It lives. And it's FAST. | FerrariChat
Discussion in '308/328' started by ATSAaron, Mar 28, 2016.
  1. ATSAaron
    ATSAaron Formula 3
    1,135
    Shady Shores, TX
    Aaron Bunch
    #1 ATSAaron, Mar 28, 2016
    First off I have to apologize because I am posting from my phone and this site allows exactly one photo per post.
    So here is the engine bay of my turbo 308. Mason Bleasdell owed me a few favors for fixing his MR2, so credit for the pretty pictures goes to him.
    Aaron
  2. ATSAaron
    ATSAaron Formula 3
    1,135
    Shady Shores, TX
    Aaron Bunch
    #2 ATSAaron, Mar 28, 2016
    288 GTO front bumper, turn signals, foglights and air dam. I bought material to fabricate a grille, but I kind of like the rawness of the fans.
  3. ATSAaron
    ATSAaron Formula 3
    1,135
    Shady Shores, TX
    Aaron Bunch
    #3 ATSAaron, Mar 28, 2016
  4. ATSAaron
    ATSAaron Formula 3
    1,135
    Shady Shores, TX
    Aaron Bunch
    #4 ATSAaron, Mar 28, 2016
    It runs on E85. It's very convenient for me as there is a pump about a block from my shop. E85 is mostly ethanol and has a very high octane and excellent cooling properties. Because of this we actually raised compression on the engine and added a turbo on top of that. The results are amazing. 572whp (about 700 flywheel horsepower based on the drivetrain losses we have seen with other F cars).
  5. topcarbon
    topcarbon F1 Rookie
    Nov 3, 2006
    2,605
    Wow, just wow
  6. ATSAaron
    ATSAaron Formula 3
    1,135
    Shady Shores, TX
    Aaron Bunch
    308 stock crankshaft
    Carillo rods
    Norwood custom JE pistons
    348 heads
    Cams worked by Bob
    308 QV block
    Custom clutch - part center force, part Bob Norwood, part Notwood Italia
    328 oil pump, can gears, exhaust manifolds and intake runners
    308 QV intake plenum
    70mm throttle body
    630cc injectors
    Fuel rails by ATS/Bob
    Runners modded for efi by ATS
    Runners ported to match 348 heads
    Cam/crank sensors from Bob
    Link G4+ ecu tuned by ATS
    Toyota Tundra coils
    Turbo kit fabricated by ATS
    Precision 6265 billet compressor wheel turbo with .82 ar T4 exhaust
    Trunk mounted water to air intercooler core and reservoir.
    Back'n'Black likes this.
  7. Jack-the-lad
    Jack-the-lad Seven Time F1 World Champ
    Impressive. What's the CR and how much boost?
  8. ATSAaron
    ATSAaron Formula 3
    1,135
    Shady Shores, TX
    Aaron Bunch
    We also did a bunch of restoration/resto-mod work.
    There is a custom aluminum radiator
    Custom ac condenser
    Dual SPAL fans
    Replaced all ac lines with R134 barrier hose
    New Sanden compressor
    New ac interior fan
    AC vent temps are cold. I haven't had a really hot day to try it, but on 80 degree days the vent temps get down into the high 30's.
  9. ATSAaron
    ATSAaron Formula 3
    1,135
    Shady Shores, TX
    Aaron Bunch
    Jack - about 11.5:1 and 14 psi of boost.
  10. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,806
    Cerritos, CA.
    Impressive!
  11. Jdubbya
    Jdubbya The $10 Trillion Man
    43,125
    PNW
    Holy Crap. A 308 with what might be a bit too much power! :eek:
    That is going to be a real handful to drive anywhere close to it's potential. Did you do any suspension or brake upgrades to match the power? What a fun project !!!
    Would love to see and hear it running.
  12. Robb
    Robb Moderator
    Moderator Lifetime Rossa Owner
    Feb 28, 2004
    14,332
    Robb
    Looks fantastic. Let's see more photos. Any videos?
    Robb
  13. ATSAaron
    ATSAaron Formula 3
    1,135
    Shady Shores, TX
    Aaron Bunch
    #13 ATSAaron, Mar 28, 2016
    We also installed the Girodisc brake kit. It's better, but you still have to be careful about when you use the boost.
    The suspension is all new poly bushings, QA-1 coilovers, new ball joints, new steering rack and tie rods.
