Italia with Speciale wheels/tires package | FerrariChat
Discussion in '458 Italia/488/F8' started by maomaoferrari, Oct 10, 2014.
  1. maomaoferrari
    maomaoferrari Karting
    Jan 23, 2004
    148
    I installed the Speciale wheels and matching Michelin Cup 2 tires on my normal 458 Italia yesterday. Having driven just a few street miles, the difference is immediate. Visually the Speciale wheels are much wider, mounting quite flush with the edge of the fenders where as the regular Italia sized wheels are a bit tucked in. Road feel from the steering and turn in response is improved as a result (I suspect) of stiffer side walls and wider widths. Braking response has however deteriorated as the tires tend not to be at optimal operating temperature on the street. Track day coming soon and will have a better review. At this point, I've got a good sense that the performance difference between the Speciale and the Italia is at least 50% attributed to this wheels and tires package.
  2. FE458IT
    FE458IT Formula Junior
    Jul 17, 2013
    445
    Toronto
    Any pics?
    Where did you get them and pricing if you don't mind, I was considering getting them.
  3. Caeruleus11
    Caeruleus11 F1 World Champ
    11,612
    It always is. If you take your 430 or Italia and put on the more focused tires and then widen the track with spacers or wider wheels and put in a more aggressive alignment and maybe more aggressive springs and you will be 65-75% of the way there. :)
  4. maomaoferrari
    Jan 23, 2004
    148
    I should also say that the ride is noticeably stiffer. It was the first time I was tempted to use the bumpy road setting in sport mode.
  5. maomaoferrari
    Jan 23, 2004
    148
    Well I think the difference just gets smaller with each iteration. The 360CS is quite different from the normal 360 and the 430 Scuderia is less difference, and finally 458 is basically a body kit with R-rated tires and some software changes.
  6. DoctorV8
    DoctorV8 Formula Junior
    Jun 29, 2004
    472
    Houston, TX
    Sanjay
    Let us know how the stability control reacts on track. The Speciale rear tires are shorter than the stockers (30 series vs 35 series), and therefore the front to rear wheel speeds are different. This is why I decided on Trofeo R's in stock sizes on the stock wheels of my 458.
  7. maomaoferrari
    Jan 23, 2004
    148
    They had some trouble with this after installing the wheels. They reset the ECU and we'll see if it comes back on track. So far so good.
  8. 458trofeo
    458trofeo F1 Rookie
    Feb 4, 2013
    4,426
    City of Angels
    101 aki
  9. icoburn
    icoburn Karting
    Jun 14, 2012
    173
    Franklin, TN
    Ian Coburn
    #10 icoburn, Oct 11, 2014
  10. pride355
    pride355 Formula Junior
    Apr 16, 2006
    388
    Istanbul/Turkey
    MOT
    Actually Speciale front tire side wall is slightly taller (3,5 mm to be specific 235/35/20 vs 245/35/20) and I have this 245 size tires on my italia.
    However, rear speciale tire side wall is 11,5 mm shorter; thus I kept my stock tire size untill Pirelli decides to produce 305/35/20 size Trofeo R tires (they have this size for P zero)
    So the stiffer ride probably comes by the rear tires.
  11. BurakUsta
    BurakUsta Formula Junior
    May 27, 2014
    289
    Istanbul/Turkey
    B.U
    As usual always the true information source ;)
  12. synergy
    synergy Formula Junior
    Aug 5, 2007
    522
    Austin Texas
    Chris
  13. RossoDiamante
    RossoDiamante Karting
    Jun 3, 2013
    214
    Mid-Atlantic, US
  14. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Any updates? Does anyone run Speciale size tires on standard 458 forged 20" wheels? I want to go to track focused tires but would prefer Michelin Sport Cup 2s over Trofeo Rs, but the SC2s don't come in 458 sizes, only Speciale sizes.
  15. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,263
    Mel
    I have 305/35/20 MPSS on the rear oem wheels .... instead op 295's ... no ECU problems and drives perfect.
  16. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Thanks, good to know, but are you sure your rears are 305/35-20 and not 305/30-20? I can't find 305/35-20 in Michelin Sport Cup2. OEM Speciale sizes are 245/35-20, and 305/30-20.
    Is anyone running these sizes on the stock 458 20" forged wheels w/o problems? My OEM size MPSS have had a few track days and I'm thinking of going to SC2 this time, but won't if that's going to cause tire telemetry issues (or fender clearance or other physical issues).
  17. AlfistaPortoghese
    AlfistaPortoghese Moderator
    Mar 18, 2014
    3,778
    Europe, but not by much.
    Nuno
    Mel,
    Do you have TPMS on your 458?
    Kind regards,
    Nuno.
  18. edgramir
    edgramir Rookie
    Dec 6, 2015
    25
  19. spyder625
    spyder625 Formula Junior
    Jun 16, 2017
    727
    NJ
    looks great, love the yellow on the wheels..
  20. edgramir
    edgramir Rookie
    Dec 6, 2015
    25
    Thanks buddy. It was my most inexpensive mod and the one people like most.
