Italamec Key Light Delay Module | FerrariChat
Discussion in '348/355' started by m.stojanovic, Apr 28, 2018.
  1. m.stojanovic
    m.stojanovic F1 Rookie
    3,297
    Serbia - Niš
    Miroljub Stojanovic
    I had a look at the internals of my (working) Italamec "relay" and put the info on how it works on one page, to assist anybody who may have problem with it.
    The Italamec module (no relay inside) has two functions:
    1. Connects left and right door switches with a large diode to enable the roof light to come on with either door switch. On my 1991 RHD Euro 348, the roof light is hard wired to the left door so, if Italamec is taken out, the right (driver's) door does not activate it.
    2. Provides +12V to the key light continuously while the driver's door is open and for ~15 sec. after the door is closed. The trigger for the delay circuit inside Italamec is taken from the cathode of the large diode (the diode cathode, "I" pin of Italamec, is connected to the driver's door switch - LHD left, RHD right). In this way (due to the diode), the key light is operated by the driver's door only.
    If the Italamec is bad (the roof light does not work with one of the doors), the module can be taken out and the pins "P" and "I" in its socket can be bridged to get the roof light function by both doors.
  2. m.stojanovic
    3,297
    Serbia - Niš
    Miroljub Stojanovic
    spaghetti_jet, Ga68_ and Qavion like this.
  3. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Thank you, Miroljub. My key light isn't functioning and IIRC it's not getting voltage. Maybe this will help diagnose the problem.
  4. m.stojanovic
    3,297
    Serbia - Niš
    Miroljub Stojanovic
    The key bulb is grounded on one side and gets +12V from the Italamec's "L" pin. To test the bulb and its wiring, pull the Italamec out and bridge the female pins "30" and "L" in its socket (verify that you have permanent +12V in the "30" socket). The light is hard to see in daylight, it is only visible when looking directly into the key slot. If the light works with the bypass, then your Italamec is bad but it can be repaired - see the transistor types I wrote on the page, both are available on Ebay. There is also a 220 uF capacitor which can be a suspect.
  5. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Huge thanks, Miro. This has been one of those things I've been wanting to look into but other more important items have kept me from starting the investigation. The info you've provided will make it an easy process to isolate the source of the problem. Going to print this out and keep it in the passenger seat for use the next time I can open that door. Thank you!
    BTW, do you or anyone else know what's entailed in changing the lamp itself if it's burned out?
  6. m.stojanovic
    3,297
    Serbia - Niš
    Miroljub Stojanovic
    I can't help with the way of changing the bulb but, if your bulb has burnt and you can't get the original, you can replace it with small 12V bulb, usually available in radio shops. If using a universal bulb, it shouldn't be more than about 0.5-0.6 Watt (~50 mA) as the transistor driving it (the MPSW05) has only 1 Watt dissipation and it has no heat sink.
    Qavion likes this.
  7. Qavion
    Qavion F1 World Champ
    14,488
    Ian Riddell
    Ga68_ likes this.
  8. m.stojanovic
    3,297
    Serbia - Niš
    Miroljub Stojanovic
    You are welcome to add the info. One suggestion: replace your note "Diode orientation depends on LHD/RHD" with "Pin I goes to the driver's door switch, pin P to passenger's" or "Pin I goes to the left door switch on LHD, right door switch on RHD" or similar.
    The large diode is inside the Italamec (across pins P & I) and its orientation is not changed for LHD/RHD but the wiring to the pins P and I is different for LHD and RHD; pin I is always connected to the driver's door switch, wherever the driver's side is, and pin P goes to the passenger (easy to remember).
    Qavion likes this.
  9. m.stojanovic
    3,297
    Serbia - Niš
    Miroljub Stojanovic
    Hi Ian. As I was going to check the voltages on my TPS-s, I looked at your 348 Motronic 2.7 Wiring Diagram as well as at the original one. I noticed a discrepancy in the connections of the left and right TPS-s to their respective ECU-s and could see that on your diagram (which follows the original one), you have put question marks at the Right TPS. It appears that, in the original diagram, the connections of the IAC and TPS to the ECU have been swapped-over by mistake. I believe that the IAC and TPS connections to the ECU shown for the Left bank are correct and that the diagram for the Right bank should be corrected, i.e. should be same as shown for the Left bank. This is because the instructions in the manual for checking the voltages on the TPS state that, for both banks, the voltmeter should be connected between ECU pins 19 & 53 to verify that there is 5V supply. On the diagram for the Left bank, ECU 19 (ground actually) goes to Pin 1 of the TPS and ECU 53 goes to Pin 3 of the TPS and I have just verified that I have 5V between Pins 1 & 3 on both of my TPS-s.
