Issues with 1996 Spider F355 roof Hydraulics | FerrariChat
Discussion in '348/355' started by Roger348, Nov 5, 2015.
  1. Roger348
    Roger348 Karting
    Feb 10, 2013
    104
    Reno, Nevada
    Roger Cody
    Has anyone out there had a issue with the hydraulic system on there car? And if so how did you resolve it?
    I've just replaced the roof frame, tried the unit and found that the Rams are not moving at the same time and rate. The unit is full of oil and runs in both directions.
    Or should I remove the system and have it overhaul?
    Cheers!
    Roger
  2. WATSON
    23,903
    WI
    Have you properly bled the hydraulics?
  3. Roger348
    Roger348 Karting
    Feb 10, 2013
    104
    Reno, Nevada
    Roger Cody
    Just did a search of Fchat and found a post and recommend a complete flush and bleeding of system. So I'll try that over the weekend.
  4. John M
    John M Formula Junior
    Nov 18, 2004
    887
    Kentucky
    Sounds like the compensation valve bleeder wasn't done. New fluid and proper bleeding at both locations won't hurt. The stuff I pulled out of mine was about as thick as molasses.
  5. Roger348
    Roger348 Karting
    Feb 10, 2013
    104
    Reno, Nevada
    Roger Cody
    I've just bled the hydraulics and I've got the main Rams working as they should, but I not able to get it to operate on the control switch. When it's engaged it just makes a bepeing sound, but nothing is moving. The only way to operate the roof at this time is by way of the emergency switch.
    Has anyone had this issue and know of a way to resolve?
    Roger
  6. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,662
    San Carlos, CA
    Mitchell Le
    Yes, if it just beeps at you then the causes are:
    1. Windows not down
    2. Parking brake not pulled up
    3. Seat not moved forward or failed potentiometer
    4. Microswitch inop
  7. Roger348
    Roger348 Karting
    Feb 10, 2013
    104
    Reno, Nevada
    Roger Cody
    Thanks, I'll check and see if one or more are the issues.
    Cheers!
    Roger
  8. Shootfighter65
    Shootfighter65 Formula 3
    May 13, 2014
    1,372
    Charleston SC
    Randy..alluneedtokno
    convert to manual....all problems solved
  9. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    +1
  10. Roger348
    Roger348 Karting
    Feb 10, 2013
    104
    Reno, Nevada
    Roger Cody
    It looks as if it's one or both Potentiometer on under the seats, everything else checks out fine. I'll pull the seats and update the findings. After this much time and funds I'm just not going to make it a manual top and also it's my wife's car and if I ever hope to get my 360 or 430 I've got to get this one repaired. But I've also got to find a home for my 348ts.
    Cheers!
    Roger
  11. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Good job. Converting it to manual is not a solution , its a compromise. It's a Ferrari. Love it and fix it!
