360 - Jacking up 360 | FerrariChat
360 Jacking up 360
Discussion in '360/430' started by jfor348, Oct 9, 2020.
  1. jfor348
    jfor348 Rookie
    Apr 14, 2016
    29
    Vancouver
    John Foreman
    Need a bit of help here. I just purchased a 360 Spider, and I’m having the wheels re-finished. They just don’t mach up with the rest of the car as far as quality of finish. Also I’m cleaning everything I can while they’re away. I lifted the car with an aluminum racing jack, then blocked it up under the frame, then added a typical car jack under the jacking point that I originally lifted it with, as in the photo, just as an added measure of protection. I’m going to need to do this at the rear when I get the fronts back. My problem is I’m not exactly sure where, at the rear, I can put my blocks. I just can’t really see things as clearly as I could at the front. Could anyone recommend an appropriate spot where it’s safe to block? Thanks!
  2. Chrisv123
    Chrisv123 Karting
    108
    Chris
    In front of the rear wheel well, the circle.