    I have not physically verified that the Right TPS is connected to its ECU in the same way as the Left one but it looks obvious to me that the connections TPS & IAC to the ECU on the Right bank are wrong.
    The mentioned instructions for the TPS voltage checks are also confusing. They only mention connection of the voltmeter between Pins 1 & 3 of the TPS (Pins 19 & 53 of the ECU) to verify the 5V and then state that 400-600 mV is correct voltage on the TPS (at idle position) but do not state that this should be measured between Pins 1 & 2 of the TPS (Pins 19 and 12 of the ECU).
  10. Qavion
    14,488
    Ian Riddell
    Yeah, the original did look a little suspect.
    It was a little tricky to get the lines in the right place, but I did a direct swap for pins 1, 2 & 3 on both the IAC and TPS
    Maybe you could just briefly check this piece of my diagram and then I'll cut and paste it onto the old diagram:
    F348_27_Correction
    I'll keep the ECU pin numbering in magenta to remind me that there has been a correction.
  11. m.stojanovic
    3,297
    Serbia - Niš
    Miroljub Stojanovic
    #11 m.stojanovic, Sep 13, 2020
    You need to make the following further changes to the RH bank connections:
    IAC 1 - OK
    IAC 2 - move from splices "VVV..." to splices "NNN..." (ground)
    IAC 3 - OK
    TPS 1 - move from ECU 12 to ECU 53
    TPS 2 - move from splices "NNN..." to ECU 12
    TPS 3 - move from ECU 53 to splices "NNN..." (ground)
    RH TPS Pins 1 & 3 have to be connected opposite to how the LH TPS pins are connected since they are rotated in opposite directions (LH anticlockwise, RH clockwise).
  12. Qavion
    14,488
    Ian Riddell
    Complicated. So not all the wires were swapped from one device to another. Hopefully there are no wire colour changes at the ECU pins.
    We also have one more earth wire and one less power wire. Are you sure about this? The LH IAC 2 seems to have power on it (orange wire), but the RH IAC 2 has an earth.
    F348_27_Correction2
    I'll update the corrected (full size) diagram tomorrow.
  13. m.stojanovic
    3,297
    Serbia - Niš
    Miroljub Stojanovic
    #13 m.stojanovic, Sep 13, 2020
    Sorry, my previous info was wrong. I was confused because, as I just found out, the TPS pin markings on the diagram 1,2,3 do not exactly correspond to the 1,2,3 markings on the TPS itself. The diagram Pin 2 (wiper of the TPS) is Pin 3 on the TPS itself (and vice versa).
    After checking directly on my 348, I can confirm that your "F348_27_Correction" is all correct (discard your "F348_27_Correction2").
    As you will note (looking at the diagram pin numbering), on the Left TPS, Pin 1 is ground and Pin 3 gets +5v from the ECU Pin 12; on the Right TPS, they are reversed - Pin 1 gets +5v from the ECU Pin 12 and Pin 3 is ground. This reversal of 5V supply polarity to the end terminals of the TPS potentiometer is necessary because the Left TPS is rotated counterclockwise and the Right one clockwise.
    You can also change your wording (at the Right Bank green splices) "12V power splices" to "ECU provided 12V power splices" and put the same description at the Left Bank brown splices.
  14. Qavion
    14,488
    Ian Riddell
    I can change the pin numbering on the diagram if that helps. It's nice to have sequential numbers on diagrams, but even Ferrari doesn't always do this.
    Is it just a matter of swapping the 2 & 3 like this?
    Just to confirm, you mean that the ECU controls the relay which provides 12 volt battery power to the spices?
  15. m.stojanovic
    3,297
    Serbia - Niš
    Miroljub Stojanovic
    I don't see that any relay provides power to the "12 volt splices". The "12 volt splices" get power from the ECU and the splices provide power to one side of the coils of the Fuel Pump and Injection relays. The other side of these relays is grounded by the ECU to switch them on as required.
    The TPS connections:
    I (again) overlooked one detail - on your "F348_27_Correction" diagram, the existing Right TPS pin numbering happens to be as per the numbering on the TPS as far as the links to the ground and the ECU are concerned so you should leave them as they are. Just move the potentiometer symbol up a bit (until aligned with line 2), link 1 to its other end and link 3 to the middle of the pot symbol. Something like this:
    On the diagram for the Left TPS, move the pot icon down a bit (until aligned with line 2), link 1 to its other end and link 3 to the middle of the pot symbol (mirror image of the above pic).
