Joining the ranks | Page 2 | FerrariChat
Joining the ranks
Discussion in '308/328' started by benino, Sep 16, 2025.
  1. nitro
    nitro Karting
    Dec 9, 2012
    188
    Snowmass/KenCaryl
    Is that the oil line with the "T" connector? If so...yup....make sure that is in perfect shape.
  2. aventari
    aventari Karting
    Dec 9, 2010
    197
    San Diego
    subnet67, dgalovich, ZikZak and 5 others like this.
  3. aventari
    aventari Karting
    Dec 9, 2010
    197
    San Diego
    Oil pressure seems a bit low, can't tell if the gauge and circuit are just old?
    Its around 5 or 10 at idle and goes up to approx 40 around 2000 and stays there from 2000 rpm up. Is that what the oil pressure relief valve is set at?
    I'd love to get a modern gauge on the oil pressure when we get home for a more precise reading
    There's no engine or valve noise or anything else I'd associate with low pressure and it's running very smooth and solid.
  4. aventari
    aventari Karting
    Dec 9, 2010
    197
    San Diego
    Just read some info and people say the gauge is notoriously inaccurate which makes sense.
    We are seeing the tach bounce every once in a while and drop to zero and for a little bit read half the actual rpm, which I assume because the ignition runs 2 banks of 4 cylinders and one was probably loose and dropping out.
    Drive is great otherwise! It does feel like the heater is on all of the time, but you guys warned us about that
  5. Dockboy
    Dockboy Formula Junior
    652
    Maryland
    Congrats on picking up your 308!
    That is typical behavior for the sender.
    If you want the oil pressure gauge to read correctly...you need this ;)
    https://www.ferrarichat.com/forum/threads/modern-oil-pressure-sensor-kit-for-3x8-mondial-etc.567312/
  6. benino
    benino Rookie
    Mar 6, 2025
    10
    Had a smooth ride first day. A little too hot in the car and way more traffic than I would have liked coming out of Portland but we got through it and into the nice open highway. Engine feels like it's running great. Got as far as Medford Oregon. The woman at the front desk of the hotel offered us a special parking spot where they would be able to keep an eye on the car. Everyone we see loves it. Had my first Magnum pI reference today. "Hey. That's the one from Magnum PI right? It's beautiful!". :p
    BenB, A12pilot, vinny72758 and 5 others like this.
  7. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,930
    Mike 996
    Re the oil pressure - the gauge indication is too low above 4000 RPM IF the gauge is correct. As noted, it may not be and can easily be checked with a manual gauge. It's probably the gauge/sender but needs to be checked. The gauge MIGHT be accurate within itself - although the indications are wrong, the needle may move in proper relation to pressure. In any case I wouldn't take the RPM past 5K until the oil pressure is checked and verified that it is within spec. As far as the gauge reading, of course it would be good to have it correctly display pressure but if the needle moves in correct relation with actual pressure, you could just "know" that and not worry about what it shows.
    I wouldn't buy anything at the moment other than a manual oil pressure test gauge/kit if you don't already have one. Once you have determined the actual oil pressure you can proceed with whatever steps you think appropriate.
    aventari likes this.
  8. ChevyDave
    ChevyDave Formula Junior
    Dec 21, 2019
    536
    Pacific Northwest, USA
    Dave W
    First thing the Help Desk will ask is if you tapped on the face of the gauge? :p
    I did notice within the last year that at cold start the needle would occasionally stick on "0" and require a light tap on the gauge face to start registering properly, but I never noticed the needle sticking while driving. The idle to 4k RPM pressure readings sound fine, but I agree with Mike about exceeding 5k RPM; better safe than sorry.
    One low-pressure situation that you need to be aware of - which I forgot to cover before you left and can be fatal to your engine - is the loss of oil pressure in hard right-hand turns. This is something all stock 308 wet sump engines share and a number of strategies exist for dealing with it: over-filling the sump, installing a sump baffle (what I would have done had I kept the car), or installing an Accusump system.
    However you choose to address it, the important thing is to avoid hard, right-hand turns until you do. IIIRC, you guys were planning to mainly use Interstates on your way home, so outside of attacking on and off ramps it shouldn’t be a problem for you. Just keep it in mind if you decide on any two-lane excursions.;)
    Finally, regarding the cabin temp: make sure both heater controls are in the Off/Fresh Air position. We had some very warm days in Portland last month and it’s possible I left the heat on.
    Otherwise, sounds like you guys are having a great trip; enjoy the run to SD today!
    - Dave
  9. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,534
    Dumpster Fire #31
    SMG
    Thread needs road pics!
    LE06, MacNugget and ChevyDave like this.
  10. benino
    benino Rookie
    Mar 6, 2025
    10
    Here are some highway shots. I've been pleasantly surprised with how comfortable it is to cruise in. Yes, there is heat coming from under the dash and the seats aren't perfect, but there are no squeaks and rattles, and it's not as noisy inside as I expected with when the windows are up. The chassis is also stiffer than I expected for a car without a solid roof. We also figured out how the AC works and we're able to use it a decent amount today.
    vinny72758, LE06 and MacNugget like this.
