Jag experts pls help | FerrariChat
Discussion in 'British' started by Jerrari, Dec 25, 2010.
  1. Jerrari
    Jerrari F1 Veteran
    Jul 24, 2001
    5,469
    Michigan
    Jerry Wiersma
    I am looking at a '98 XJ8L w/ 72,000 miles for $5800 obo. It is in pristine condition & loaded. I would be buying this for my daughter. I know next to nothing about Jags, so could someone pls tell me the potential trouble areas on these cars? Trans, electrical, engine, etc? Thanks in advance! Jerry.
  2. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #2 2NA, Dec 25, 2010
    That pretty much covers it. ;)
    The car is probably due for a timing chain tensioner.
    IIRC cup holders break frequently.
    The early V8s had problems with Nikasil cylinders. Some engines were replaced under warranty.
  3. Glassman
    Glassman F1 World Champ
    I've never owned a Jag that new but after owning and driving many, I would suggest that you buy your daughter a Toyota. Especially if it is intended to be her primary source of transportation.
  4. Jerrari
    Jerrari F1 Veteran
    Jul 24, 2001
    5,469
    Michigan
    Jerry Wiersma
    I know that is the practical thing to do, but she likes unique cars as I do, so was just wondering about reliability on these cars. I was hoping to get a response of "they are bullet proof, go for it". I guess no such luck. :(
  5. bergxu
    bergxu Formula 3
    Aug 16, 2005
    1,307
    OnTheSerpentMound
    Aaron
    Yep, make SURE the chains and tensioners have been done. If not, definitely plan on doing them ASAP. $2,500 at an indie, $3,500 at a dealer.
    All Jag V8s until those made on August 13, 2001 at 10:43am and later had Nikasil-lined bores. Be careful if the car has low mileage on it, as it was short trips that caused the wear to accelerate. I'd strongly suggest a compression test on any early ('98-mid '01) V8.
    Beyond that, they're actually very good cars. Plenty of Bosch electronics and other reliable systems. But if you're after an XJ of that generation, you'd be better off with an earlier ('95-'97) six cylinder car. That engine, the AJ16, is absolutely bulletproof. They'll run 250K without even batting an eye.
    PM me if you want more info. I work on them every day.
    Cheers,
    Aaron
  6. kevfla
    kevfla Formula 3
    Nov 20, 2003
    2,086
    gone 4 good
    +1 on the AJ16 engine.
    Mine just turned 175,000 miles this afternoon on my '96 VDP. Still pulls like a freight-train when you step on it. The leather quality could be better though. This is my third XJ6 ('81, '93, '96). Only one was ever on a flat-bed, the '93, when the fuel pump failed.
    Next summer I plan to look for a '05-'06 Super V8 that I'll try to keep for 5-10 years. I will miss the sleekness of the X-300/308 body shell. Lighter exterior colors will make the eventual parking lot door-dings less noticeable than black or the dark, really dark, green.
    When you find a prospective car, ask if the Bosch ignition coils (on-plugs) have been replaced. The housings crack, causing a misfire. The "flexjoint," the rubber spacer that mounts between the driveshaft and the differential deteriorates and will likely need replacing due to age. But overall, the cars are very robust and not difficult to work on (the 6s). The V8 may be a different story.
    KevFla
    Orlando
  7. Jerrari
    Jerrari F1 Veteran
    Jul 24, 2001
    5,469
    Michigan
    Jerry Wiersma
    Thank you very much for the advice guys, much appreciated!!
  8. 76Steel
    76Steel Formula 3
    Sep 8, 2007
    1,482
    New Jersey
    +1 on Aaron's views.
  9. Arvin Grajau
    Arvin Grajau Seven Time F1 World Champ
    Jun 7, 2006
    78,325
    Wurundjeri man.
    Arvin Grajau
    My parents bought new in 2000 a 4.0litre sovereign been a great car,spent money on a new transmission and a new water radiator apart from that been trouble free.
  10. Carbureted308GTB
    Jan 12, 2011
    5
    North Scottsdale
    Chris
    Not a very good choice for your daughter. I don't mean Jags in general, but I have been driving them a long time. Nothing but the bulletproof 4.0 Inline-6 motor that's in my 1996 XJR. 1998 is the first year Ford started dumping their V8s into the XJ, which had LARGE issues until the tail end of 2001. Timing chains, transmissions, Nikisil issue with cylinder walls as mentioned above, and general value of the car is pitiful.
    To put it into perspective I bough my 96 XJR for $7500 with 60K miles...the X300 (1995-1997 XJs) are indestructible, perhaps the best years anyone could ever own a Jaguar after Ford invested a ton of money to get rid of notorious electrical reputations Jag had in earlier years.
    1995-97 cars are same body style as the 1998 you mentioned (and was used until 2003) but 98-03 models have sharper headlights, taillights, turning lights, heavily revised interiors, new transmission, and the V8s that were terribly unreliable for the first couple years, which is why those 98/99/00 XJ8s and XJRs are so dirt cheap.
    If you're looking for a Jag for your daughter 95-97 cars are without a doubt the best choice you'll make. Find one with relatively low miles 60K-80K and you'll be fine. I'm not kidding the I6 4.0 motor is a TANK. A very nice example XJ6 from 95-97 will run you around $5K-6K. I doubt your daughter needs the XJR I have, which has special points to look out for that the regular XJ6 doesn't have to worry about.
    Hope this helps! Oh yea, and join Jaguar Forums! :)
  11. bergxu
    bergxu Formula 3
    Aug 16, 2005
    1,307
    OnTheSerpentMound
    Aaron
    Jerry,
    Sent you an email.