    I hope this finally clears the Ferrari mess.
  16. Qavion
    14,488
    Ian Riddell
    #16 Qavion, Sep 14, 2020
    If you look at relay L pin 87, one of the outputs goes towards the right to the relay panel blue plug. Relay L is activated by a white wire from the Right ECU. The output from the relay goes from the blue plug to the splices on a 2.5V wire. This is the largest wire going to the splice, so it is usually the source. The other output of relay L goes to the fuel pump relay solenoid. The 355 operates in a similar manner.
    The diagram can be confusing because of the pigtail on pin 7 of plug 119. It's probably just a convenient power tap for the CEL.
    Here's the full diagram with your suggestions (I hope this is correct):
    Motronic_2.7_Wiring_Diagram_348
  17. m.stojanovic
    3,297
    Serbia - Niš
    Miroljub Stojanovic
    Absolutely right. I did earlier follow the 2.5V line (a number of times) from the 12V splices to the relay L and saw it connected to the relay pin 87 but, due to some brain lock (or age catching up), I took it to mean one of the relay coil pins, even though I have known the meaning of the relay numbers for at least 40 years (and I didn't look just a bit up to see that 87 goes to the relay contact). Relay L (Injection) is activated at ignition "on" and it provides power to one side of the coil of relay N (fuel pump) and gets it ready to be switched on by the ECU during cranking and during engine running.
    I will have a look at your final diagram tomorrow and let you know. Cheers.
    Qavion likes this.
  18. m.stojanovic
    3,297
    Serbia - Niš
    Miroljub Stojanovic
    Your diagram Motronic 2.7 Ver. 14, everything good - just a couple of small changes:
    1. The "+5V" should be at Pin 2 on the Left TPS and at Pin 1 at Right TPS.
    2. At the splices, replace "ECU provided" with "IGN".
  19. Qavion
    14,488
    Ian Riddell
    Thanks, Miro. Click on the previous link to see amendments (after refreshing browser)
    Maybe ECU-controlled 12volts would be better? Is there any other logic in the ECU (other than ignition on) which might prevent power going to the relay L solenoid?
    Also, the battery is supplying power to the relay. Anyway, whatever makes it easier for 348 fixers :D
  20. m.stojanovic
    3,297
    Serbia - Niš
    Miroljub Stojanovic
    Put "+5V" also at pin 1 of the Right TPS.
    As to the power to the "splices", it is controlled by both, the Ign. switch and the ECU. The ECU will normally allow the relay L (injection) to be switched on at every ignition on but it will switch this relay off in the case of bank shut-down. Perhaps you can put "IGN/ECU controlled 12V pwr splices".
    Qavion likes this.
  21. SpiderMan95
    SpiderMan95 Karting
    May 2, 2021
    51
    Ontario Canada
    Matteo Gpro
    Hello I have a 95 348 spider us.
    I'm having a issue understanding the dome light and it's functions. The dome light has 3 wires options. Do we know what goes where and also what are the functions.
    1 when you open the door to light comes on and the other 2 options?
    This is my issue right now. I press the clear lense one way so on position and it only works when I open the door. That's it I get no other functions from it.
    I have 3 wires and a brand new come light. To replace my old one that was bad
  22. SpiderMan95
    SpiderMan95 Karting
    May 2, 2021
    51
    Ontario Canada
    Matteo Gpro
    I did have it reversed at one point where I had the dome light when I pressed it but not on the door opening. I'm sure I'm close but I tried many other ways to have both. Pressing it when I need it in the car and with the door. So far no luck. But it looks to gave 3 options.
  23. Qavion
    14,488
    Ian Riddell
    I don't think I have a diagram for this kind of light. You have the type of light bezel which tilts/rotates?
    I have a F355 spider with this kind of light. I replaced mine a few years ago because the contacts were intermittent. I don't remember how it is hooked up.
  24. Qavion
    14,488
    Ian Riddell
    Here's the instructions for the F355 Spider dome light
    I recall it is possible to mount the light back to front, so the functions may be reversed.
    spaghetti_jet likes this.
  25. SpiderMan95
    SpiderMan95 Karting
    May 2, 2021
    51
    Ontario Canada
    Matteo Gpro
    Thank you this is very similar to mine 3 positions. Makes more sense now.
    A position works that's great
    B position is off okay.
    C. Position is where I'm having a issue. Your awesome let me see now what I need to do. I'm new to this site still trying to understand it.
    I have one other question how do you change the bulb for the gas release lock and unlock. They bulbs don't look to be removable looks like the old style bulb with 2 wires that some how are stuck in maybe ? With no way of removing.
