Jalpa thread | Page 3 | FerrariChat
Jalpa thread
Discussion in 'LamborghiniChat.com' started by SVJTech, Nov 12, 2009.
  1. SVJTech
    SVJTech Rookie
    Apr 1, 2009
    36
    Western US
    Jason F.
    Yes- we did - those may have been placed into the round filing bin.. That was a part of the testing - we did find it necessary to run it a bit on the richer side on the lower end, and then lean it out to a “close but still slightly rich” A/F ratio for the rest of the rpm range, up to 7100 - due to the best efforts in jetting combination. Rev limiter kicks in at 7000.
    Load bearing dyno with sporadic pavement testing…
    --Jason
  2. House_Counsel
    House_Counsel Karting
    Jan 28, 2009
    105
    White Plains, NY
    #52 House_Counsel, Nov 25, 2009
    I have MSD. It was installed before I bought the car.
  3. House_Counsel
    Jan 28, 2009
    105
    White Plains, NY
    I heard they were made by Koenig. There's a guy in NY with a set for sale.
  4. SVJTech
    SVJTech Rookie
    Apr 1, 2009
    36
    Western US
    Jason F.
    I'm curious if anyone out there with a Jalpa also has a BMW M1 - it's been thought they may share some common traits..
  5. SVJTech
    SVJTech Rookie
    Apr 1, 2009
    36
    Western US
    Jason F.
    Anyone remember / know about the 1983 Monaco Grand Prix Pace Car Jalpa?
  6. hyenahf
    hyenahf F1 Rookie
    May 25, 2004
    2,603
    first of all ive never driven a M1..so most of this is conjecture.
    although the bmw m1 was to be built by lamborghini (code name E26) and they did most of the R&D work, i dont think they have a lot in common technically.
    many differences:
    deschamps vs gioguaro, stanzini/alfieri vs dallara, transverse vs longitude, tube frame vs unitbody, wishbone/trailing arms vs macpherson, iron I-6 vs alloy V8 , coupe vs targa, fiberglass vs steel, injection vs carbs
    the closes car i can think of is a pantera, same zf gearbox, designer dallara, layout longitude. the performance, power and weight are comparable too
    from the road test ive read they are fantastic drives and are starting to be fairly sought after. price has doubled in the last 5-7 years
  7. SVJTech
    SVJTech Rookie
    Apr 1, 2009
    36
    Western US
    Jason F.
    Interesting Comparison -
    This is meant just as a comparison of the philosophy in each - no intention of stating in any way or implying, more or less for either / or...
    BMW M1
    Production: 455 cars (399 road, 56 race)
    Cylinders: 6 in-line, mid mounted
    Capacity: 3453cc
    Power: 277hp @ 6500rpm
    Torque: 243lb @ 5000rpm
    Weight: 3175lb
    Max Speed: 162mph
    Acceleration: 0-100kmh(62mph) in 5.6sec
    Fuel Consumption: 14.4mpg
    1st gear ratio : 2,420
    2nd gear ratio : 1,610
    3rd gear ratio : 1,140
    4th gear ratio : 0,846
    5th gear ratio : 0,704
    Rev. gear ratio : 2,860
    Final drive ratio : 4,220
    Front Wheels/Tires: Alloy 7x16 205/55 VR16
    Rear Wheels/Tires: Alloy 8x16 225/50 VR 16
    Engine Management System: Kugelfischer-Bosch Mechanical injection
    Brake Disc diameter, front (mm) 300
    Brake Disc diameter, rear (mm) 297
    Wheelbase 2560 mm
    Track, front (mm) 1550 ( In ProCar Trim 1345)
    Track, rear (mm) 1576 ( In ProCar Trim 1578)
    Overall length : 4360mm
    Overall width : 1922 mm
    Overall height : 1140 mm
    Ground clearance: 125
    L. Jalpa
    Production: 420
    Cylinders: 8 90degree, mid mounted
    Capacity: 3485 cc
    Power: 255 bhp at 7000 rpm
    Torque: 231 lbs.ft. at 3500 rpm
    Weight: 3 329lb
    Max Speed: 146
    Acceleration: 0-100kmh(62mph) in 7 sec
    Fuel Consumption: 14.5 mpg
    1st gear ratio : 2.933:1
    2nd gear ratio : 2.105:1
    3rd gear ratio : 1.565:1
    4th gear ratio : 1.185:1
    5th gear ratio : 0.870:1
    Rev. gear ratio : 2.775:1
    Final drive ratio : 4.00:1
    Front Wheels/Tires: Alloy 7 x 16 inch 205/55 VR 16
    Rear Wheels/Tires: Alloy 7.5 x 16 inch 225/50 VR 16.