  14. ATSAaron
    ATSAaron Formula 3
    1,135
    Shady Shores, TX
    Aaron Bunch
    #14 ATSAaron, Mar 28, 2016
  15. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I want your front spolier/air dam!! I'd put a grill in it, but I love the GTO quad lights. I've contemplated buying a deep fiberglass repro and modifying it.
    And the power, I'd be up for a fistfull of that also!
    Noice!
  16. Arvid
    Arvid Formula Junior
    May 28, 2012
    668
    Norway
    Arvid Andersson
    WOW ! This looks mean and fast.
    Are the wheels 17" Autostrada Modena ? They look great on the car. I have a set that's going on the 400GT some time in the future.
    A
  17. 455Fosbery
    455Fosbery Karting
    Oct 3, 2013
    212
    Simply fabulous!
    Before any of the purists jump in (AKA the 'originality freaks'... and BTW there is absolutely nothing wrong with being one!), it must be said that you really have to drive one of these conversions before passing judgment. If you are used to a stock 308 QV, these are surreal!
    That being said, as the man reminds: "...you still have to be careful about when you use the boost..."
    I recall many years ago one of the reviews of the original Porsche 930 being simply, "Lethal in the wrong hands". 14 pounds of boost in this application certainly could yield the same observation.
    All the very best and happy (and safe!) driving with this rocket!
    John (another Norwood turbo-QV owner)
  18. Imperial Stormtrooper
    May 7, 2014
    148
    Far, Far Away
    George
    Nice! I'd love to see some video of this thing in action!
  19. ATSAaron
    ATSAaron Formula 3
    1,135
    Shady Shores, TX
    Aaron Bunch
    Yes! That is exactly what they are. Good eye.
    Aaron
  20. ATSAaron
    ATSAaron Formula 3
    1,135
    Shady Shores, TX
    Aaron Bunch
    #20 ATSAaron, Mar 29, 2016
    All my original parts including my carbureted 2v engine are shelved/stored. Almost everything was a "bolt on" affair with no drilling or cutting. But I can't imagine wanting to go back to original/stock.
  21. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,318
    Dumpster Fire #31
    SMG
    Friggen awesome, love boosted engines! Anything over 450Hp is pure stupid fun and plasters a grin that sticks for long while!
    Link G4, really the only way to go unless one has serious coin for Mclaren :D I really like the ease and speed of using Link.
    Honestly you're probably around 630-ish at the crank. I know sounds low, but there is a couple reasons why, bearing and viscous gear drag are roughly ~1% most all gearboxes in a 1:1 ratio are 98%~98.5% efficient. The 308 though is 1:1.12 in 4th so it's off that mark by about 2%. I'd roughly figure a loss of ~10%. The transaxle in the 308 does not utilize a 90* turn via a hypoid-geared diff, that's where conventional drivetrains lose ~10%.
    Another thing to keep in mind is the losses are frictional and thus would be converted as heat, converting the loss to heat in terms of power required to heat the gear oil and transaxle will give one a rough idea if the numbers are realistic. Oil heats up at twice the rate of water for example. 126Hp or a 22% thermal conversion would boil the oil in very short order!
    Oh and interesting to note, there is a right off the bat a 10% reduction in RPM from the clutch to the input shaft, the drop gears are not 1:1.
  22. luckydynes
    luckydynes F1 Rookie
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    Awesome job and way to stick with it!
    I'd scare myself with that much power ... I want to be scared :).
    cheers
  23. Saabguy
    Saabguy Formula 3
    Mar 28, 2012
    1,785
    Shreveport, LA
    As with others I say WOW!
  24. sltillim
    sltillim Formula 3
    1,693
    San Diego
    Insane build and right on for doing what YOU want!!!!
    I love the front end too. I would think it would be very easy to damage that nice radiator though. Rather than making a traditional 288 grille you can do something more raw like some vintage mesh grille that is a little recessed and only covers most of the radiator. I'd paint the mesh black too - that would be mean!!! Do a search on "bumperless" in the 308 section and you can get some ideas from some threads.
    can't wait to see this thing go in a video!
  25. GrayTA
    GrayTA F1 World Champ
    15,130
    Deep South
    PDG
    Holy Crap!!!
    That's insane!!!
    Congrats on an incredible car!!
    PDG
