariChat
Discussion in '308/328' started by Mohan Balasingam, Jun 13, 2023.
  1. Mohan Balasingam
    Mohan Balasingam Rookie
    Jan 5, 2020
    8
    Singapore & Malaysia
    Mohan Balasingam
    Hi there,
    Have a few questions below if you guys can help on my 1979 308GT4:
    - I use 95 unleaded fuel. Is this the right grade of fuel to use?
    - Whats the best grade of engine & gearbox oil to use for this car. I live in a very hot & humid climate(Malaysia)
    - Plugs to use?
    - Car backfires when i turn off the engine. Any reason why? Out of tune?
    - Has anyone modified their power window to fit a more modern motor & mechanism?
    - where is the best place to source for parts
    Thanks for your help & look forward to your replies.
    Cheers,
    Mohan
  2. fatbillybob
    fatbillybob Two Time F1 World Champ Consultant Owner
    Aug 10, 2002
    28,999
    socal
    95 is ok.
    Check timing for back fire. Then check carb function and settings.
    Window motors use power to windows to trigger separate relay. The connect relay to window and power from battery to get windows to move at best speed. Also clean tracks and ensure free movement. Oils use correct weight and api rating. Different gear oils can affect shifts positively and negatively. Lots like redline and Mobil 1
  3. Mohan Balasingam
    Jan 5, 2020
    8
    Mohan Balasingam
    Thanks for all the information.
    With regards to the window relays, I assume these are located near the fusebox? Pardon my ignorance. I was actually thinking of getting a japanese motor to replace the current one.
    Cheers
  4. fatbillybob
    Aug 10, 2002
    28,999
    socal
    Motors could be a problem but often it is just clean power to the windows. That's why using the stock power wire to the window and adding a relay to direct clean power to motors work well to get some speed. You can test the benefit by putting a fully charged 12.5v car battery on the window and see if that improves speed. If yes then adding external relay will too.
  5. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,027
  6. Rifledriver
    37,100
  7. Steve Magnusson
    Steve Magnusson Two Time F1 World Champ Lifetime Rossa
    26,806
    I believe the OP lives in a country that uses the RON octane rating system -- not the AKI rating system used in the US. 95 RON fuel is about 90 AKI fuel in the US (so nothing too special).
  8. Mohan Balasingam
    Jan 5, 2020
    8
    Mohan Balasingam
  9. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,027
    Oops! Missed that.
  10. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,027
    Octane rating - Wikipedia
    According to this article, looks like the RON octane rating alone is used as Steve mentioned, so the octane rating as we're used to it, is lower.
    I haven't had too many issues with 308's knocking. I only run AKI 91 which would roughly translate to 96 RON.
  11. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,027
    Once I've seen a carb 308 backfire badly on shutdown. The driver revved up the engine to 3-4K rev's and switched off the ignition.