    Engine Management System: Weber
    Brake Disc diameter, front (mm) 274 mm
    Brake Disc diameter, rear (mm) 274 mm
    Wheelbase: 2451 mm
    Track, front (mm) 1500 mm
    Track, rear (mm) 1554 mm
    Overall length : 4330 mm
    Overall width : 1880 mm
    Ground clearance : 127 mm
    Again - meant only as a comparison on the thought process going on / in and of the design with each auto..
  8. Jalpa_Mike
    Jalpa_Mike F1 Rookie
    Apr 2, 2004
    3,019
    Sequim
    Michael Wilson
    #58 Jalpa_Mike, Dec 1, 2009
  9. hyenahf
    hyenahf F1 Rookie
    May 25, 2004
    2,603
    that m1 used to be in our area before it was sold. it a pretty butchered up version of the original car.
    it would be nice to bring it back to its original state or do a procar replica
  10. SVJTech
    SVJTech Rookie
    Apr 1, 2009
    36
    Western US
    Jason F.
    I was curious if anyone has seen or done other in depth testing with the Lamborghini V-8?
    With the usual 'magic number' of 100 hp per liter, it seems like there should be a few others who have tried to get the V-8 there..
  11. Peter K.
    Peter K. F1 Rookie
    4,450
    Connecticut
    Peter K.
  12. hyenahf
    hyenahf F1 Rookie
    May 25, 2004
    2,603
    RVosari in CT has done some tuning on a P300 motor. new pistons, rods, were some of the detail i remember. i think he got 280 or so out of it. pretty respectable for a 3 liter
    its probably harder to get 100hp/litter with a 3.5 longer stroke motor.
  13. House_Counsel
    Jan 28, 2009
    105
    White Plains, NY
    Can anyone tell me why our cars are so "reasonably" priced? I have seen them priced anywhere from 30k-45k USD. The way I see it, they are so rare that they should be much more valuable. I think they are much more attractive, than earlier models like the Jarama and Espada. Wherever I go, people snap pictures and gravitate to the car, even when there are newer and much costlier cars around. I don't get it. It seems as though everyone loves the car, but no one wants to own it, so it has to have a bargain price to attract owners.
    Maybe I'm just in grouchy mood. I apologize if I offended anyone. But I'm not going to delete this post, in the hopes that someone might provide some great insight.
    Kevin
    1985 Jalpa red
  14. hyenahf
    hyenahf F1 Rookie
    May 25, 2004
    2,603
    maybe because a wheel bearing cost 10x more than it should?
  15. EMILIO
    EMILIO F1 Veteran
    Feb 23, 2006
    6,854
    Italia
    as a former jalpa owner (and as a jalpa lover!)
    i think they are a good buy at today prices, they could go up something but hardly MUCH imo
    and i think for some reasons, like:
    - jalpa cost almost as a much as a countach to restore-upkeep
    - the car is not near as fast as a countach
    - the car is not as mitical or looks as good as a countach
    so when you think you can still find good driver FI QVs in the 90k$, it would makes no sense to buy a jalpa at 50k$ or more...this keep the value of good cars in the 40k$ or so..
    i think if the "regular" countach value will go up (and it will imo) the jalpa value will somewhat follow
  16. Downdraft1
    Downdraft1 Formula Junior
    Nov 13, 2008
    803
    Hey, Urraco cars in the 1980s were even worse for re-sale value, as a former P250S owner I can assure you. As Emilio said, the upkeep costs are significant and any ground up restoration is an "act of love" because you will not ever have a return on investment. None-the-less 8 cylinder Lambos are fun and offer exceptionally good handling.