  11. benino
    benino Rookie
    Mar 6, 2025
    10
    We decided to drive into San Francisco to have lunch with an old friend. That turned out to be quite stressful. Traffic was a nightmare. At one point we were going slower than first gear idle speed for a full 20 minutes. Once we got through that we had to deal with the crazy streets and stoplights and stop signs on ridiculous inclines. I've included two shots out the windshield in San Francisco, and the common sight of me refueling.
  12. benino
    benino Rookie
    Mar 6, 2025
    10
    One more shot at a view point some distance south of San Francisco. Had to make an emergency stop to pee. Unfortunately the parking lot was mostly full and there was no restroom. And it's hard to take a surreptitious pee anywhere near this car! It's too low to hid anything and it's drawing everyone's stare. ...so everyone at the view point has a nice vista of a stream of pee coming out from behind a tree.
    We are still on the road. We decided to push through and get home tonight. As long as the car doesn't have other plans I should make it home just after 1am (2 hours from now).
    smg2, Michael DB, LE06 and 3 others like this.
  13. MacNugget
    MacNugget Formula Junior
    615
    Tejas Hill Country
    There’s no better way to bond with a new car than an epic road trip. Thanks for sharing the photos of your adventure, I love to see it. These cars are for driving, not polishing.
    ChevyDave and aventari like this.
  14. s219
    s219 Formula Junior
    Aug 26, 2021
    521
  15. aventari
    aventari Karting
    Dec 9, 2010
    197
    San Diego
    subnet67, TheMayor, dgalovich and 3 others like this.
  16. A12pilot
    A12pilot Formula Junior
    634
    DFW
    Dave
    Miles of smiles. Congrats! An Epic journey. I had to do extensive de-wiring of mine as there was an alarm, huge stereo remnants, and a radar detector with a six pack of relays shoved under the dash. I feel like I’m a caretaker preserving and improving history on my “Rolling Rembrandt”. Enjoy it in good health!!
    cheers
    Dave
  17. ZikZak
    ZikZak Karting
    Dec 18, 2023
    228
    Vancouver/Los Angeles/Miami
    Dickie Maxwell
    How was water temp in all that traffic?
  18. benino
    benino Rookie
    Mar 6, 2025
    10
    It did surprisingly well. It was pretty rock solid most of the way at about the green mark here. During the longest stretch of stop and go with the hottest temps it crept up to about the red mark. At one point late in the evening it randomly jumped up to somewhere around the red mark... But then we ran over some cooling bumps and it bounced back down. :p
  19. 26street
    26street Formula Junior
    Jan 30, 2021
    473
    Westchester New York
    Mark k
    congratulations what a beautiful car your smile says everything, give the good girl a once over and drive she will luv you right back if you do
  20. Imatk
    Imatk Formula Junior
    May 6, 2007
    863
    Could be that, could be the tach is on its way out. Had to send both my tach and speedometer in for servicing.
  21. Martin308GTB
    Martin308GTB F1 Rookie
    4,334
    Black Forest Germany
    Martin N.
    The definite cause for this; There is a duct below the dash for the fresh air system and the A/C. It's often not correctly sealed against the bodywork, letting heat from the front compartment -caused by the radiator- into the cabin. Been there - I had a 10mm gap there- adjusted the evaporator installation and sealed that ducting thoroughly. Made a tremendous difference.
    Best from Germany
    Martin
    aventari and ZikZak like this.
  22. Martin308GTB
    4,334
    Martin N.
    Just for illustration of my previous message; the picture below shows the duct I was talking about. It's integral part of the evaporator housing and the latter allows some adjustment while installation. This can lead to a gap where it goes through the bodywork to the central vent on top of the dashboard. This gap allows the radiator heat from the front compartment to enter the cabin. Sometimes the rubber seal has shrunk or is missing completely, what worsens things.
    Best from Germany
    Martin
    flash32 likes this.
  23. spirot
    spirot F1 World Champ
    Dec 12, 2005
    15,232
    Atlanta
    Tom Spiro
    Yes, 100%, but also under the passenger foot well, you will find pretty large gaps, that allow hot air directly from the radiator that comes in, around the spare wheel well, and also there are gaps that alow hot air to circulate through the tunnel, and come out by your ankle on the right side... the 308 has lots of air gaps, that you can find when its hot out.
  24. spirot
    Dec 12, 2005
    15,232
    Atlanta
    Tom Spiro
    I would say you have a great 308, if you were able to Idle in SF traffic and it only got to 195 + mark and just stayed there... that is excellent. mine would routinely go past the your red mark and hover between that and 200 ish... which always concerned me.... and then once in a while it would boil over... when I got the radiator torn out and re cored etc... they found that the core had sprung a bunch of pin hole leaks so it was a like a sauna in there... reducing pressure and cooling... when mine was on the open road it was usually excellent and even the AC would work for a time... until it froze up... the Joy's of 308's! Still the driving experience is way better than any of the newer cars in my opinion.
