Issues with the gas-cap / check engine light? | FerrariChat
Discussion in '360/430' started by D-Rod360, Apr 25, 2017.
  1. D-Rod360
    D-Rod360 Rookie
    Apr 25, 2017
    2
    Any experiencing this?
    Also, I recently changed the stereo system. Will that trigger the check engine light?
  2. Skidkid
    Skidkid F1 Veteran
    9,524
    Campbell, CA
    John Zornes
    Gas caps and CEL are a common problem.
    The stereo can cause a CEL but only if you caused an electrical issue.
  3. RossoC360
    RossoC360 Formula Junior
    Jun 20, 2008
    477
    Buffalo NY
    Jason
    did you scan it to see what the code is?
