355 - ITG Air Intake filter vs OEM. You saw it here first :) | FerrariChat
355 ITG Air Intake filter vs OEM. You saw it here first :)
Discussion in '348/355' started by ShineKen, Mar 29, 2022.
  1. ShineKen
    ShineKen F1 World Champ
    19,369
    Southern California
    Nostradamus
    All foam. No plastic/rubber bits to block air flow :).
  2. Carmellini
    Carmellini Formula Junior
    Jul 16, 2019
    899
    Look nice! Do you anticipate a specific benefit?
    JoeCab likes this.
  3. ShineKen
    19,369
    Southern California
    Nostradamus
    I’m thinkin’ 50hp gains and F1 sound, but if I don’t get that, I still would save roughly 2 lbs :).
    sbenus and Carmellini like this.
  4. IvanRico
    IvanRico Karting
    197
    Westchester NY
    Ivan Rico
    Don’t forget the zen like experience of adding washing and oiling filters to your annual maintenance. ;)
    moehler and ShineKen like this.
  5. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Dont over oil it gets on the maf sensor.
    ShineKen likes this.
  6. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,153
    CT
    John Kreskovsky
    Great for lawn mowers, snow blowers and chain saws. ;)
    GatedF355GTB likes this.
  7. ShineKen
    19,369
    Southern California
    Nostradamus
    ITG Foam filter uses a different type of oil used on say a K&N.
    https://www.lotustalk.com/threads/finally-a-real-air-filter.107603/
    "Good question-- and another annoyance of fabric filters is the light-weight oil that always finds its way to the MAF and IAC (for DBC cars). The foam filters use an entirely different kind of oil.
    Foam filter oil from No-Toil, for an example, spray on thin. You work the oil into the filter and then let the oil setup/dry for an hour or two... Once it drys, it become very tacky-- a bit like "bar and chain oil" for those who work in the yard Image Unavailable, Please Login This tacky oil stays in the filter and typically doesn't make a mess of the MAF sensor like KN oil does...
    We pre-oil all the ITG filters before shipping, so the first oiling is on us. You can surely go a few oil changes between cleanings under normal use without worrying about performance degradation... On the other hand, fabric filters should really be cleaned every oil change or after every long track weekend, as the tire particulates will clog them up."
    I ran ITG filters on both my Exige and Scud. Scud since 2017.
  8. ShineKen
    19,369
    Southern California
    Nostradamus
    They also come pre-oiled. At $200 a pair... you can choose to clean them if they're not too dirty or simply replace them if they are.
  9. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Kn oil is also tacky, so is every other foam filter oil, go to a motorcycle shop and there's shelves of the stuff .
    Sent using FerrariChat.com mobile app
  10. ShineKen
    19,369
    Southern California
    Nostradamus
    Just because they are both tacky, doesn't imply they are the same. A foam filter uses a different oil than a fabric filter.
    https://www.boefab.com/products/itg-cold-air-box-rev300-400-itg-cab
    "Foam filters allow for better filtration and much better airflow when dirty compared to fabric or paper filters. In addition, the tacky foam filter oil stays on the filter media and reduces residue on the Mass Air Flow (MAF) sensor when compared to lighter weight oils that become air-born found on fabric filters."
    One only need to periodically inspect their filter and MAF (probably same time as an oil change) to get an idea of what the foam filter and oil is doing. The same filters are still on my Exige and Scud since 2017. Zero MAF damage. Is 5 years enough time? Both cars running stronger than ever.
  11. PaulK
    PaulK F1 Rookie
    4,769
    Michigan
    Paul
    I've used No Toil on my ATV foam air filter. It is really easy to clean if you use their cleaner. However I wouldn't use oiled filters in cars like this due to the MAF.
  12. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,071
    Josh @jtcarprojects
  13. ShineKen
    19,369
    Southern California
    Nostradamus
    On a side note. Everytime I’ve inspected the filters, I’ve never had to clean it. They’re pretty clean. If I had to clean, a damp cloth with a few swipes off the flat surface would suffice. This isn’t an intricate cone.
    There’s a difference between what filters to choose if you drive 2k mi/year vs 20k mi a year.
  14. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,629
    SoCal LA/OC/New Mexico
    Tim Dee
    I been using K&N foam filters on racing bikes since 1971
    Never an issues oiling them babies up
    308 GTB likes this.
  15. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Every bike I ever had had foam filter, pj1, no toil, tons of brands the idea that that filter has some secret sauce oil is kind of funny is all. It's not lying it's marketing. [emoji39]
  16. sbenus
    sbenus Formula Junior
    414
    San Juan
    Simon
    really 50hp?
  17. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,636
    Do you have flow bench numbers for the new-factory filter, and dirty-factory filter, and your filter in new and dirty conditions ??
