Jump Start 355 | FerrariChat
Jump Start 355
Discussion in 'Technical Q&A' started by bartman, Mar 12, 2006.
  1. bartman
    bartman Karting
    May 17, 2004
    127
    new jersey
    Andrew
    Does anyone know how to jump start a 355? I can't figure the manual out and I have no idea where the batter is. And it looks like from the manual you can jump it from somewhere else too??? Please help. Thanks
  2. rketex7
    rketex7 Formula Junior
    Jan 8, 2004
    511
    Midwest
    K.C.Y.
    The battery is actually inside the passenger front fender, but no need to get to it for jumping. In the engine bay off the passenger side, there is a black metal lateral cover held with 3 screw with allen heads. Once you remove it, you will see the battery connection terminals. The positive is cover by a plastic lid with big old + marked on top. Good luck!
  3. bartman
    bartman Karting
    May 17, 2004
    127
    new jersey
    Andrew
    Thanks! Going to try now
  4. bartman
    bartman Karting
    May 17, 2004
    127
    new jersey
    Andrew
    OK, I'm a little slow. I can't find the black cox you are t alking about to remove. Can you tell me about how big it is and where in the passenger side engine compartment it is. Thanks
  5. vincent355
    vincent355 F1 Veteran
    6,513
    Wine Country
    Vincent
    #5 vincent355, Mar 12, 2006
    Hey bartman,
    YOu remove the accesss cover ont he rt side of the engine, three 6mm hex bolts I think. UNder there is a box about 2 by 2 inches, this holds the positive terminal, it will have a red cross on it. next to it on the frame is the negative ground lug.
    hope this helps. Let me know if you need more.
    Good luck man.
  6. bartman
    bartman Karting
    May 17, 2004
    127
    new jersey
    Andrew
    Thanks guys!
    Vincent thanks for the photo, that did the trick. I got her started now I'll keep my fingers crossed it's not the sign of a bigger problem : )
  7. vincent355
    6,513
    Wine Country
    Vincent
    cool!
  8. rketex7
    Jan 8, 2004
    511
    Midwest
    K.C.Y.
    Picture worth a thousand words... 355 is notorious for draining battery. If it does not hold charge well, may be it is time for a new battery which mean pulling the right passenger wheel out to access the panel to the battery. Good luck
  9. van22
    van22 Karting
    227
    Absecon Island, New Jersey
    VAN C
    bought a battery tender for 50$ and leave it attached to the car. no more problems with mine plus they make a quick connect so its even easier. live in the northeast part of the country and in the winter on severe cold days battery drained way to fast. no problems since
  10. Ferrari Fanatic
    Ferrari Fanatic Formula 3
    Apr 2, 2003
    1,317
    SoCal
    Jump starting a car with a dead battery and then using the alternator to charge the battery put an INSANE amount of load on the alternator.
    I have seen people replace a bad alternator and not charge the battery with a charger...The result....another fried alternator.
    Under consistent load the alternator could get so hot you could smell the burning insulation and so hot you could not touch it.
