It's ALIVE! | FerrariChat
It's ALIVE!
Discussion in '308/328' started by Brian Harper, Jun 4, 2007.
  1. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    #1 Brian Harper, Jun 4, 2007
    I'd just like to say thanks to everyone here. I've been doing a major service on my GT4 and there's no way I would have done it without all of the F Chat help. I took the first belt cover off just before Christmas and took it for its first real drive yesterday. Along the way I replaced timing belts and tensioners, cam seals, water pump bearings and seal, water pump nipples, alternator, fuel accumulator, fuel and oil filters, oil pressure sender, coolant hoses and fuel lines, fuel lines, light bulbs, spark plugs, gaskets, gaskets, adjusted cam timing, one coil, swapped points for Pertonix electronic pickups, cleaned, painted or polished everything I touched, and replaced a whole bunch of rusty hardware with stainless nuts, bolts, washers and hose clamps.
    The drive was great. The engine pulls OK until 4k, then it just sings from 4k to 7k, and will go to redline easily. I went up into hills (Hwy 9 in Saratoga for the locals) and drove it harder than I ever did before the service. Windows down, twilight (deer time), headlights on (alternator works now!) I never pushed it hard enough to get tires to squeal, but I could hear the tires bite through curves. The car is very predictable, always doing what I wanted, always communicating how things are going. Add throttle in a turn and you'd better be turning the wheel a little more, because it is going to push, let off in a turn and you'd better be giving it a bit of uwind, because that push goes away quick. But always the same, always predictable. I didn't want to find any strange mid-engine handling surprises (yet), like the MR2 that is famous for swapping ends before you can say " What the #%**&%?!??" Just keeping a rhythm up the hill, enjoying the music.
    About seven miles to the top, pulled into the overlook. Oil that I got on the headers is burning off, little plume of smoke rising from the engine bay. I don't have the engine cover on yet - not that optomistic yet -and gave everything a check over. Still one oil leak, rear distributor base gasket or cam end seal or distributor o-ring, or something like that over there. The rear header is glowing a little in the dark, I can just see it through a hole in the shielding. I can't tell if the front header is the same. Is this an issue or just a result of hard running and good insulation? I need to recheck timing, etc, just to be sure, and since the distributor is coming off for the oil leak I'll be doing that anyway.
    I actually coasted back down the hill, pushing harder and harder braking later, carrying more speed through the turns, stock sized tires never squealed. I'm sure that very mildly sporting sedan sold today will both out-accelerate and out manuever the GT4, but the car just sounds and feels so right, everything just filled with sweet goodness.
    I took the freeway home, pulled hard on the uphill on ramp, cruised for minute to check conditions, down shifted and pulled hard through third and fourth and it goes just fine. The speedo doesn't work (always something!) but I pulled to 7k in fourth before letting off, I'm sure in "go to jail" speed territory. Sweet the whole way.
    Still a whole lotta work to do on the car, but it should be a rolling project for now. Speedo, brakes, suspension bushings, etc., etc. So I'll still be around for more questions, but so far, it is good.
    (I'll include three pics. First pic is the engine, second is the pile of stuff I replaced, third pic is a so-so pic of the engine when I got the car)
  2. JohnnyS
    JohnnyS F1 World Champ
    Oct 19, 2006
    15,284
    Illinois
    That is just awsome!!
    Congrats on that major service.
    Pics are great. Do you hire out?
  3. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    Finally getting some benefits from your work huh? Sounds like a great drive and the satisfaction of doing the work yourself is priceless.
    Great looking engine bay!!!
  4. davem
    davem F1 World Champ
    10,969
    Stepford, Connecticut
    dave m
    Looks great!
    Where did you get the FI? Imagine it came complete with another 2 valve engine?
  5. jimshadow
    jimshadow F1 Veteran
    Feb 19, 2006
    6,257
    Indiana/North Carolina
    JIM
    That is just AWESOME!!!
    Great write up, can't wait to hear more and more.
    Enjoy the driving!