  17. The reason they are not expensive is the 8 cylinder engine. If it had a 12 cylinder it would be worth a good bit more. If you are fair, performance times match or beat many other exotics of the time. They are extremely rare, most have never seen one. I have seen two & one of them is mine. I have had more than a few comments , asking if that was a model that came before the Countach (ok to be fair, I have been ask if it was a Diablo several times). Most have never seen a Lamborghini, so I guess it catches them off guard. A Jalpa will draw far more attention than a TR or many other exotic cars. IMO they look so much better than a Espada, Jarma, and even a Islero (I like them all, just my preference). It's the 12 cylinder.
  18. EMILIO
    EMILIO F1 Veteran
    Feb 23, 2006
    6,854
    Italia
    you are correct the V12 is one of the reasons but it is not all there...
    an espada is not worth more than a jalpa in Europe...may be is less in the same conditions
    the jarama is around the same or slightly more than a jalpa
    the islero is more expensive, but it is RARE and has pretty nice shape that is appealing to many
    a silhouette is worth 50k euro or even more for a perfect one
    it is worth more than espada or jarama and still a V8,
    it is REALLY awesome looking inside-out and RARE
  19. EMILIO
    EMILIO F1 Veteran
    Feb 23, 2006
    6,854
    Italia
    i agree with everything you said
    now, if only i could find a nice LHD sil. for a fair price...
  20. ralfabco
    ralfabco Two Time F1 World Champ
    Mar 1, 2002
    28,029
    Dixie
    Itamar Ben-Gvir
    I obtained the enclosed message. An enthusiast is looking for a Jalpa. Can you try and help out the potential Jalpa buyer with any information ? Thanks.
    ________
    I was wondering if anyone in your club had a lamborghini jalpa? I have been looking at them online for a while now but one of my friends told me that I shouldn't because I would not be able to fit in them. In reality this friend has no idea because he doesn't have one. So I was wondering if anyone in this club has one. I'm 6'6" so I could see me not being able to fit into an older sports car like the jalpa.
  21. Jalpa_Mike
    Apr 2, 2004
    3,019
    Sequim
    Michael Wilson
    I am 6' 1" and wear size 12 shoes. I found the Jalpa to have PLENTY of headroom!!! I had no issues of fitting in it at all. I wore driving shoes, so I didn't have any problems with my feet hitting multiple pedals at the same time either.
  22. kc023515
    kc023515 Formula Junior
    Dec 5, 2007
    600
    Belgium
    Kevin Crauwels
  23. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,063
    Switzerland
    Raymond S.
    puuh, if this is an excellent car, what would a running example not having been in storage for 15 years be?
    Can someone call them for the VIN?
    From the leather piping it looks like a young one.
  24. Peter K.
    Peter K. F1 Rookie
    4,450
    Connecticut
    Peter K.
    Stay away.
    Unless money is no object.
    This is a total restoration that will cost as much as 2 nice examples.
  25. Olivier NAMECHE
    Olivier NAMECHE F1 Veteran
    Aug 18, 2007
    5,098
    CANADA
    Olivier
    Emilio, I agree with your explanations and I will also point the finger on the fact people looking for a rear V8 mid engine are also thinking about the myth "308 GTS" from the TV serie icon "Magnum's Ferrari" that is also really affordable... and unfortunatelly keeps Jalpa price low !!!
