Jacking Up A 458 | FerrariChat
Jacking Up A 458
Discussion in '458 Italia/488/F8' started by glennglenn, Mar 31, 2013.
  1. glennglenn
    glennglenn Rookie
    Jun 4, 2006
    18
    I want to jack up my 458, anyone know where the rear jacking points are.
  2. leead1
    leead1 F1 Rookie
    Nov 29, 2006
    2,828
    Florida
    Lee
    #2 leead1, Mar 31, 2013
    I would ask a dealer. I would look at my manual but the car is in my storage area. I use my Orlando dealer to come and get the car or fix a flat. I have bought three F cars from them and know them well and the dealer is great. I would call and ask the dealer. If you look at the chasis at the rear you will see the strength lift points I suspect. To be honest I have never looked.
    Be careful on this web site! There are alot of nice people on this site some are even dealers but there are also kids who are just playing. It can be hard to know who you are talking to if you do not have an idea of the correct answer.
    They try to police this forum and I have seen several banned for a little time. But they come back. All forums have the same problem.
    Good luck :)
    Lee
  3. not4one
    not4one Formula Junior
    May 23, 2010
    887
    CT, FL
    As I recall from lifting mine (to put on the spacers), there are round reinforced metal areas (disc like in shape) a few inches behind the front wheels and a few inches under when looking from the side. At the rear the same point is FORWARD of the rear wheels. You need to get on the floor and look/feel around...but they are obvious once you find them. I used a compact 1.5 ton floor jack (the type on small wheels) and had no trouble using those points.
  4. garak
    garak Formula Junior
    Dec 28, 2010
    303
    Florida/Arizona
    #4 garak, May 28, 2015
    Sorry to dig up an old thread, but I searched and didn't find anything definitive on this.
    Are these the jacking points for the 458?
  5. rockitman
    rockitman F1 Veteran
    May 31, 2015
    5,989
    Upstate, NY
    Christian
    It's impossible to tell by the pictures in the manual. I am assuming that is the rear jack point where the hole is. There is a similar hole very close to the front wheel well. I can't imagine there is any other option. Seems most people here take the car to the shop. Confrmation by someone who has lifted their 458 would be appreciated.
  6. Jasone
    Jasone Formula 3
    Nov 15, 2011
    1,203
    Tampa Florida
    Jasone
    I jack mine all the time, that is the correct spot.
  7. rockitman
    May 31, 2015
    5,989
    Upstate, NY
    Christian
    Thanks Jasone.
  8. luvair
    luvair Formula 3
    1,584
    #8 luvair, Aug 6, 2015
  9. abstamaria
    abstamaria F1 Rookie
    Feb 11, 2006
    2,668
    Andres
    Porsche 911s, or at least from the 993 on, have special metal lifting pads that fit into holes in the jacking points. One then positions the lift or jack so they contact those removable pads. Luvair's attachment suggest there are similar pads - bushes - that fit in the holes, one shown in garak's photo above.
    I have a two-post lift at home and was wondering how to lift the 458.
    Best,
    Andy
  10. justthebest
    justthebest Formula Junior
    May 14, 2014
    319
    Denver, CO
    Many M-B AMGs also have specific inserts to make a large enough area (drink coaster size) to properly jack with any equipment.
  11. maxvonauto
    maxvonauto Karting
    May 23, 2015
    159
    Corona
    Mark
    The rears are a pain. You'll need a low profile long nose jack to get that far under the car without hitting the skirts. Plus, the hard points are recessed a bit so you'll need a small block of wood on top of the jack pad. The only way I was able to get my std floor jack to work was to use a scissor jack first to gain some clearance for the floor jack.
    Frankly, there's not much you can do other than service the wheels/brake pads, etc. The aero panels virtually cover every square inch under the car. You'd think Ferrari would have made plugs under the various drains so you can change trans and engine oil without dropping the diffuser and engine pan (which is a major PITA).
  12. MuratC
    MuratC Formula Junior
    Jul 6, 2014
    539
    Istanbul, Turkey
    Like Mark said, I also use 2 floor jacks. I first raise the front a bit and then slide the second jack underneath for the rear. Otherwise if I try to raise the rear first, the arm of the jack touches the side skirts.
  13. luvair
    luvair Formula 3
    1,584
    I'm familiar the chassis holes with the Porsches, and have special hockey type pucks that make the Porsche lift points to easily identifiable and importantly, use of the lift.
    That said, I didn't see the same on my 458. I have a Rotary two post lift, and even purchased the thinner arms for a low profile sports car. It still was not thin enough, so needed to purchase race ramps to raise the car b4 finding the jack points. At least to me, its still a bit of challenge as my 458 has CF rocker panels, and the clearance is still very tight. What helped me some was going to y dealer and visibly seeing the jacking points.
  14. abstamaria
    Feb 11, 2006
    2,668
    Andres
    The pages you posted are from a workshop manual, Luvair? I wonder if Ferrari sells those "bushes" or "bushings" for lifting.
    Andy
  15. abstamaria
    Feb 11, 2006
    2,668
    Andres
    #15 abstamaria, Aug 7, 2015
  16. abstamaria
    Feb 11, 2006
    2,668
    Andres
    #16 abstamaria, Aug 7, 2015
    I took this photo to show how the Porsche items look. The tabs fit into holesin the chassis. I wonder if I can modify these to fit my 458.
  17. rockitman
    May 31, 2015
    5,989
    Upstate, NY
    Christian
    As far as getting the jack under the rear points without hitting the aero skirts, it might be helpful to drive the car up on 2x10" planks too get the extra clearence. That is what I am going to do if I need to remove the wheels.
  18. rockitman
    May 31, 2015
    5,989
    Upstate, NY
    Christian
    I wonder if the Ferrari dealer can order the jack pad/pin they use on their lifts for the 458 ? I would think one could use that same pad/pin set up on a floor jack.
  19. luvair
    luvair Formula 3
    1,584
    #19 luvair, Aug 7, 2015
    I don't think so. My dealer and I use plan hockey pucks, and they work well.
    Car on lift is not a Ferrari, but provides idea how I use the hockey pucks on my Rotary lift.
  20. luvair
    luvair Formula 3
    1,584
    I have the same for my 911. But could not retrofit for the 458 without ruining them for the 911. Pls see my post b4 this, as plain hockey pucks work well, and do not overlap to non jacking points.
  21. rockitman
    May 31, 2015
    5,989
    Upstate, NY
    Christian
    I have a healthy supply of hockey pucks I used on my 911. I also have low profile jack point stands that have a smaller diameter 1/4" thick hard rubber disc that looks like it will fit inside the under tray surrounding the jack point area....if a hockey puck is too wide. I have not jacked the car (458) up yet to know for sure.
    http://www.jackpointjackstands.com
  22. abstamaria
    Feb 11, 2006
    2,668
    Andres
    I must order hockey pucks. l live in the tropics, so they don't exist here.
  23. Drifting
    Drifting Karting
    Jun 28, 2013
    55
    Los Angeles
    I don't think people are referring to actual hockey pucks that you would play hockey with, just that they look like hockey pucks.
  24. rockitman
    May 31, 2015
    5,989
    Upstate, NY
    Christian
    I use real hockey pucks...very hard rubber and work well. They don't deform much under the weight load.
  25. luvair
    luvair Formula 3
    1,584
    Me too. Been using real hockey. Work great.