    JIM
  6. Mr. Nice Guy
    Mr. Nice Guy Formula Junior
    Apr 11, 2007
    301
    Southern NH
    Eric
    A thing of beauty!!
  7. DavidDriver
    DavidDriver F1 Rookie
    May 9, 2006
    4,424
    Grass Valley, CA
    David Driver
    Way cool!
    Thanks for sharing.
    Used to go Hwy9 almost every weekend in my buddy' 250+hp MGB, back in the 70's.
    Those were "the days"! Well, at least they were for me ;)
    Did you take it through the "hair-pin" turn yet?
  8. Mr. Nice Guy
    Apr 11, 2007
    301
    Southern NH
    Eric
    Holy crap! 250 hp MGB??
    I had a 77 MG... had it pretty well tuned out about 120hp! Had dual webber side-draft carbs, monza exhaust w/ header... stripped out all the emission junk... and tore out every piece of Lucas crap and replaced it with Bosch.
  9. 350HPMondial
    350HPMondial F1 Veteran
    5,336
    Edwardo
    Brian,
    Very nice! I can't wait untill I can get to your levelon my 1981 Euro Mondial 8..
    Where did you get your aircleaner,,,,?
    I want one like that.
    Edwardo
  10. DavidDriver
    May 9, 2006
    4,424
    Grass Valley, CA
    David Driver
    Yeah it was a pretty wild ride. ground an, bored, and maxed over-sized valves, 12:1 or 13:1 comp pistons.
    A lot of HP for a '67, but very very unreliable.
    The darned thing kept spinning bearings. :rolleyes: Little wonder!
    He had a lot of money into the car. Most of the work done at Tony's British on El Camino in Sunnyvale.
    It had so much torque, you had to turn the steering wheel when taking off, just to keep it in a straight line.
    When a new turbo charged MGB passed him one day on Lawrence near Homestead, he finally gave-up on it, and bought a Mustang.
  11. SonomaRik
    SonomaRik F1 Veteran
    awsome!!!! congrats
  12. doug328
    doug328 Formula 3
    Mar 11, 2004
    1,599
    The Space Coast, FL
    Doug B
    congrats on all the fine work, that engine looks great. It's such a special feeling to drive the car after you have done the work, more of a rewarding experience. Keep driving and enjoying.
  13. dstacy
    dstacy F1 World Champ
    Jan 23, 2006
    11,999
    GMT -5 & GMT +1
    Dave
    "cleaned up"?
    I'll say, sure looks good.
  14. DavidDriver
    May 9, 2006
    4,424
    Grass Valley, CA
    David Driver
    Been on the Treo all day long, and have been waiting to get home to see it on "The BIG Screen".
    Whoa! What a GREAT LOOKING detail!
  15. TGF
    TGF Formula Junior
    May 1, 2007
    319
    North Central, MA
    Tom
    That must feel really good. :) I hope to be able to do that one day.
  16. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Just mind blowing spectacular!
    That is a wonderful engine and it must go and sound marvelous.
    Brilliant, brilliant work!
  17. DavidDriver
    May 9, 2006
    4,424
    Grass Valley, CA
    David Driver
    +1
  18. Brian Harper
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    Came with the car when I got it. I don't know what I got from a donor car, but I have few things that don't belong like later intake cams and steel cam belt pulleys in addition to the CIS.
  19. Brian Harper
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    #19 Brian Harper, Jun 4, 2007
    First of all, no you don't. It is too small, I'm sure that it doesn't flow enough and I bet the car would pull better up high with out it or with a better design. Maybe I'll try it once and see what it is like. If/when I dyno the car I'll definately do a run with out it and see what ti is costing me in hp.
    But it is a custom piece made from a Mondial 8 air cleaner housing. Just chop yours up and weld it back together smaller. I have the middle part they chopped out with the Ferrari silkscreening and part number. I used it as a pointer for degreeing the cams.
  20. thecarreaper
    thecarreaper F1 World Champ
    18,120
    Savannah
    daaaaamn ! thats cool!
  21. thecarreaper
    18,120
    Savannah
