Jack stand positioning | FerrariChat
Discussion in '308/328' started by Frisky, Dec 14, 2019.
  1. Frisky
    Frisky Karting
    Apr 26, 2014
    230
    MA
    Rolfe Lofmark
    Hi all,
    I have been lurking on the site since I bought my 308 about six year ago. When I bought it I knew it had been sitting for years and it would need a going through including timing belts, tensioners, and a bunch of other maintenance before trying to start it up. Anyway, it has sat untouched in my garage since the day I bought it.
    That being said, there is a guy with a 308 GTSI in my town who has been giving me a hard time to get it going. I made the trip to harbor freight and got some jack stands and other equipment to begin the work. Today I began the work.
    I didn’t see anywhere else to put the jack stands.
    If the experts out there could confirm the location It would be appreciated.
  2. Frisky
    Frisky Karting
    Apr 26, 2014
    230
    MA
    Rolfe Lofmark
    One more question. If I want to jack the front on stands, I see no place to put them. I researched the diagram out in other threads, but jack stands can’t locate in those spots covered by panels. Do the panels need to be removed in the front?
  3. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,360
    https://www.ferrarichat.com/forum/posts/135076261/
    This has always been the definitive diagram for where to put stands under a 308/328.
    Never jack or support the car on the sills.
    As a general rule you are not going to go too far wrong placing them under the chassis as close to suspension pick up points as you can get them. I prefer to use stands with flat tops & rubber pads under the square section rubes though.
    As advised by one of the well respected indis hereabouts if you just want to lift the rear then its fine to jack it under the rear cross member behind the engine (but I put a couple of bits of hardboard between the frame rail & the anti-roll bar below when I do that).
  4. Vonbarron
    Vonbarron Formula 3
    2,289
    Westside Mofo
    S B
  5. Portofino
    Portofino Formula Junior
    Sep 17, 2011
    953
    Yorkshire UK / Switzerland/ Antibes France
    Portofino
    How easy is it to remove the big under panel ?
    Like to do that one day to apply anti corrosion product .
  6. Frisky
    Frisky Karting
    Apr 26, 2014
    230
    MA
    Rolfe Lofmark
    Than you for the panel off view. Very helpful.
    I tried getting the jack stands as far out as possible, but my lift jack was using the lift point to get the jack stands in place. That was as far outboard as I could get them. Maybe there is a better technique to getting the jack stands in place? Either way, you can see where I have them placed in the top picture. Think that looks safe enough to do the belt service and other engine maintenance jobs?
  7. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,614
    California SF bay area
    Paul
    I'd say you're a bit too far forward with the aft stands. You're even with the factory jack pad which is nearing the balance point since it's designed to lift both front and rear wheels on that side at the same time. I can't say for certain but if you were to lean over the trunk with your full body weight it's possible you could lift the front end. I know it doesn't look that way but there is a weight bias towards the rear on these cars. A better location for the stands is further back where the wing rails are gusseted to the main rails of the frame. You'll see the triangular plates at that location.
  8. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,360
    +1 , in line with the jacking point is a very bad place to put them, its the balance point of the car. Very dangerous if you then have the whole car off the ground with the front lifted as well. The thing is quite likely to tip backwards off the stands.
    Stands at the rear want to be somewhere in line with the rear axle line & at the front on the triangle just to the rear of the front wheels as per the diagram I linked to above.
  9. Frisky
    Frisky Karting
    Apr 26, 2014
    230
    MA
    Rolfe Lofmark
    Thank you, will work on getting a pair at the furthest aft points.
    Will search on removing the protective plates. Probably something in the archives in that.
  10. Tustin308
    Tustin308 Rookie
    May 20, 2019
    39
    Tustin, CA
    Arthur Trejo
    I agree. The rear stands are too far forward. Here are some pics of my 308 on stands. Notice the placement of the rear stand just forward of the engine. One tip, I removed the front spolier to fit the front jacks. It made it easier to place them.
    Nuvolari, Portofino and miketuason like this.
  11. TommyA
    TommyA Formula Junior
    Oct 7, 2002
    549
    Atlanta
    Tommy A
  12. robertgarven
    robertgarven F1 Veteran
    Feb 24, 2002
    5,322
    Ventura, California
    Robert Garven
    Friends,
    Here is an old writeup I did, its for a GT4 but the frames are similar I think.
    Rob
    Hannibal308 likes this.
  13. Frisky
    Frisky Karting
    Apr 26, 2014
    230
    MA
    Rolfe Lofmark
  14. Frisky
    Frisky Karting
    Apr 26, 2014
    230
    MA
    Rolfe Lofmark
    Great guide on jacking it up. Unfortunately my car is not running yet so I can’t drive it up on ramps. Love the comment about don’t do it while drinking and the other self preservation tips. Great stuff!
  15. robertgarven
    Feb 24, 2002
    5,322
    Ventura, California
    Robert Garven
    Rolfe,
    Thanks, I envisioned a whole series of those until I found out how little I knew, but I did complete a cooling, gb and oil change ones. I have lifted it up with out ramps, but it takes a bit more care, 3 floor jacks and patience to do it safely. Well that was at least me, not sure how others would do it....
    Rob
  16. Hannibal308
    Hannibal308 F1 Veteran
    Jan 3, 2012
    7,177
    Arizona / Hawai’i
    Hannibal
    Pass on your other guides...nice work!
